I am far from an authority on the subject; however, I disagree with the AOPA
and believe the following logic applies. If you are a Private Pilot (Glider) then you have a higher rating then a Sports Pilot (Glider); therefore, the Sport Pilot (Airplane) can be added on with an instructor's endorsement. The main Sports Pilot/Sports Aircraft guru is the EAA. They are the ones who fought the battle in Washington to form the new category. Wayne HP-14 "6F" http://www.soaridaho.com/ "Andy" wrote in message ... In a recent thread it was asserted that it was possible to get sport pilot airplane privileges without taking a knowledge test and flight test if the pilot held a private glider rating. For some reason I cannot see that thread. I had doubts that this was true and followed up with AOPA. The text of my question and the AOPA answer are shown below. my question: I seek clarification on sport pilot rules. The sport pilot PTS provides this statement: Sport Pilot--Additional Privileges If you hold a Sport Pilot Certificate or higher and seek to operate an additional category or class of light-sport aircraft (14 CFR part 61, section 61.321), you must: 1. receive a logbook endorsement ....... 2. successfully complete a proficiency check from an authorized instructor ...... 3. complete an application for those privileges ....... 4. receive a logbook endorsement from the instructor ....... In this context, what is meant by a "higher" certificate? I assume that a commercial single engine land certificate is "higher" that a private single engine land certificate. But , for example, is a commercial glider certificate considered to be higher than a private airplane single engine land certificate. More to the point, is a private glider certificate higher than a sport pilot certificate for the purpose of meeting the PTS requirements to fly light sport airplanes? I.e. can a person with a private glider certificate receive sport pilot airplane privileges without passing a knowledge test or a flight exam as long as steps 1-4 above are completed? AOPA answer: Thanks for the email. Your issues is one of SEL power vs. non-powered glider. Any current glider certificated and rated glider pilot desiring to fly any powered SEL aircraft must complete the powered training as appropriate. Sport Pilot privileges and certification requirements is Part 61Subpart J. Outside of SP is Recreational, Private, Commercial and ATP. All powered ratings, Glider is separate. Upgrading from an Sport Pilot certification to either Glider or powered Rec or Pvt SEL requires passing a PTS with an Examiner. A glider certificated pilot is not higher than SP. Higher certification means going from SP to Rec, Pvt., etc. FAR 61.31 and Subpart J defines the differences. Taking written knowledge test to stay within powered aircraft does not required additional written test within SP. But moving outside SP to Rec or Pvt does. Reason is each test is written and designed to cover the privileges and regulations applicable to that rating certtificate as the rule are different. end AOPA answer. I won't attempt to provide an interpretation of the AOPA answer. However, I find the statement "A glider certificated pilot is not higher than SP" to be significant in understanding the Sport PTS requirements. Andy |
| Thread Tools | |
| Display Modes | |
| Sport Aviation Airplane | Danny Dot | Piloting | 29 | December 11th 06 03:49 PM |
| Can a Sport Instructor give a tailwheel signoff to a private pilot? | TRA | Piloting | 4 | September 14th 06 08:17 PM |
| Light Sport Aircraft for Private Pilots (Long) | Jimbob | Owning | 17 | March 1st 05 04:01 AM |
| Private to Sport Pilot | Slick | Piloting | 10 | February 26th 05 10:35 AM |
| Mooney to Offer Light Sport Airplane | Rick Pellicciotti | Home Built | 4 | September 24th 03 02:08 PM |
