I was stationed at Beale AFB, CA from 85-87. I lived in base housing three
miles from the flightline and run up area. I still remember the house rattling when they were doing SR run ups. Wasn't the SR-71 cabled during runups? As for the B-52s. I was stationed at Beale AFB,TX from 78-80. My barricks was next to the flight line. I will never forget the run up from the KC-135s and B-52s. The black smoke and the noise was bad. The alert pad run up were no better. J.F. "Eric" wrote in message news ![]() If you want teeth rattling and the feeling that your heart is going to vibrate though your chest, you should try a B-52G with all 8 burning water (water injection for the uninitiated). I never got to work on the SR-71, but their power runs were always awesome. Your teeth rattled from a 1/2 mile away. "jc" wrote in message ... On Sun, 16 Dec 2007 11:46:08 +0100, Michael Huber wrote: Markus Baur wrote: is there already a report out what really happeend .. ? Can't find the link now. They did a max power test, and apparently mx ran up all four engines simultaneously instead of one by one, overpowering the aircraft's brakes. I would suggest that one does not do full power runs "one at a time" on a large airplane with wing engines. If you do, the thing is liable to spin like a top. Every airline I've that I've ever worked on their airplanes had a policy of running at least two wing engines at the same time, one on each side, for full power runs. Twin and tri-engined airplanes required that both wing engines be run at the same time for full power runs. In fact, that same policy was used on TWA's Connies (other airlines with prop airplanes I'm not sure about). Generally, not all 4 are run at full power although I've done so on 707's and 747's a few times in the past (we always used chocks on all wheels, too, including the nose). It's somewhat exhilarating, if you like getting your teeth rattled. Even more so if standing outside, next to an engine at full power. It vibrates you to the core. Cheers, jc |
| Thread Tools | |
| Display Modes | |
| A340 Engine Test Gone Wrong | Phil | Piloting | 15 | November 22nd 07 04:16 PM |
| China Airlines Airbus A340 | Valentin Golec | Aviation Photos | 0 | February 17th 07 10:29 PM |
| airbus A340/330 | Christian HACQUARD | Simulators | 1 | May 2nd 05 03:45 PM |
| cokpict Airbus A340-313X | franck jeamourra | Instrument Flight Rules | 0 | June 26th 04 08:31 AM |
| PSS A340 with FS2004 | PumpkinPie | Simulators | 1 | October 5th 03 01:19 AM |
