Andrew Sarangan wrote:
On Nov 3, 3:01 pm, C J Campbell wrote: On 2007-11-02 15:55:56 -0700, Andrew Sarangan said: On Nov 1, 12:58 am, wrote: I was preparing to fly a cessna 172SP the other day and as I usually do I pulled the alt.static expecting a small wiggle in the gauges. And got nothing. This was the first time I i got no response from the gauges. I was told by somebody at the front desk this was common and that many of the 172's show no movement at all. But.. if this is so.. how can I be certain the alt.static would work when I needed it. Thanks in advance. I have seen some airplanes show a small wiggle, and some that don't when the static port is turned on or off. There is no easy way to positively verify that your alternate static is working. If you are up to it, you could suck on the static port and ask someone to verify whether the VSI is showing a climb. Then repeat with the alt static open. The latter should not show a climb. Or get a suction for this purpose. Just a thought. I have never done it this way. You don't want to, either. I have had avionics guys tell me that this can damage the instruments. -- Why would applying suction on the static port damage anything? Isn't that what the atmosphere is doing during a climb? Like everything else in life; depends on how hard you suck... -- Jim Pennino Remove .spam.sux to reply. |
| Thread Tools | |
| Display Modes | |
| Static Discharge | gman | Piloting | 12 | March 24th 07 08:56 PM |
| KX-155 static | Robert M. Gary | Piloting | 3 | September 13th 06 04:40 AM |
| KX-155 static | Robert M. Gary | Owning | 4 | September 13th 06 04:40 AM |
| IFR static discharge | [email protected] | Home Built | 0 | April 2nd 06 09:06 PM |
| static wicks | keepitrunning | Home Built | 6 | January 1st 06 02:01 AM |
