Ugh? If you have a 302 you have one of the best STF there is - so make sure you have the right polar, ballast etc. loaded in the 302 and use that STF - and then worry about how much to ignore what it is telling you to do. Anybody serious is going to have a good flight computer, the PDA really is the wrong place to do STF-- and I would want an audio tone not to be trying to read a PDA screen for this type of info.There is a great thread on the SeeYou Mobile support forum that touches on why PDA based solutions really can't provide good STF - they just don't have fast and clean enough data. See http://www.naviter.si/component/opti...8/topic,2832.0 (BTW Naviter's responsiveness on their support forum is very good, and one of the reasons I switched to SeeYou Mobile). But in this case Jerry is likely doing the right thing by ignoring your request! I'm not sure what GN is showing as I've never used it. I am not aware of any detailed description of how WinPilot Pro calculates wind and I've not used it enough (well not recently) to be sure but I beleive that WinPilot Pro is reading the extended data in the NEMA stream for the 302 that includes TAS, etc. and when you change direction enough it can calculate the wind from that. This is also how SeeYou Mobile does it - they don't read the computed wind output from the 302 (which is also available in the NEMA steam). Winpilot Pro can also give you near instant headwind/tailind component just from the TAS vs. GS. When you thermal it will use circle drift. WinPilot advance only uses circle drift. The raw TAS/GS/ etc. data is more or less the same but both WinPilot Pro and the 302 calculate wind using completely different software algorithms, which will have different aging factors, different height bands, hence the difference you see. I'd not overly worry about these differences, they are all pretty crude approximations to what the wind is going to do next. Worry about knowing how to display wind vs. altitude, develop a feel for how accurate each algorithm is, and on the PDA especially know how to resent the calculated winds if you think they are going to run you into the ground with overly optimistic tailwinds etc. The 302 is calculating the wind that you see on the 303 - which is just a display to look at what the 302 thinks is going on, it really does little else. Darryl On Dec 5, 3:43 pm, bobcaldwell wrote: Hi pilots, I know this subject has been discussed in the past but I am not sure if this particular issue has come up. I run a CAI 302 which drives both Winpilot Pro and a 303 head. The wind speed and directions are often differing by large margins on these two displays even though they must be looking at similar information. This is true even after turning such that both displays should be completely "updated". What are your thoughts on this subject or can you direct me to the archives where this question may have been already answered? Also on the subject of Winpilot, myself and others have pushed on Jerry to provide a navbox with speed-to-fly data. He is apparently unwilling to do this even though the program must be calculating it. I understand the reasoning behind not chasing the instantaneous STF number but I often wish I knew exactly what that number was. Other programs such as GN II do provide this number. If other WP users push on Jerry as well maybe he will put this navbox in. Thoughts? Thanks and fly safely, Bob Caldwell |
| Thread Tools | |
| Display Modes | |
| ATC speed instructions, wind and altimeter indications | Mxsmanic | Piloting | 27 | October 25th 06 09:05 AM |
| Dr. Jack's Wind Direction | rjciii | Soaring | 14 | October 5th 03 06:37 AM |
| Wind Direction | --=JJay=-- | Soaring | 2 | September 27th 03 08:18 PM |
