Brake bleeder device
Old December 12th 07, 02:19 PM posted to rec.aviation.homebuilt
comanche driver
Default Brake bleeder device
mine is a chunk of 4 inch pvc with a cap glued on one end and a screw plug
in the other. a tire valve stem is mounted in the cap. a hole is drilled
and tapped in the side of the tube at the bottom and a small brass valve is
inserted. a small tube that fits over the bleeder screw is attached to the
valve. fill the pvc tube with 5606 screw the cap on, charge it to about 30
psi with the compressor, slip the tube over the fitting, crack the bleeder
fitting and open the valve slightly.....vola
cost about 3 bucks.......
R. burns
I use an oiler squirt can I got from ACE(?) hardware. Attached some
tubing to the squirt end and manage to get all the bubbles out. A
little messy but it works. I really don't need to bleed it that often.
SQ2000 canard http://www.abri.com/sq2000
Some New Benefits of GPS Device [email protected] Piloting 0 September 19th 07 11:09 AM
Tiedown "winch" device City Dweller Owning 12 June 22nd 05 05:37 PM
New Wheel Locking Device TM Products 2 March 29th 05 04:07 PM
DIY DF device John Home Built 15 May 4th 04 11:32 PM
New traffic warning device Loran Products 26 February 18th 04 12:14 AM
