#31
On Wed, 31 Oct 2007 20:32:08 -0700, Fred the Red Shirt
wrote: On Oct 26, 2:04 pm, "Roger (K8RI)" wrote: On Fri, 26 Oct 2007 09:53:04 -0700, Fred the Red Shirt ... Surface Preparation (cleaning) is extremely important as traces or organics (from handling( will prevent adhesion of the aluminum. Texereau recommends final cleaning by electron bombardment in the vacuum chamber. Which reminded me, my friend uses that plasma for the final cleaning. Thats a lot of electronic bombardment. :-)) How big is his vacuum chamber? What sort of vacuum pump(s) does he use? The roughing pump is a two stage, dual vane, rotary pump with IIRC a 2.6 Liter capacity. (It's big and heavy any way and uses a 1 HP motor) The diffusion pump is a 10" Siemens with a 3 stage chimney, but no cold trap. The cold trap is there but only serves as a baffle without cooling and appears to stop back gassing. It uses about 100 ml of 704 or 705 fluid (although the pump works well with anything between 50 and 150 ml). One large enough for a 17.5" mirror is rather non-trivial. Assuming a 20" diameter cylindrical chamber, the top and bottom would need to support over 3000 pounds each, if the work is done at sea level. He has a quartz bell jar that is (again IIRC) about 18"in diameter and close to 18" tall or a bit more. Ultimate vacuum is probably on the order of 1.2 or 1.3 X 10^-6 or -7 Torr although it doesn't need to go that high. Roger (K8RI) |
| Thread Tools | |
| Display Modes | |
| aluminum rib, aluminum spar, holes drilled but screws broken off | jls | Home Built | 13 | January 3rd 07 09:06 AM |
| Lighter than air... | Richard Lamb | Home Built | 12 | February 28th 06 12:16 AM |
| composite using aluminum windowscreen layer | Allan Morrison | Home Built | 4 | January 27th 05 02:19 PM |
| Composite & Carbon Fiber | NW_PILOT | Home Built | 11 | September 21st 04 07:21 PM |
| If I make it stronger | Jdandy | Home Built | 9 | August 30th 04 09:22 PM |
