#51
On Nov 1, 1:10 pm, "Morgans" wrote:
"Denny" wrote Jeez, there goes my excuse for not fixing the broken latch on the tailgate... I hate it when that happens... Ahh, don't sweat it too much. A couple bungee chords will do just fine. g -- Jim in NC I hate modern technology. They never work as well as the old stuff. Just today I saw the broken end of a bungee on the side of the highway. That never happened in the days of baling wire. Harry K |
#52
Capt. Geoffrey Thorpe wrote:
"cavelamb himself" wrote in message link.net... ... But those webbed tailgate thingies have GOT to increase drag. Don't they??? Richard OK, Following up on on old thread. I spent the day working in an automotive wind tunnel today, and I thought to ask the operator if he had tried tailgate up / down in the tunnel. He said they did a bunch of tests on an F150 and found that a tonnau cover was best, a cap was nearly as good, tailgate up was better than down (I forget if there was a difference between down and removed) and the web things were the worst. With the tailgate up, when they used smoke, the smoke would go over the roof and then come down and touch the top of the tailgate. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. I work on the RJ program and it was once explained to me, in a discussion of devices to slow airflow in ducts, that a wire mesh structure has far more drag and will create a much larger and more permanent (longer lasting effect downstream) drop in velocity than a single obstruction, even if the single obstruction is much larger. In our case, a nozzle type restrictor used on the cockpit air duct had a fraction of the effect on velocity downstream, that the mesh screen at the outlet had, and was basically useless. So it's easy to see how those tailgate screens are the worst thing to do for drag. John |
Myth: 1 G barrel rolls are impossible. | Jim Logajan | Piloting | 244 | June 22nd 07 04:33 AM |
Dispelling the Myth: Hillary Clinton and the Purple Heart | Otis Willie | Naval Aviation | 0 | February 21st 06 05:41 AM |
dam busters | Hamisha3 | Military Aviation | 48 | February 26th 04 11:17 PM |
cheap, durable, homebuilt aircrafts- myth or truth? | -=:|SAJAN|:=- | Home Built | 27 | January 8th 04 09:05 AM |
The myth that won't die. | Roger Long | Piloting | 7 | December 19th 03 06:15 PM |
