#131
#132
On Wed, 08 Oct 2003 21:56:10 +0100, Ken Duffey
wrote: As a result, the P-42 was able to gather speed and break through the sonic barrier when climbing". It doesn't actually say 'climbing vertically' - but it does say supersonic whilst climbing. Which returns (for the very last time, I promise) to my contention. I've never doubted the ability of the F-15, nor the P-42, nor for that matter, the F-4E or even the lowly T-38 to "break through the sonic barrier when climbing". My argument was purely rhetorical and dealing with the symantics of accelerating through the mach when vertical. There's a huge difference between stabilized vertical flight sub-sonic, then selecting full thrust and achieving supersonic with pure vertical acceleration. I postulate once mo pick a subsonic speed--I like around 500 kts indicated. Pull up to vertical--throttle modulation to maintain airspeed is acceptable. When established vertical, still subsonic, stabilize pitch (this will require zero G) and accelerate through the mach. Factors involved: Making the initial pitch up at such an indicated airspeed without climbing through an altitude at which the mach is passed prior to achieving vertical. Decrease in thrust as altitude increases. Remember that vaunted 1-to-1 T/W is measured at sea level. Available altitude before running into service ceiling Available fuel--while lighter means easier acceleration, fuel consumption also means running out of fuel. Temp/altitude changes in relationship of mach to indicated to true. The simple problem of reliable fuel flow in the unloaded G state required to maintain vertical. There's probably more at work, but the problem is complex and neither the Streak Eagle experience or the Soviet record meet the discussion criteria. End of diatribe. |
#133
WaltBJ wrote:
SNIP: Ed Rasimus wrote: Now, let's put to bed this idea of accelerating through the mach straight up. A couple reminders: 1) with a thrust to weight atio of 1.6:1 the Streak Eagle is distinctly higher powered than anything any of us flew in the service. 2) It's shedding weight in full afterburner during the takeoff and climb. I don't know what the fuel consumption of an F15 full-out is but it's certainly over a ton a minute, so the T/W is increasing. F100-PW-100, 860lb./min. SL static uninstalled, each (probably not with the VMAX switch). As you say, could be more when they're cooking along. snip 5) BTW with Jeff Ethell's flying experience and the highly visible attitude direction indicator in an F15 why question his statement that they were indeed vertical? Checking a vertical climb on the gyro is no big deal - and one also looks out at the horizon. I'm allowing for the possibility that he was a bit overwhelmed by the rate of data. ISTM that Ethell mainly flew prop a/c; AFAIK he was never a jet jock by trade. I've got an account from a seasoned RCAF jet jock (Mustang and Vampire in training, Sabre in Germany) transitioning to the CF-104D, who says he was way behind the a/c on his first takeoff, which was his first a/c with A/B. It seems possible to me that Ethell may have been in the same boat, as although he'd undoubtedly flown in jet fighters prior to that, he'd never flown them for a living. Besides, I imagine the seat of the pants difference between true vertical and 75 degrees or so is pretty small, if you're not rolling on the way up. But maybe he was staring right at the HUD ladder the entire time, and they were in fact climbing at 90 deg. I don't know, I just thought I'd better mention the possibility that they weren't true vertical. Guy |
#134
"Chad Irby" wrote in message
. .. (Harry Andreas) wrote: Once, at Geoge AFB, we had a couple of F-15s refueling while we were prepping a cross-country flight of F-4Es. The F-15s did a "haul ass ten feet off of the runway, pull the gear, go straight up while rolling until out of sight" moves. The four F-4Es... sorta slouched off of the ground and headed the other way. I was on a civilian firefighting helicopter based at George in 1981. We were on the edge of transient parking past Chopper Ops and near the California Air National Guard hanger. A few times we got to see the Delta Darts go chase a blip. They would roll out of the hanger two at a time and go vertical ASAP - very cool. - cj |
#135
B2431 writes It's basic calculus. I'm not too sure if 'basic' and 'calculus' sit too well together ![]() Compared to what I learned, and have since forgotten in calc 2 and 3 it is basic. If you want to see a course that makes sanity seem like an illusion try one in imagionary variables. Algebra is when you stop counting on your fingers and start using your toes. Calculus is when you tie those toes in knots. Differential equations is when you start learning you are now different..........etc. Dan, U. S. Air Force, retired |
#136
#137
On Wed, 08 Oct 2003 22:20:04 GMT, "cj" wrote:
"Chad Irby" wrote in message ... (Harry Andreas) wrote: Once, at Geoge AFB, we had a couple of F-15s refueling while we were prepping a cross-country flight of F-4Es. The F-15s did a "haul ass ten feet off of the runway, pull the gear, go straight up while rolling until out of sight" moves. The four F-4Es... sorta slouched off of the ground and headed the other way. I was on a civilian firefighting helicopter based at George in 1981. We were on the edge of transient parking past Chopper Ops and near the California Air National Guard hanger. A few times we got to see the Delta Darts go chase a blip. They would roll out of the hanger two at a time and go vertical ASAP - very cool. - cj None of which is impressive compared to a cat launch :-) Al Minyard |
#138
"Alan Minyard" wrote in message
... On Wed, 08 Oct 2003 22:20:04 GMT, "cj" wrote: I was on a civilian firefighting helicopter based at George in 1981. We were on the edge of transient parking past Chopper Ops and near the California Air National Guard hanger. A few times we got to see the Delta Darts go chase a blip. They would roll out of the hanger two at a time and go vertical ASAP - very cool. - cj None of which is impressive compared to a cat launch :-) Al Minyard I don't doubt that! I didn't go everywhere at George (especially immediately after the Gulf of Sidra showdown when the nice folk with the blue uniforms and white gloves started wearing camo and carrying automatic weapons), but I don't seem to recall seeing a catapult there. However, there were some arrest cables on the runway - they didn't get used much. -cj |
#139
Al Minyard You put cats in a trebuchet? Do they always land on their feet? Dan, U. S. Air Force, retired |
#140
Saw the remark on a cat launch. FWIW at the Logan drags last weekend
the fastest quarter mile time was 4.524 seconds which comps out to about an average 4.03 G and a top speed of around 315 mph. Let's see now, if I took my 99 Honda Civic and put in a . . . . Walt BJ |
| Thread Tools | |
| Display Modes | |
| bell xp-77-info? | J. Paaso | Home Built | 0 | March 25th 04 01:19 PM |
| It broke! Need help please! | Gerrie | Home Built | 0 | August 11th 03 11:24 PM |
