On Nov 2, 3:55 pm, Andrew Sarangan wrote:
On Nov 1, 12:58 am, wrote: I was preparing to fly a cessna 172SP the other day and as I usually do I pulled the alt.static expecting a small wiggle in the gauges. And got nothing. This was the first time I i got no response from the gauges. I was told by somebody at the front desk this was common and that many of the 172's show no movement at all. But.. if this is so.. how can I be certain the alt.static would work when I needed it. Thanks in advance. I have seen some airplanes show a small wiggle, and some that don't when the static port is turned on or off. There is no easy way to positively verify that your alternate static is working. If you are up to it, you could suck on the static port and ask someone to verify whether the VSI is showing a climb. Then repeat with the alt static open. The latter should not show a climb. Or get a suction for this purpose. Just a thought. I have never done it this way. To clarify i have flown - rented - this aircraft a lot and it always wiggled. The aircraft is a 172SP. I would not cancel a VFR flight in the area for the lack of alt.static, but as my CFI said - I asked him this question too - IFR would be a different story. |
| Thread Tools | |
| Display Modes | |
| Static Discharge | gman | Piloting | 12 | March 24th 07 08:56 PM |
| KX-155 static | Robert M. Gary | Piloting | 3 | September 13th 06 04:40 AM |
| KX-155 static | Robert M. Gary | Owning | 4 | September 13th 06 04:40 AM |
| IFR static discharge | [email protected] | Home Built | 0 | April 2nd 06 09:06 PM |
| static wicks | keepitrunning | Home Built | 6 | January 1st 06 02:01 AM |
