In article . com,
Lou wrote: Well Roger, I was really just looking for a couple of simple answers. Seeing how this is an experimental hobby, I thought that I would compare the strengths of the plywood that the designer put on the plans (old design) against some newer materials and idea's. It may cost me a few bucks but I want to measure strength and breaking points against each other. Lou You should be able to find that information in the materials handbooks. I would start with a Google search for "Forest Products Laboratory", which is the central source of information on wood products. They test materials and publish the results. |
On Oct 31, 10:02 am, Orval Fairbairn
wrote: You should be able to find that information in the materials handbooks. I would start with a Google search for "Forest Products Laboratory", which is the central source of information on wood products. They test materials and publish the results. That's true as far as it goes. However, the design and development of sport aircraft occasionally demands that one innovate beyond the boundaries of what established laboratories and institutions have deigned to test and approve. Consider the practice of using cellulose fiber composite panels for the reinforcement of truss junctions in chordwise wing members. First developed in the 1930s, this practice was validated in a successful glider design and is currently under evaluation for at least one light sport aircraft. However, it would never have seen the light of day of some poor guy hadn't snipped a bunch of wing rib gussets out of cereal box cardboard and tried them out. Necessity is the mother of invention. Theory often follows practice. Thanks, Bob K. |
On Wed, 31 Oct 2007 10:28:53 -0700, Bob Kuykendall
wrote: On Oct 31, 10:02 am, Orval Fairbairn wrote: You should be able to find that information in the materials handbooks. I would start with a Google search for "Forest Products Laboratory", which is the central source of information on wood products. They test materials and publish the results. That's true as far as it goes. However, the design and development of sport aircraft occasionally demands that one innovate beyond the boundaries of what established laboratories and institutions have deigned to test and approve. Even fiberglass strength varies over quite a range depending on the ratio of fiber to resin, fiber orienttion between layers, and type of resin. Plywood layups also vary some what. Roger (K8RI) Consider the practice of using cellulose fiber composite panels for the reinforcement of truss junctions in chordwise wing members. First developed in the 1930s, this practice was validated in a successful glider design and is currently under evaluation for at least one light sport aircraft. However, it would never have seen the light of day of some poor guy hadn't snipped a bunch of wing rib gussets out of cereal box cardboard and tried them out. Necessity is the mother of invention. Theory often follows practice. Thanks, Bob K. |
Do static/probe based TE systems actually measure TE? | Ken Kochanski (KK) | Soaring | 1 | April 29th 07 07:44 PM |
gps to measure feet? | brucrx | Piloting | 19 | November 13th 04 03:33 AM |
Flight physical | Slavko Vorkapitch | Piloting | 9 | October 6th 04 04:00 PM |
Vandalism, security measure, or something else? | Peter Duniho | Military Aviation | 25 | February 7th 04 05:53 AM |
Vandalism, security measure, or something else? | Peter Duniho | Piloting | 19 | February 7th 04 05:53 AM |
