Aluminum composite reportedly stronger, lighter than carbon
Old October 15th 07, 06:44 AM posted to rec.aviation.homebuilt
Roger (K8RI)
Default Aluminum composite reportedly stronger, lighter than carbon
On Wed, 10 Oct 2007 15:49:48 -0700, Fred the Red Shirt
On Oct 9, 11:53 pm, Steve Hix
In article .com,
Fred the Red Shirt wrote:
Obviously you have not seen how a telescope mirror ages over the
years.
Guess again.
Well then you should have observed that the transparency increases
between cleanings.
It's easy to recoat the mirror, so it's not so much of a problem,
certainly less of one than dealing with silver corrosion.
While it is not a technologically daunting task, it is not cheap for
IF you have the equipment (vacuum chamber, heater for vaporizing
Aluminum) it's relatively simple. One of our Astronomy club members
does up to 10 or 12" for the locals. IIRC his favorite source of
Aluminum is peeling the foil off gum wrappers although regular
Aluminum foil works. It just takes more power.
It doesn't take a super high vacuum either. Just one high enough to
develop a plasma although that's not part of the process.
On local used the chemical process for coating which worked pretty
well, but the coating isn't nearly as even as vacuum deposition.
larger mirrors especially when you consider shipping. I have a 17.5"
mirror that will need realuminizing when I finally get around to
putting
it into a scope. It has been cleaned exactly once, but the coating
is nearly gone entirely after 30 years in storage.
Offhand, do you know anyone who recoats mirrors that size?
Not that size, but there are a number of labs that do the work and I
think I saw a couple of links listed.
Roger (K8RI).
Old October 15th 07, 06:48 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Thu, 04 Oct 2007 02:36:51 -0500, cavelamb himself
Orval Fairbairn wrote:
"Wayne Paul" wrote:
I just saw the following on rec.aviation.soaring and thought it might be of
interest to this group.
From the Delft University:
http://www.compositesworld.com/news/...October/112036
HP-14 "6F"
http://www.soaridaho.com/Schreder
They have to get the Young's Modulus to match, otherwise either the
aluminum or the matrix material will be carrying most of the load.
Anything coming from anything labeled "Green" is automatically suspect,
in my book, until I see a second (or third) opinion.
Copy that. Orv.
I was a little bewildered how replacing he construction material was
going to save mega bux. Seems more like it would COST mega bux to
redesign for it...
Oh well, it's Green, therefore wonderful?
I don't think I'd call Aluminum a "green" material.
Roger (K8RI)
Right...
Richard
Old October 26th 07, 06:53 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
In article .com,
years.
Guess again.
between cleanings.
Surface Preparation (cleaning) is extremely important as traces
or organics (from handling( will prevent adhesion of the aluminum.
Texereau recommends final cleaning by electron bombardment
in the vacuum chamber.
Described by Texereau also, assuming you mean the chemical silvering
process.
putting
The place to ask would be sci.astro.amateur. I asked
OP as it looked like maybe he might know one.
FF
Old October 26th 07, 09:04 PM posted to rec.aviation.homebuilt
Roger (K8RI)
On Fri, 26 Oct 2007 09:53:04 -0700, Fred the Red Shirt
In article .com,
years.
Guess again.
between cleanings.
Which reminded me, my friend uses that plasma for the final cleaning.
Thats a lot of electronic bombardment. :-))
process.
I do and it was.
putting
I had forgotten about that group and I used to follow it.
Roger (K8RI)
Old November 1st 07, 04:32 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
How big is his vacuum chamber?
What sort of vacuum pump(s) does he use?
One large enough for a 17.5" mirror is rather non-trivial. Assuming
a 20" diameter cylindrical chamber, the top and bottom would need
to support over 3000 pounds each, if the work is done at sea level.
FF
Old November 1st 07, 02:53 PM posted to rec.aviation.homebuilt
Mark Hickey
Is it really that hard to build a vacuum chamber? Seems to me that
the most pressure it'll ever experience is about 15psi (1 bar), while
it's trivial to build/buy pressure containers that can handle 10-100x
that much (positive) pressure. Certainly if building a 1 bar vessel
20" in diameter is daunting, building a submarine (or worse, a
deep-sea bathyscaphe, which have reached depths of almost 36,000 feet
below sea level, resisting a pressure of about 1,100 bar) would be
unthinkable.
Or am I missing something?
Mark "under pressure" Hickey
Old November 1st 07, 06:21 PM posted to rec.aviation.homebuilt
Maxwell
"Mark Hickey" wrote in message
unthinkable.
Maybe, maybe not. Round pressure vessels keep their shell walls in tension,
hence the more pressure the better they hold their shape. Vacuum vessels are
just the opposite, and quite often much easier to collapse than one might
naturally assume.
I can say I once built a round vacuum chamber out of rolled 1/4" aluminum.
It was approximately 18" long and 18" in diameter. The bottom was 3/8"
aluminum, and the top was 1" clear plastic. The chamber was successful with
up to an near perfect vacuum, and used many times without failure. At
maximum vacuum, the bottom would dish approximately 1/8 to 3/16" inch, an
the plastic top would dish about 1/2".
I have a chamber I use now for another purpose, but it is only 6" in
diameter. The top for it is just 3/16" tempered glass.
Hope the number might help your estimates.
Max
  #28
Old November 1st 07, 11:38 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
unthinkable.
naturally assume.
Max
You know, an ABSOLUTE vacuum is only 15 psi...
  #29
Old November 2nd 07, 12:07 AM posted to rec.aviation.homebuilt
Maxwell
"cavelamb himself" wrote in message
Correct, one atmosphere, what is your point?
  #30
Old November 2nd 07, 02:24 AM posted to rec.aviation.homebuilt
Fred the Red Shirt
Wrong.
Absolute vacuum is 0 psia.
At sea level that will be about -14.7 psig.
Go to Death Valley or underwater and it will be less.
FF
aluminum rib, aluminum spar, holes drilled but screws broken off jls Home Built 13 January 3rd 07 09:06 AM
Lighter than air... Richard Lamb Home Built 12 February 28th 06 12:16 AM
composite using aluminum windowscreen layer Allan Morrison Home Built 4 January 27th 05 02:19 PM
Composite & Carbon Fiber NW_PILOT Home Built 11 September 21st 04 07:21 PM
If I make it stronger Jdandy Home Built 9 August 30th 04 09:22 PM
