A340 Incident
Old December 17th 07, 01:35 PM posted to alt.binaries.pictures.aviation
J.F.
Default A340 Incident
I used to go on rotation TDYs to Mildenhall in 79-80 when assigned to the
1st MAPS Sq. at Dyess. I worked in the AGE hanger right around the corner
from the Det 1, 9th FMS hanger. I used to watch the SR take off in the
morning. It sort of marked the end of night shift work day. If it wasn't
the SR71 waking me up, it was the F-111s from Lakenheath.
"Eric" wrote in message
. net...
I worked B-52's in Michigan and then 135's at Mildenhall from '77-'84. The
SR-71 routinely came in TDY. I usually worked nights, just getting to bed
about the time the SR would take-off. You could hear the engine start cart
with the two huge (I believe Buick) V-8's with shorty open headers all the
way over to the barracks, so you knew what was coming . The vibration from
take-off was so bad that stuff on the shelves would occasionally fall off.
I did see chains and/or cables used as tie-downs, attached to what looked
like a manhole cover with an eyelet welded to it. Obviously it wasn't a
manhole cover as the SR never pulled it out of the concrete on HS-24, not
far from Mum's Wood.
Mostly off-topic, but, does anybody out there know the stories behind
Mum's Wood and HS-28 at RAF Mildenhall?
"J.F." wrote in message
. net...
I was stationed at Beale AFB, CA from 85-87. I lived in base housing
three miles from the flightline and run up area. I still remember the
house rattling when they were doing SR run ups. Wasn't the SR-71 cabled
during runups?
As for the B-52s. I was stationed at Beale AFB,TX from 78-80. My
barricks was next to the flight line. I will never forget the run up
from the KC-135s and B-52s. The black smoke and the noise was bad. The
alert pad run up were no better.
J.F.
news
If you want teeth rattling and the feeling that your heart is going to
vibrate though your chest, you should try a B-52G with all 8 burning
water (water injection for the uninitiated).
I never got to work on the SR-71, but their power runs were always
awesome. Your teeth rattled from a 1/2 mile away.
"jc" wrote in message
On Sun, 16 Dec 2007 11:46:08 +0100, Michael Huber
Markus Baur wrote:
is there already a report out what really happeend .. ?
Can't find the link now. They did a max power test, and apparently mx
ran up
all four engines simultaneously instead of one by one, overpowering the
aircraft's brakes.
I would suggest that one does not do full power runs "one at a time" on
a large
airplane with wing engines. If you do, the thing is liable to spin
like a top.
Every airline I've that I've ever worked on their airplanes had a
policy of
running at least two wing engines at the same time, one on each side,
for full
power runs. Twin and tri-engined airplanes required that both wing
engines be
run at the same time for full power runs. In fact, that same policy
was used on
TWA's Connies (other airlines with prop airplanes I'm not sure about).
Generally, not all 4 are run at full power although I've done so on
707's and
747's a few times in the past (we always used chocks on all wheels,
too,
including the nose). It's somewhat exhilarating, if you like getting
your teeth
rattled. Even more so if standing outside, next to an engine at full
power. It
vibrates you to the core.
Cheers,
jc
Old December 17th 07, 04:50 PM posted to alt.binaries.pictures.aviation
John Szalay
Default A340 Incident - 2 attachments (2/2)
MBS66QQ!W^A\_;!D2Y/F&2U-70PS2R4^AF@*DZ6MOW0@7-S]=L1--5UN6PM
`&:#KISS\T30)&8CO/TY]5QP_Q%5,:
M?G7PVDN:BH898MDU`F,(`;?3SQSQT3_P`0_19XT+D^YW) #HH%^7CAA"
M[;7L=R3O?WQSLQWNQ!EVT*YFO/7.GBO8]CV/8VZ4G*0L*N(IU[P6_/'T
M"?#BH^\/9:X359HXJ5Z4]S&MM37NHOL?]_4=,?/W2/W=5&_I(#^N/H9^%]
MS!CXJ[&G#E)54+QFC)IZ7P'5)IL]PP&PU'J?+'+=)BX,IP./T6QV46MQ8[@
,)1!/G$+,LI0&!-'B"@
MW(]+7MB](.(J.&(-4T[4U2B:JAF93J)'51Y]+FVW3#39O517,T-2TBAE2$%
M"[7ZW)Z'8_\`VC'(M+YDM'=9=3F8\!U[\]6C/PMSD:GD/\`Q4YEDD%C;22
MM[;@ON=C]\#9;RXYUUR2TD7&@++&2I:P$A+=!T(/E_IB^)*\9C,:*=IHXG!
M.S!2.GIN2;G!53FM)1P5$%-J,9_=7N`IO?QO:P_3!TZKH,`2X(0QCCVF
MVW7YB3]E8L')_G2(K5?%1$B_B57`"BYN-0\[7.)IN:,5(M53;0M''J#HC
M$L03;PF^YWN7_EE;F%ZK\F%!),D:&Z6(NP._2YWQ+T%-#15W?REV)D,3+
M8`'RD#W'4^@Q(KO)[4'RY\%GX=IRY1?B/KKY+'M=3\Y.&^&8J&"O6HKZQB;
MJI_Z5Q8WL;6Q:=7GW:8R[.(QBR".IBA1]+]+L?KU!M]L9TAJ'$;9KF'=Q3B
MG[I%D2][,`-AY(BYVVQ3+N+8SFL1D=G5G"H5B!#D#RFUA8^W7#&&QUO[
M\$#GMRQ)$^ZP'5]H[G)P[$[YAR]J)E6,,\:H%Z@7M_=KF+3H_B'49)%+1
MUW"LT$:S-I=82"=SYZ=+G[#&U8Y-0RAE@5GF@,?R^B[6)N#8"UP-K0^Q
MQ`MV?5/$,)J\TX/AG(D-DM8O7)VZ;D@#WQP[L.#-6GZ'Y+78FG6S-2?'
MRCV.BQ%P!V].'L__`.S'A&5&`L)&U`L;;D[^(6\O]!:X\C[:'+^OS26FRBG
MEG!96-/+3/:-@;`!AUVMB^,M[,7(&EK)7CX?2%HE8E0WH=](VM;;KZ^)OAK
MD3RBR(&3)MA:$/KATF,L0.C&Q/^^)K'".LQA'CI^R.E3Q5",[P?*_CY*U
M&[1W!PD8?,!)71P'IROB"D,&N-EZ?EY'`&4]MCDM2.T]1G4(K$003O4J3I2
MS7(`Z&Y.,JYWRQX'?*5RV;+HI5J+(TRHH;3I*ZK@7L-PM_,8QGF?9`[/-?6
M33/PZ)I)I"(5V4RH#:^F_7J??;`T^I-,AUAW1X%E9M5P#@X7L9X1SHKCX
M;[17)CB7,JG,H+(Q`%`B+:%5C?K8V];?06QDO'O+6"D@XAJ,_A6I0@'5H
M#`&VH6.]QZ_VU\XM[%W`=?ET%+PP9:4&0_OQ*WA'720/;[[X;S/L5,U$N4
^7T@J
MJKC6AEJ)(Y"SR3Z[!@;D7VM8#KT-\`9AVAN5-!31Q0\44XF`1C-%*OA73;3;
MSZDWQKJ_8@JZC+C4T/%E0&C!U`L3D]#?Z'IZ^!_P#X"8:AXX:OC"HD60^&
M5FNC@=0"-P;G;8?IAI9A'-+34]N=RKSCAB);3!C4?OZ+.=7VD^4N:9L^60\
M2PK!$NIYTD!9Y+"Y)(M^9]\.T'.WE]ETDL5+Q73S1:U*/)*I-B&N&'\77]+
MXPE5?#\X2RN8TJ\3Y@XB,D9$4H+*P_%OY@=-\$95V`.'Y.^GJ.:V&DB@W56
MG78`&XWMUZN$&EA0(:\GR3*=3'5W0ZD/59L?FQR]:KGI\_@DD*:*:-YM!
MTAMR3ZVV']-\*?M)\J:FJA@CXHH8/EZA@89)=5CX1:QW!V!\@+#&*A\/KA5I
M4BI^89E=^Y5&V.G[_7N(KB;XV15TDM/P[Q1-(X),K25#@QL"03MT&QZX
MJM;A7""_V^:NU&8MQ$,GS_19KSGGERHI,O-/2\0TX5]]3ZBNXNQ=CWZ^AN
M?KBSLVYZ\NH*EZ:?.J14C90)EF&F5_L?X38VMY8Q_3_#JX:% :"7CJL9D(#5
M"RR,=Q8"WMU/MB+SGX7=2E2)YN+:V*D:1R6$YO8,0-CON+=.GVQ+:.`B7U#Z
M);:E.GEITVQNO_CZ+*D?-SD_74SC_CBA6:50=`%F-KV`'GMO?;?$7)S'Y
M?453-%3\8T8J9T5115`[[W(].FW7&)\Q^%I/'40U.7U1NQ[UI6LGE=_
M\OE^6#F^&?2UDLM?F/,"HUH[+3QQRFSOJL26N-NO3TPYV'V;E@53?="J"MM
M1Y$T`!;LF95QOR9BDCAK..:26268@LM1HUJ]SY;CI:^)F;*,E&94T^79_12
MPU%E0Q.&T*VRDW_"?KC"%;\+C,JRNEK*/CFKC%/QNCD%B2!:WK??W4ML`
M5'8/Y^*YCW?#O,:HE1$4+"9R021QWVM[$8K_A.Z&LJJMFKBZ9S5:-O\`
M:;^A6TV4CACAVJLZS2BD#.).^:9'"):RCT-K&^'ZCB3E_2-+ET'$,0GE"O
M!,LB=VH'0'W)/2WIC0/CCL\=LGAUIY8VS"13*REXY[[7!T]=QC\\6)FG+S
MM2\+2]_Q#2YM%(4`CU2MLUK#?I]`?;%NEL0N(=U[;[E4J;?P$#"O@:E=-7X
@`DWWZ^G7S&
M.8N0CM492XFC7-F@4!:=A%J-]_/&5'N?G:JX:X1BAEC,TD3"-4:F74=]PY
MZGVZ89B-D5J)$5&N/B`4O";?IUYST'`?.];Q)1F?+GIN\L[2B0NYL-86S!
M3Y=`=\`3T$=/(IEEK+W$:OX0UCXB?7J:6R=L;M7\/PR&OX'2L)-ODU0C5'
M8;^S7/4N(NE^(IS?HYIZC/"YJ.8S`F*0.Q%@#TVMTZXJ'9V.)AH!WV,J
MS3VKLZFX.(+9C4'4_-;V0Y]0T=E#$T[3.KVE6#'@7ZNW7`^?"2AS2"G
#0KLM[V`'2WVQ
MDS.\S[5/%?"%)7Y5DWR-?44_1Q6&P(WN?7U&$G`8FG(0/$[_7Z)C-IX?$/
MFF"8N('W^2V&J\VRG*:!LQK@AFJ1_P`RKMLW_`38_4?UQ&9A S/Y;94%R^LX
MGHH8+*8HG;2Q%Q'?S7:_L,:9=R+[;G'6:TDG,;FM+0NDEXJ5P'TJ=EVVO
M+AS8_P!5H[]?=;#YUVKN4^4O+35.4P6,!8(1&'"`VT[VN3?K?&/N-NUSE5
M-32YAPED;E(9K0OH)90U[D"WF/L+8+R3LNM,ER-I)8'K*CY@(_-RH%O+S`
MVN,7IEG+K@N'+XF?(H'"`*&$:Z2X%CX?0D^V^%MHX2FVTN]DUSL96-X%N_QC
MG[K`65]IGG5S#S9'P9PQF"1,"'JYJ;0AW&]MO.YP[Q/P)VG.+)3")):9`2
MKA]QKWL+B][6).-FLGROAW+Z?][E5-3*CD:HE%P#X2-O+8]-MO?#E=/#49:8
M(H4:H9Z8I"-2E0;AAU(-P;V]QA_7T*8&5OGJELPE=[3F=()W6YYX+7'E7V
M0*E)DSOF7QG-6U!:R12R$JOJ"/3WQE?A;LZGH*OO:3AR#YI@-9JCK5UV)VM
MY"_O8^N+IK*7/%HHH,K+K*9BSJ8@1N+BX]/+?U.&HWK9\NC2?+'CJ#*##'.
MFEHVL`=SOO^?0X'/5TPZ)\D=.C1I4Q++C0Z_JE9#P!DV0T*G(,H6"G*M'4
MJ-(**MC?P[W\1/VQ--*F29:"@I9)D=%U3P+LR6W)\M/V\\6]36SF01YG3
M.LA;NS%`I(GSVV!MMMZ8F:3.I,WINZRZ+NTUZ59B!`"XZWM 8?3"@:K]=VG
M[JR'400&BY/?SW=RD4RY,RC^7I:EHB"HF=9?`$L;D^X/]/7"JB4^56`#*)-
M%.([-N2;:A?S`O[;XK29%%498L:RM%,\A[Q`P`13C4.E[GMA$C9_'&E3,J
M?(L\@1T4%9"@-B1U!!_B]L,::C:EBG/+#=I\M/T^2+R:B-)EQJ:B00N"!)#&
M;:"2+-?U-O\`\HXFI*M%FJ?VA$J&6(I'IB8`A=B01N"02,0-+E=?&LLC2K)(
!?TN/OZ8FFZI,D*'Y'`ES+
(\@L
-4M=:RET
9_?Z*O_`*F4'73W[CS";EHY*AZ."9_^6+:5$-1I
M"M?4?7H&Q55'3UJ?-F%8M;I2=SR(^PM?I8W&WM@/*(UJ9S4QP]Z\:!]
M)/='0H)78BW7KUOB5JZ"LH*9:B,QS)(LDD8$E@3)JOOZ7]O;#6EY(;W\
M^J![VO?!L18VW?7BS3T%/04,T$-1KCEU#1.6[QAJ.]K_6_3K[8+H$RBKF5
MX*B6%Z:G;N&07#V'BTGSVN+8-EB:&E-#7SDRR0A14A@P=#UW\C8FWWQ'Y8J2
M"&NRNF.072.($*5!(;R];[=&VH7""-.?T6#(\0`)$$^%^/@GKX=KJCD
MS*'-8ZA)K&6GE7QH-%PHWW)V)^F"EHYU1:BFDF19I].D^-HM8O87O$&UO+[
M8K.FL1'#DK4J2R)W32;]5L;CZW%_0^V':7,*^*BFIH0ZT\4ZA*EIUUBPTDJ
M;]#O][8F:E0V'A)!2T\_+T0E3F59DKS9?-"L:U#/&H+`E`NWD+V%_U_+V7
M9A7+`Y$L]-)'&$GEA`8E02+BU[C]F$4V7)7TWS=5*DXCJ`669K!]K,5/J0/
M;#V9U9RBJFI,NJR89(!&\A0!8D`V(V&LB]MKX,C-$B_FEL(K+1'S^WV1]#
MG=%)6S"&&1[0*Z1O'*2-NOT_7?%:B=CE*UE1EJO)W1-RH3NVL;KMU&Q)O?K
MB'RZOK)ZEGF=B9PJR.!86\Q]"2ZHJ44S50:J@5@T-2P%E(T];$$6+;^N%F
M,P!^:$N=3:71I]/"_MY%40/#F,Z4].:Y9*/%WATHI&UQ;Q7`_.WO@"//JII
M:0K(ZA).XL9F(NUCUV/Z$X(.J5;\!R80/IL$.#?;Z\]^BF:.7.!229B"@,3W
$6;`^X'YC$7246=U]8T"5+
MGO8=!:KF'47MI.QO8'IY7PNJR^EAK1)4LC22@!1(NL,+$^$=-B;^^^(#2"0
M=/VU2JCB7918_(I]*^CIVJP:$B66;NXT2R!@QON3L;`@7]+X0^8BKF:*:2
M&2,1'NY*=]R!R$]=CQWN,*RS*UJJ%J:GH72CC.F56'BL;$=?$C=/(X(R
M_+H'IQ$L$0[,X2YO\`AM?\5R?3IADC*/%9UC1IKSN]_-5R7,\QJ0D,/=R
M@IWDT!CL407"D^?B\6Q-[X5'FD]%3BKGRWNZB6YTK^$$DD7L=B;WO[#TP97Y
MDB/#F9J(1,1W9CCC(:7`!8`6`ON/J;=-+*M+0&GCJVGLKS/WS"PL/"`.NV
M^W^V(:'9Y.I[_P!$#ZK#JS6)YX\4$,_!A$G_+K'=I)E()*WN3[;#IU\6#J
M'-J.1)JF%Y16/3ZD)8:63406OT`WON;[8M_+OV?W2UE7'"P\,3I-J`)U`Z;`
M"XOM?],2M!4#(XJFA@C@1/_P`L20RLK*&\7FMC;]?3H&YF4S//(1.=+(
MB./FCZC-Z&KKC01_+]^DWB$X+KHMNU^AZGTZXB(FRJDRAIJR=6$9M''2Q&^
MJQW!(W-MOOA6?9GEF243UT-0IG4=ZL8N3X02"&&^YM#TWQYJO+VHUK8X&6
M2-`0H!D56&P(N;+L;G_3&!KM9]-Z6`#V@(TY\%YJ]4-+F51,[".$QTL*OJOT
MMJ(WO;^M^F$+\]F$B"6I6DCB8F)!'W:LP&Y)!LP_U]L.4D=)F6504M88(YJ
MCO$700Y`U`V]1N;D['UP`T1RV.:FS22."=PYDD4`^(6M:UE!L#[V`DYHA$
MV'B'7MP]/.BR/,!1Y!&8JHJ+B8GQAAL$N0+^7TZ8ELJ8,S-/)*L2B!P
\1 Z6W&U]]\$9)
MEW$F3U(898D4O0GIJ*KU4,2NPOY=!@LLDF80-#,I(:9WZ\=WDKCGS:BC
MK9J;+:"+1"%D96!6YU$WM;?R-M[?;%N9YP74SYJUBF[N6=%22(.+HI:_3P
MNNV&PGAN%0L]3',E@Y!&A`2`2PO;`V'OYX,R:JS;]HRQF9@VKPNT;`*I
ML=0W!&P'MO\`4X+,7"02B]M)X#6P8LHBOKH,F'RD53`\3#34$-G:Z'?S
MOY?GYXRBIGRO(FKF6:5U4-K("+I9;BXZV-C;T(M@DRU^;U-3314$54Y9P(E
[%-R5&_M?:VU\2\R0`I:'$%KAP
M//I.FB3\U29K4&I[R-8ED0PS5,I'C\VM?Z_I@J?+,K5C45-13HTT802J22'8
M[-;R%Q]KF^V(2JCR^:H-+)3@+3KJ5GX1K:K`7%@#?;_`+;;X?RRIFIIC\[
M*E14Q-=;GKJZ7W%A;;#\M-3FF7.ZB[V6-K11S3!@"+^,`9#6!Q'BKRO*P*
M=ZLS,W[J$^&1BPLQ\AT:X'0GIAC*\UIXZ6L@J)+F^8EIR`$0D;`VW\ (W^
MN%Q4B=UN")E5F:&RX'KP\E+S4-`^615U-ERM&Q_=%G-V`W(8^QU8!7)*=Y&
MS6CIHH641M+ILZM_"-O$#UW]HPY#F0[_Y:$3)I\,7A,D'%=_+G??`F
MU4^4S!(:B5VF20ZVD*:$V(/A(.V^_P#7&.S$R/'7=P]KJ0X/;E?W\\\$SE%0
ML8O.V81EIX-$D4+`ZF)(\^N_EMO^6#*_P#9U"S43153D*3^Y32RR'S.P&YO
MY'KB*J:67532K*/F9Y59E.H,-):Y%MAL/(FPQ2ES:3,)*BKEAEC0E1$TA/A
MMUNQV-S8W)VN"&OD.:$65C221(]^/'P^RN%5%9"STE/+:?1IIR]S&-%C;8V
M-][]-\`9_-,LDM+4_+B(A1,8E)[W8J+&U_3IQ.!*+.WH*414]*[,(VCHU
MM(U`W!#WUMAN14%6:3+HFGAA"]S(H)#-=0=0W&X.#)!]4!:P@.&^W
MKSO2:&#-I%BEKYVAB6(,_,J%&`L$L!_EZ^XZ8#RZ"@I)I,QFS(10[K(9$UL
MRG8V4#V!O:VUK8FLKS2@K\XE6H?NVG"@+(NI3OOIL#IZWW). !6X1J0RPYM4
MAH6E)",2H7J%+6\V('I;VP;B^F0V-=/FL+8:;1'/[)%3%3Y95J:*E9J4S7:.
M5K!KC8#JW4^HZ#UPS414]?6O6FCAF_=F..*2P`8@F_J`-R/ITQ)9A6)%FQC^
'8Q^PCQ
M^ZAH-0[SW?506:Y*++FJJ;.%B=K/%&H-KFP8*;;D=#MY#?`W#V8U="($
M@D"/22(H_$6U;A218J3Z=!BY9L"UC1R3!13J[B/N19]0MI;8^5NMCN/K@7
M)J"CS8S4-5530TY82!7`9$]C8`["^UNG3`Y#4`UL=3^R;F#&YM-+)CCQ[M
M?!#9?Q9%39IW,DD4D*B7N.[%B2HN+$6U`J/,;X,H,P+UKPST3:9%#*AW1N
MH-[7/G]+?E7-,DRT5E:\I0+=%E=P-+-?P[;&]O,[6V(F:?.(*BG@EII(XM
M*NS6.Z&X'7]^O7WQ@#S?GGR1YFF0&GGAS[2I))LLJ9:B*B[QN\TP*CWB+=
M6W(`%MC^U\"997O-F4]!$Q8B+O%82`@/T47Z*.@]+B^%YE723YE:M,(GH4
MRQ&^ID8`F['\1L#O&UO48A^$Z-Y:JKSZ%"D*ZB5#FZGW(N";P]/;$RX-
M-_7GBJN81V0`!\_!26;54F40E)*801Q*GSBBY#K86"&Q\0-QZ'%C7\L7
M_-BAJ\JXLX6C5&"BCS%P5EU:NM_+S%O7%_5^33CO\UFE:1Y!HA, 8;\`!W\[
MDDDB^XMZXB9QDJHC#E=$QDIVNZ.RZ`X.QWV`'4'S/7`EKGG?/&5C,KB00`T
MCO\`WC=.BP]E/9GYA\HYGSOE5QU5S4ZPJT&7U^EA)+8C2IW]Q?WQ!U_:RS7@
MV2FRKF_PG6T53)5%^AI[Q+O8D6Z['];$F9XP^0EJ3$@6)4=E$AUFW3:P`
M#=#Z7.(;B_A*(IJ#B#(HJR$@AS51)9)+`+XM[DC;;`EA#E!9#8I&.[TX_
M0JO"',+@OB^%VX6SJG0HHEC8,A92J[#U!V]]L3F6O1Y,QFEF$DY*:YGN
M23TZ^0TG[$XU_P"8?8^SVGS5*N47%=9E%=*!**1I2(&8"Y-CMTVMOAOAOM4
M\WN`\UAROG=PBT]/3JL4%?$MU87&XMUL-_+KC!F;W_/Y74-K0X"HV"-^HCUL
MM@J&"=*V"I1$BB4Q1)+(3J`&K7A!O?ITZWP7'Q`M'64ZYA .LL;,.\F5K&
M1[=0%\^AZ#;ZXLG(^?\`RLXJ22KRCBBF,[UN2EJ&4E`5(9@"=[_`,S?$Y-6
M\+4QCI*6LE69]($@E#DOT%]B`!8&V_WP);(F=-WEO1NU\P03O\`2)\5,9K
MGN0OGS0)-,9T13(+*N@`V))\[WZ@]$4S9#72?-5-?$U+'3[3E`6A-VL"#
MN?%M7ZGRZ6QF1CJ%6`Y+':+6]00-7B4$7]6!-_/$/55]=!FZYA6F'B)M!
M4E!86)'XNI(NIQ!949!N@!:^&6@=W/OX75Z29XN13.(QB$=-(4=C$;N2%
MM=5%SM8^FWOB*ASJ+3U65Y4EY:CQ3NU]19@2!Z+U&_EZ6Q;M3F*-2S9]1!1
M5GNUDB"6$@&GJ2+%NM[6O;"8\]KZC+Y-=1-W"%W$%E_'Y"]R;`-]/RN(#+VO
MS]4U[J+``?L*OSAG.GRNBJI)JD!G0P4TEF$4AN#XF/B%E`%SO=3A=75P
MYKEYCABFC%*I#+X/W3A022.A.W2_EMBS,MFFE[N5*P*07E`"@B)B0+-MOU\K
MC88)BSI*82+,QIZMK?ADU*R`$GIMU_SWPG*X6Y]T51K,A.7?Z#7W1QS3+Z2
MT!K9&*S"61;G2P!4BR6%A]+D[]SS,9\SI6$\YAB_ZN@L8P&U;&Q&X`]/^
M^(&D^:J)U7/9%EJ=*NBK=0JV`MZ;'U\(K99\QD2""F28E990ZGO"?PK93
&P)U("H(
M\CYG`E,ISJ@7,!5RR/'*R&%NC@(:1M]!8VO;WPYFT4%:M-+4&.`P*?Q^(
MJ]@00`;;FUCY$]1B'HLV2+,!-'5J\3AGEF9!J*J2"%'\)Z]-^GTQ':R\55&
^L+741S""&CB9%D
M,B,:82%-+;[MIZDW&U[6.):2DR28SU,58:BI23QA@`EMB"#8DW!ZN(_Y&IH
M:#]M4M2LB53D"5P5[L;6("C:UB=A;I?&4VQI914AUXF3ISP7&W_$"4Z.$5
MEGA9QDBF985`"L2Q`(^GZ6QS7QTC_P`1;34\7/+)FIH'2/Y2,1R2'4:&)8
MHZ;XYN8[G88C9S1XK08H@XAT#F%['LQ[&W2$Y1H)*R*-NC2*#^/H#^'9E,
MF6]F'A3+K#0"7+F9U=AH8"]VOZD#_QCY_*4VJHR?*0?SQ]!WPV:N.J[+_!Q
MJLO;5%1V,TDH76-R-/L+W\^O3UY7I,XM;3M(O]%M=CL:_%$$Q99LHZZID@BH
MZ#+GDAEGF`(!@#8];['%R=UFV:K%F--$A--&0W[L@$V\/0=0`UB/^V',
MD6:*2"L$TA1?"O=A@!UU6\SMY^OMB6JLPR^HK_GLNED2+2H: %7(%RNDZ@/1
MB?7ICCR7$`Y5U0IL_I=ISYH&A2:J:4=ZZZ7E98MXEN;;]-C]C?$K34V8R
)ZWM M8?7!5
M+Q`\IJ::22O&P:&H`_%M^$#RM?\AA@HNF3Q2@\-(:+SH?*ZI8ZV!5A1VBD
MCJ5,QN+L+;C?R&W3V]%Y=49I/&T:S"%I^ZA5HO$$V!-_7XOZ85)":NLBI
M8YG?3"KQ$^))5OG4/3^5O3$AE]/5Q)WD)/?VTO+H)5%((!!_P"ZYOA]&@XD
M,!1/+7#.[CI%O7W2Y8ZZ.FGJ%)BF?NV#1@-&0P-KW_VZX*-+5S.#E%-`\4
M%FJ'47UCK:P\[6_/$C294TL+-+%&S*ZMK5KL;@W8[77KOZ6]L1&9SP95*J3
M,FU%&L@TE]-[@^8\OMBR*;:8@[N?55\Q+;^/#[[T1'GC45X:^-#70II@
MTDJ3)KUGAV%OIA=#6'+LVEBI8S(7CUP2F4%]-F_"/,6M@2C6BTV9-"ZZG
MGL8]+.239;V):Q/Y88@IH&2&IHJ,BZN57*@#J1N"-[=??!/T3E-_U2J;7R
MZ1;?W\.84[%FU-63]_099'-F=O\`F7=V.FP;86Z"VP/J!ZX9B:353J\55/))
M,BIWB*%`V!Z]"+]?OB+%3639N59CF=")#W.Q%]C?8;7]/(XE9II*JFI\P
!3WMAFFFGIO\`LGS+4U58S BG^6I88R%EF
ME`E9S8MI!/4W&V_3#IBGCC:-)Y)^[(CK;E;*VWAZVV%_J;8%=6G4?/TPED2
M-9(F9R+@C=K6Z^WG:V'*2OD:KRIOF97^6=I)2RH!?\`A3T/^HP#HIN2A3-5
M@&DGVW!&1T^8&&-:IWJ9-9=]*J=,5@1:W1C;?ITWQ'23M#F=+F!JGA228NRJ
MNH,X(!_"-O"!]K`],$T5:U*(JJ..1%CN"@E&[$D;VZV&USU/Z(H,FS*:KEF
2IF-Y%`N01
M77I?\6^^*5=?E-%EBTT1(B1T1^[`/[HW`V&W7VWWP-E=1319S\O6M,E0\:E
M3+NA;IL2=MON/OA=2DHDHZ/O*21V"G5:P_$&)ZFUO?`Y:@`1'%.'5M6R
M2/7WWHBGCJJ2(4M/)%(KO-)5-(#8`[@C5N;7W^OWP[3O+F=%'"M0Y$5N]L;Z
M@/("^XVO_08'XE#95E,^=TV7/(XIN[=!)_US=2?/#3UZXMSAK/.)N)\QBK#
MD4U+!"2E3(-U!864F_GML))070F2#4;"NG*\_IWK)Y:BBU04UH@XEK$&S
M6\MQ[_H/UN;J8S'12SIWZFS"3=B!U/0C:^Q_P!!PTF89?3B..JB-DL7=`
MQ.P/F/6_3T.V"2K?O960QA;2=V]B"?._I;R^OGMA%0YUQA6*5)TB(.J3+
MG%9\O3-'&R*:@!6%@JJ0+DWZL3?^F'AG6;*2]71NQ6(RFN"2";CKY6VPDY
M5D8Y:RBI!:,`-3.A`T@?B!\[WM:W7?"7RE(:=9HYY!$!JB1&V`(L!?SZD_
MV)+Y%A!2V4Q4D38'F/KZH9JV*N[UKRP%%!`S`,-0N?XNHN*C:@IZ*.(T0
*5
ML4D;M!+O)HN3&1:_MO;WPAS\@OZ)[J1$#3ZGUY\T1(TDS6?N*Q`%LLAC8Z;
M;FX!'2XW]=L#T=!'4U(KZJ"0ATD#1B9K[`$,ATC;W\\4DASD*Q%(A-"J_
M,01@!5/DE^F_K]L$T%0Z=[5BJF#/#IFF8DA?$%V'N#N,#+ABV[]5#6&`T;
MOG]?HH23.Z"LA:C6G.OO0HA==GDN"=]]/^V%U7#M/Q932C-(TE-*&8:BI*R*
MI):W0@$V!_3$K5RY70JKQSM&FLHRO%?NR=(ZGXZ[=06MQCS@X1Y9-51Y
MSF5!1J!9.\(9CT-QU%_OY887.J6:-]N*7F:0YQ=`UO;G:O+(4RP20.P,R
MOJ$/RXUN3X221MMN?OTQC/C#B[AG*1-4YOR^?*1M8QP@!G+;%M]S_0#&+N:
M?Q3^'^%2VX;R&:NCI&#68W$CV`'A/O;;IC7SC#XAO-SFCQ9^TJ*C^0A$C)^
MSHX5T@&]SL/0XW$V'C:U09FD#O/LN9Q7239N':KI=W3S"RCQ1VFM;/:B"
M;AD4!B![B`QV+#8J=S^$V&,\-Y76\U.+#-7Y5+5FKD!BIH[@*=77S%A_7#W
M)7DGS-[2_$:YS67I8R?W]15"UD!L`/[\L;LHS5D_+6!(*"*&PQ+JJI$&J
M75YCV\['%O$BAL]T4[NBZJ8*EB]J,S5+,!LH3D[RQX%IN&LMGI^$H*2I@IU$
M;LFF\BBS-_[CY7QDR.*6NC@GJ.\:*6'NUL-XFT_A'IN+_?$]E7!-&Y-)/)W+
MQTZN6,0T647:UK6._P"N#$X=DK9M,2*WS*6C?N"HC`-P0!OQZ^^-$X5:O:.
:Y5=Q?5;7ZFXL0/J2E7P]055
M7EV6F'O7D$S/`VNG6/458=!?TVZ7\QC&T@P@MTX\$EQS=DB^A/&/U[_`%5N
MR9'1TT24]0T`#HK&J:3;6+@J;]!MO:_EB+HLMGS"18IT6!K-=[6]+6_AZ%
MAMOB\Z7A6*H,4684ZJLC/332%=$2G8DW)-_QO3#XR')7,8IP)&O21DK?:
MX/UV'VPX4Q3):3-D#H)S1ZFG.]6O3C*#&:"FR4RP1MK*B7QDZB?8&Q/3T][
5+D]8*4R24D=2]4)(T"`'0I-MS
ML$3)U($55*L(0:@VHVFVL`P\O"/7K^@L)9)E"]A)RL$1Q^BM_+J#B&KD7
M,(7"12:9&[L`+MNHMMZW%]MM\"5=75BGMB603H\3!$Z;A0`6Z6-_[Z7A4\
M(T54R1UN93Q+/`S`Q@@KIV(*CT(Z^F^+8K\O6BAIZ&NE^:T-?NF$MM6/W/
MUVO@26@:;DP%^XW)WZ?NA*7AJHRDU%4X1BY0)WC#3EKGZ6]/7Z88J.&*HYA
?48AK1@S=V"+`K8VZ#`,9RIX
MS-F196LI)`!N=B;G^FD==L,94.0PL?3:^IE=;C;BG4HYIJ_P"6 ES%GO&J@
MPJ#&Y4`__EAVFS+,MJ32UDLNEP\9!#L@&UPOEUW\]\$4E1-\Y#6+1//"
MH-R'_`02!T\P`.GK[X,FRP3K`/ERS3,&:0(2%)W(%O6P'U(P)+F#G5-;386S
M!![YX(WA7/JHZB2"OE97B2TTIL#'UV)%]B-KB_7\CLJXBRB:`TV8M)&TZ`)
MH`;3?JUSOT%\-9#P80CA*GNG:0-/3@FX4+DM:U]Q^8]L('#)K.(YZ$Y=IZ
MR?,NY&G:X0'WU6L/3!-XF3?F$+*;!,'O\.[7[J6R[AC**3-US'+9=2%"R@N
?3U'T&$04=32VEJ-=2!'
M'00J+;7.^UOQ6WVP_)F@BRXJV7IWPDU0D*658V%[$DV.][?7#'-=:][7[D
M-4$"=]O'NU3\U%DR9:^NJ*IGLD3AG%S;5X1Y^FY]3AKYFINMKYXIN^BC,(
M#L`ZBY75;H+W^NX\CAN',!1Q"HJZ17'/'$-BH(WNU_.UCTP)69O2UE/IGD2
MG0MW,[Q6=[?AMYKN?7WPV"223S]$J149+1,[^'?Y*X9\BE5D,$*QR)JC:%
M21LP)Z[#8!?KAK+ZNBIGCCA@(RR-II7L`ZW:^GK8?7R&(3)JK*HZ.*CS6-
M4U:^X+;.-BV_0W-SOZX:J)?WR9K++&5@A[M6CDL5:2]P;C?_P`AC&LS1//Z
MK&"FT21)._NYNKCJL],5*^89;4LBG1'%#*Y8#2=RN_0'S\R,#TM?29C22&NB
M[UQ*)*P,!W@W)!%[=0#;UP)-`L7=K6HYJIXSW9V52Q74%`Z"^X^N`,BNRY
MH5_9$/)K*HLQU*!WLU^MO([DG:UAK,@)"4UH\'O'[J:SW,$6&5JJD*($T
MZH[(0M_3U\CMMUP.E729@:;/9)EI^[+1:%U(@-AYFYW`WWZ8IG-17YY20O%
($;I*;;VZW^A(%][^^($ALGY
MI;@2^(FXX\V4BLN6Y=E,=+2R*\D1C$M[@V/X?7:WZ'VPJ7-/%H:9)#W9CB
=\\H=Z"GABA
MO&!#,"+ITW"[7]WQ-G&R74=_+!T_='9?65,].E-+!4Z8P+ON2IOT-K;"UK7
MW&!Y_P!LR9BKI.L\4`W22\B_D/H!UP3DKTE7)\Q+731-"DD1IT:UV_%JV];
MD?SQ2OI*FHC^;II52&1],\,[,.]'34+=.GT\(]"T`.^Z9#`\7]-_KS*8J)8
MILZ_:-)4`JTHB0,"58W-@HN;6ZDG_+B4ESG,EK:F2F$KRR?BG[A661B"`5L
M;BY/IZ8CZRDJ(J2E-,-,DU.R1R1!"LC!;FY'F=)-_488;,Q1F`&%GCJ%C1GT
"$_B;1
M*%-_,`GZ8BUXDXM2H:IJXHOEGDC8".0"12%.^W7?^QB1G2.222EIJ 1W=E9(
M6-[(5O?F]NO0[7PQ!0S5JK+`@C[JFO'%$-18W'X=M]@18[[6P8!;NYYT6-Z
MI[)9Y^7DI'*JF?,*O244AKNTI&]K^$#UZ7_LX:SZMSBC6/\`8-="[S3LSF2"
MP5?,W\K`6'],#4-?)7SR4,T:I2LSB.&*X=5`;?T7V\NN$4V914F7)%F,\M0J
M3GPF(E7:QTV8#;KU-NAP3&%I!(T\^*2:8!S;K\ZIBISO,4)FFI0Z"?O(H5#
M7!-R&6]QY7\MQ@NNJ:"3)D@ILR=:B1%8ZP+V):QW((VM[6P+73UU5(*JG0L
MM-&S(%;2P%P1['5L2;M\6PQK\NRK1203S(]22KI%8`;D[7VN?Y^^)-%[VR
)357U]E]6LAID0
MGN0H%C:XW)!V\7GTML?*U.%:QFS(9AF3.)(I"KP+&"+,+CIN3 OWL+`8F)*.
MCR/)*NLR,I$DE0PFDC748UN27:]]V))/2^HX6*;G/[U#GMJ`L:/6PNY)I
MUKXLNG+2/((D8TT0.Y7Q$@,HV!OZG6V"JJNIZG*H$21F@C*EWG;\*WU:K7-
(A)':&H$[H#?I[CRO]L/"B$V255+$HD[J/=A(E[$:
M@5\[@[C^Q@NS$:$I+\C6WT%^[5%I35"(D7SR!%8RK%$HO*H!LH;K:WF1ZX*H
MN():V.6B9I##(FTA`+*1O?2;;BP_TQ$M3R4+155W9*149%=U #*IVW/4CKL
M.35M=3R&K_9TJ1M.#5(K=&/\*7L0+`7\1VP+6EYY^7'Q1/RHUI%XW\#W*
M)I:ZEIIYJ".A*B(9)7`)"]23U8[^UK8-X9JJ5FGK\QF:8EFACCGTKX0#
MW]A["YQ'993M69U`_P`XD:1J6T&'_P"D/%OON;[';R&"/E)X_[]93&)3^YI
MF&TR@"QO_#X=_/=\-;E)&FW/V6.$M#P()4P$HRQ4;2J5:Z=T6"^(78:
M@=[@"QZX]0T]4[145?4%TJOWE/.@MI/DMR?0GSZC`;Y=FJ=UE^59N*."SJ(
M[J5N+[^9#7W]!A%9Q!F-9$N54TBE(K*LK@Q[J+FVW3F`;^2V@]?HA:W--^
M^)YGR0O%.5*9KSPQ2Q5,DX,K6+!;#H2OEOQ^^+?GJJAR U::KJ)%1W6;
M@@[`7)!W'G_`/=@W,I,PKJ2:JJYU:9GU4YAHDA%M2BVY-[$@^U^F(6KDIL
MPJZ7O,FEM8&258AT8C;':XMO;IA[02)O")F5K@(F.?T2ZFKI1E4N505$`[
MLB64S$@#\5MQN3_K@@9UELM7%-2,&B*-)B8](+,0"?!U%CUZ[X:K,RHI:6I
MILZR=DB6\P46U@#H=SM8[8MZGKVBH_F\MJ?$J:PSH"0H!*MU%NC;^OWQ@:
MY[26A9F8P@N'[\GO\UU)Q@@;*4AE#I5%5=W!C4%0;D7Z6&PZ]25-GD3I/
MDD@C,EI!42==`-NES876VKWQ9%%GL\V=Q]W+(]14QL96T'3$`;^(?2]_*YQ
M(U5^7115-=E]0T2AHZ55_%^P(VW.]MOS.(+'.(`A,=4I.;,&3/ESZJ\
M%XADS5&'SE(D\12*)&4$(ICL?$W\O/;$=/G62K*TYBF,,H2H3N@1'L0-FM
M8-8GV'6QQ`35=;-23YS'1:/FYPJ.'!*7'XKWZ7WM8'UQ6:3,:.6*EK6GE,TQ
=F:TVGZ^ZRNO):B.:C CJLJT2O'J,P
M:0#4@46TKP(8@^XV\L#O4TKUD0HJR%9Q&':H"+8ZKDCS`)/D1,N=+#630B
MGC1(9AWLD2`D*PWOTN1N.AZ^#*7/J9YY(XN@1HXUDF=F-I-*G20IO8V.]]
MM\0X2"8YA1EJ9YD=PX7/MR$NMRV;(%2"BK7J*H5(:%9%NK7(U'^72X^OK@A
MGFFTI5YA*6GJU766TA;6)(Z[7ON?(8]D^8N:5JJHHZBL,U1I"&4!XB/#X&'D
M1YV\L-5PJ*R.6)Z1K_TZB8%3NVI38`D68#I;$ATOD]UT?5MBT_3Z;U,4F
MS39+F.6UN8TU2TJZC'"2'(L;D-:]]^AZ??`N5TM.)X_DRC1P`Z8II]0;8FV]
MS&_E[XM%,Y&29U#!4F\I5EB,)*@*PTBY\^IZ7]\2]?F==0YHN0N@4*H-+$
'?,P6[
3M035TAD,J:
08R&Q(',
M(0!2"XS.GWB;UT3/1"D@*IHIJ!HW`518R'7/GY[?TP+7\/0YI50YI%
M4]_I(B8/=+7/0+U(%_IMAIFI,XIUHDDB@I(XRTC,6"N0W0`B]]]O/;$IF689
M;04;U5%/3NL$(:`=T%V'2]A"VP(MN+]`&-%XM^B)K\M4`\=./V*A.(,JR8
MS5WS%%)*\$XT&Y"SC3X;V!L.MO;$'FF3A)CW=?W,$Q;7%%I$ AL22QMO:UA;
MSWQ+T?T=!3P+4+#(VIOFZJ*Y+KIU;D]=RN]\%9Q7.3O'WT:R*:R.:@))
MON`3M;\K]ML$3V8W\4X,8UP=9Y_56K6SU660&AD=8W,()U0?BC!VL1?2 2
M#8GV&%S5-?\`LR/*Z.DCCGJHKU$Y-C:^S7%B=MB![^'YN)'JT2%I%"OJ(!
M2Y`M8`7`WVM?SVQ%UO&L5%0)1Q49^8*!3-(`I*$"P'6Y(M;?;;`B@XML(GF$
MP56_UGAZ7]$6*VCHC#DC5.X"O"7E32URU[7()L20+B^V&5S96ITI,O@[Z+YR
MW=&/O5+`$ZP3L;'S^@Q#YOQ%29(\D&5H)08695=M=CXF538BQO?\[VQ&4W&6
M:Y3E=Z:'_J%VC5!9BQL"!N-O49%\`:536;\_9*;5H.HY8MZZ\ZV5Q9AG]!F
\%'W3PLX%1"+)'6M[@[&
MV+%R_,'JLR?YEOG(M[.`I:YL&O?:VPMT]\+/&68TQ^0/?2100:7,8"G1YO
/1RD
-@W
MYQ-5S_L0I.1'$3`K26D0CWZD^_MUQ"09Q)6QS9;F^5Q2B22THD0, C7(TDB^
MWE?Z8QHVS[CW6N?2I.:7,)#N?T5HH/B=\I./J(-39L^75\)*I%71`.7L"
M;EM]_P",WY1Q.W&15-3%F??0S`2TS0JI(4J"%U7&PL#L;;[XTBY_=ECE9S
M(SA,WR;*EH\RC8/)+E"Z&TWV/EOD'Z8L6#C/M8=F^,Y3EN:5F=Y)"R2Z3*_
MHH%@O7PMWN,,%"2#3,=Q^A55N,K4;51F'$?4+HM1YC4T\` I*V&3YDSY
MPVE7%AU!V))OL!L?/$E4U%/4B58HX#^["O4*"`MC?`+?;J?;WQI?RL^(IP[
MS"8TO%.??L_,*5QWD-==-3@6L-1VZ#?S.-ALDS;-.+X$K,@SE9(&C$SD5%T
MLNH[=-K_`'L('L,.$7YU6RH8NC587,,]W-U?&6O29?ET21Y^[]ZG@LXD#L
MQ%K`D:`0/05^F'JKB.9YQ!"2JI$K,L37,C$G2/M[^+(BR#,Z&D:LAJWE9
M:QY)8T5@%(:ZFW2QW\_/`R9I-\_%F5/4-WE++WDKJUD#-;K;H-@1]L0`QVO%
M$YX!+FS]95^YMQ9)6++7/0VC0KWD_68$[V())(%K`^OD0,',#+4GA^8S8J
MM0"L8BNS*-76YWLGL`,0=5Q/GF:T5J2I4=VY,?V\;6-CX=AOOYWOO?$%\M
MF,='\],S1R2=4D'AW&Y!'0@@;#V^F)T=`&[BDU'QV0=?;GF(5ZYCQSE,T[5
M=2TJPJ$[I+-N"+#Q6VO=K#SQ;]-QMK9*$4$H42=TIZN[]3Y]!N;_0X@J"@_
U
MQY;^6,&28(4.?6+29GAS//%7E74UE+)'#%&C3H5(;O0EQ$EM(\5K`(ZI
MKYJC/,S@8Z9*,+(K(M
M['78$&_E;?S\^D77;,1TTC-GVG6V\-5L@!(8,OE_*^,#6#M#]%'656C*=
M3SX+E)\?GB9^(^?F0M&EHXLJ"L-=]+[ZE.^QO?&@.-[OCMSY'/V@J2T2:
MPK\\DXG['_"IK*=V2EC:$,(P;+MX_P#\K3C@%CK]\"?M395FG+-^1F:,@K('
M;Y-IY;7(6Y`)Z&P!QS726D7X9CP-"KNSJK*6,!8FWFNDCYA)+5O5R('FB(6
M*&(,NE;`$@=#O?ZX+HZ$Z!Y%4KJ"W(";AA=3T-@1WTQ;(CG[Z:KJIV9I%!
MC+V`4_47Z#[DXGLN=LP=(Y9M9FGD0C0P'78_KZ8Y`TVL9*ZH5#4J1(XCGQ
"+SWW^
MM@\C2)$JL(&5SA/ASSW)[*LXBCJDBK:N0-32*TE2+#5TWZ+:UP'1YM'6&
MIJ*`P%)P#:6R^$FX%B=O.V()N(^'F.J$*)8R2BZ1N"+%6/3:^UO?!N=Y3F
ME$R95(23$6D*?Q.I]_3K@F$!MQ;B79P7/OX#U4LV?2UE9-4O621-,RB4*#
M9A?;?R]+8&CSNCFK%J7E@EJ&GWBDB+&^V]]CO\`D0K5JR9*6=HS5$VD87
M`8;:3N=NOZ83/44HH&_=D1]X\E632PV&POOUV_\8,'^W03SWI#R\B-_T\%,
MT#P5%@KYM$S.+1J#;8W(V]B/R]\3^3ULM/%+2P0R/0DTQ@TZB&L38D[`?T
M.WG;42Q4^3")Z59(C(#%.)"'0VTVN?*XN1Y[8=WAK/VE3@R?O`K6[MMO
#M8V"AAON?+?H,-&
M:JA^;C@%(K2!74DMWH4LQ)!WOX^^&II_VC/,'HM:RPAR80R%SL=C?UQM
MY@8K5T[M-)(BNKS68@$DL6V/B'0[7&"!+G'A:G])`-MWU3E54-15T6MS(
M&[MDU1W06&J^_0?3I88D94BSEC%#''WKNJD#2QZ_]UK=+^7Y1N8S55)5Q
MUU=3/*DB#O%$8\)4^+[GH!M^G7$G"CG6L$9IV(:G"L=186;5?IIW/ZX6V&
M@$VX\\RC`'WCN@:\PI.@RVAAZU)73L8X]U8C`,;6W%S[C#L=55YE6=U+4
M14KW'[T&[MU\/OW7K;$5!FT4^8F*2(0#NQ%K0ZE`OL"#Y]-Q_KAN2/,GIQ
M-24K2,DMU663HEP//Z`_4#$B2;$H@`!)(\?)2M+60S5-344D+)'*0)(HPS
M*"#N6(L;@WVP!+6U&6TT67YCF??!_&12W:XW4"QWO;6]\4R_+LW%9)F+U#(
M'5U12-":6W!_4_6U\(6IR:M2G6ZP5#,SRJX)=[5]R+@]-K875#2X9G^:-
MP+8R08Y'/LGI98C0K^ZFK&`8&4BX)`6]^I\_K]-9?Q#3Y*G?Q92^BIMWB%
M;Z+$#H/PP/E]5)7`JSNXB`55E8DR0TKMO_`"MYX9S$R":GK:Z,NLC'N0?
M%$UKZ;?8[$^^%/,'+'[email protected];^'-E)X^R)ZI*8Y@9IBTK3-8!P3L/3
MH?\`\+"OF,IS-5I4$%J@E)46/38@DA@!O;?D??%N%89O&T$LLJ"0R.@NH
M]+$[C!YIZF2L:L$Q26&%6,QM^[!`VN=@+D_6^$U*")YWI@AM2SAY`ZH^A
MKJ*5&@DE5R(R!4,`@55%KV)-P0/KNRRN!G1*(QP1A2NC4A#KOJ`/KT(/OB
M.K*)ZK+R22PRR68!G!9QZ`]`![6],%1=YEM*0E-$8WO'`H;Q!@6-[[6-P`
M/3"S2&2V^W(3C68;A42GIJ*26:EB$AFEYV:Y*[:0NU[[6^^&*.KR[+\N,BQ
%O*YV'MZ 8;DS3*I"M0U
M")U@IPK#7I9O#;5YWM?_`,8PTVS#9*8SVD[CW3I=/^SY8JB!657BD$TJ-&
M%)MT&_4VZG_3%O8\W.%N%(9,PSKB"EBI(X%D*M9;V)8"P)V-_Y8PYVR^V=E
MW`&52Y/P]2&+,IY"IO)XD`%CV\C:V-#LPYB\Q^;/''[.S'-YI7J6*O.\Q4?
M]IMZ6-WL_8C\8WK:ARM]9/N9VKTCIX&IU36AS_`$A;.^/BA_L_.*JDX1R
&^X!ZB_7
X:%
M0`H:LLCNJ7-P`3Z@8Z08/"[-H![&`)O^D^2YQ^)Q^T1U=9]CH`+#P`U6"
M!^Q-SJXJJX1G%++/%FDZ.(=)1:*]P6][1WQNIRI^'URGX'AAJYRL5L\S
M1B,,/"22`P)V]/M]L;`9-298N62I64**]-'XWC06:6_\5MBHV%[WW]L&J\%&
M\;5M7%')&@9HCL[[=`;;?8?UQSN,VQB*YR-[+1K&_P`_LNBV5T=PF'&8=IQ&
M\:'FHOA?@C@S@S)HER3)#&W%T1(0A4BXL;[$"V+DDK*"DHS))1`-2TRM3
M,SB^D6`&D"Q-[=#Z^F]&EIC'3]U7J6=RL5)L"!JN68^:GUMO?`L=#1QM(PI&
MIWA?3('FLMS77UW`_\`P:8BHZI(\^?9;\,8*0`,),TBRO JIHV:PF6+
M4L;$]-NA!OY]`1B4I$JZFG2KIJN'1&3))'*2-3$?PMU'0;=!@FJ:CR_P#9
M\*M)*CLX$[%[!U*;&]KD6/K8^6%4@32D57,D70Z8U#7"@7)LI-R/[\\-R$
MW%AS"![3482")W3P\$)6Y@5B:"LG"@E6K(`5-U8C2@-Q[BYPK(F-!2"N@C00
MVTO#IZ6Z=;^5_P`\-UW[-I,V[RJHP::7P2%C8-8[$#^'S/Y^APP^?9#EO=LD
M:LLA6,OKL;"_I?UMY8BHTDWGR4T7.`EYF;/VNB8\QI\WDF66,I)!,5B=B
M""KIM[&V_D!TP\\$T-5%254*]Z(_&C!Q(K'8DITM;;KTP'!GV5-Q&E!)E`
M8U([N1-8L6ZAB;;[C?T^^#12U4N:SE981(LFG2S,5F'^6Y^AMO[;8EV9QTFW
M%)/5T23,&9TU52*-06J1''4.%2.1&)4;@`6\A[HPQ459HX)I36F-5F5:!6
M9?$;,=MP`,;NYYY**17[N!E%1#/$2$(;E^F'5S.@K:6:*942*F4$E4%I/
M(BPZD?T.V,IB1(/J_U5A[BXEI/#TY]BDU]+49C'#EM&TTG=6GDTFR(`-[
M^]A86Q:8"&B:.NJ*$U+FJ$2V0WO8`&X]06QL:,],\U%%I93&(8X2&N`/J+
M#_88C:^DJZ:.5JNIDBI^[+NQ/1F'3:^]KNV"8&FIW&[D*NXU&TP`0=-.*A
\]_7!U)
M0&/,H131"6-J?2')\191^`!A8&WEMT/IAWAVHHZJKAJ)IJ9"JAF2Y(U'UAT
M_O;!-(#9.Y.7OK6/WYW)N*#,LCIXX4HU3OY"]/'%'L]]B5-[=`2=NH&)"'N
M,HB--F#2,J;U;H@5XV#77;_-[=#;$O1Q?OHX,[=S'%,S4K-)J1`UAIO8;?Z8
MAWR^2:?]FE#/*K`R*""-R0+6Z@=;8)@;4F0E.?68D`F;\]Z;ESF*BDAJJ5
MJEXIV4R",6&Y87(]R!?VQ)U]:NJ*CJ1$[[L"H``4B]_P`C][X"SREJ\MHI
$F_:-N[`L#]!ZM\&`TQ'//
MA&:#F,]\'#W4[\K3/E8J(W*B5[Q2%"&8@`!1OOO?;RWQ%3YE-19BF6!!&
M]Y(IDVVL+6O?K?GTPSE$)2CGFBKS([SA@IJ@MU(\MO7V\\3=7DF55,J5E!
MXJZJYCD\:M;H%(MU)U6_7$M-,GGR4&3:9,7UX75NUM-65$E+4L]-'4DR11
M%R3L;L;$A\L#UE%%#+'&9IET*IB@DD`VOZ(6+HJ:22F@ JXVHC+)W37J
MT\VN+K:X(-F)V]-\"R\,M%-$D=(U342QD4\\DUBKBQ06Z,?%[7_7##48U\.2
MV-6-#$V(04E7^R\L2B?OFBC(61FLS+O?WV^OOANNX@KLSJ:&FH\M _!"NI
MA&`TW7;W%P"?4_GB?.3TLE/'!73S/4+(#52QP6**H&]P2/*VG;IBWZ/)$AS2
M M-2EG-S8KMUMS?%:C-J^H$R*S-3KW;NR=WK%K[;7Z7ZX&HTKMS0453)33
M1TS@:A&!WAU7!V\^A/N,$15%1\T8,Q?O*@@B,(;=WN2U_KYCIO?&`AK[:
M9O"-+4Y05$V:J(Y'2GEGET]P8B+`7`)/OL?N?;":=H$JTBDK$,$T2&2H1B6
MCTL;#;?3KL.N///\O5F:2B[UW"N9%9OW3D"_EMYC`M#F$75@.;TQCG:0)"
MH32NH"UR;C;H!]?/#65!FCCSO"4ZG#`[.;??]T=EF93311K55$T$DG[E8
#]_?$9F:9=\U'++3S'
\2\4W5+WU
MYY"20'-'=W:^*D:GB2L%:M7\W%%!*[)&XCOK+-8C2+;7WO]-L3U%GZT)@J)
MJ68(NE&EELNE002UAL=]OIBT@J*1JN&89&KF.`Z"YU#0;6;^U_P"6)*1
``&4(=AOZ^@]?L1:"X`""%#II$R"ICS*J$:44TM,
MT0[HP%`%0&P^GB6Q^N%SF@KB\!6GF22TLI0;'?58[$`C_7$!E-=W!:*GF4
MI$KW:_FX6VWIUOH/7$C5PU'?\`_+Y/)%JBU.TH4B0$D%;$W4V!\_*QP1#6
M`@"X27TNM`X]D_+DHC*.*LIIG[FII'[U(2::1-3#25-^IM?8`8$XJJ^ICB
M5(UI'KI6)'#.L8#&PWZ&U][CZ;8JU/&'7;NC&LD:!56'086)4_B.YM?8;7
MMANLR";OY(WSY`BE"2YML9#Z`@G\[8#."8OSN\+_L@=0R@P[TT]/7DH^\
M4TO9Z=^@6=EJ!(K-^H=+#8X+HZH(*:/YB&=BKQJ8V("GJ0UCL;%B!Y
M$C\@0V8LVJ%!-64Y14@2$/\0ULOGN03^N(V7,V7+T&=4G21W[U(HS&?$0
M+':QW]]KX"]N=R+MEH)(\]=%(I!EXJ9*GO9!3Z%P,]A9QUB=]_%]=NF(
MFFS&DS+-ZW+:%M,2C0.H1EZ#:VU[=-O/!-#24&83&.NCDI5&Z(%/B)(V!_B
MZ@]=L)S+)ZC804%I'?P21_NUC*K^%F\O6_OA['!T`:PE!\L+COCOX3R$D
M4-"\\%;5YD,;R*OT\-C&0E]0)&_0W-S^(CRP!6YE#E6:3Y=/G1EIW,B2+"
,AB8!"[`M8*UR?ZCD8"3ARGR
M^%Z#,JZ5C63J]2YLY.K8$7VV-L&W,7CV]4D')3D.T[O?G[JE16451%20TT'
M_*2%D[]Y=6\[^'5?\`3RP33TF72@STL:M+(EDD8-JD'6Q(O8GU]SB.@H8\
MH[[N()8C1,\4CQ$;V8GH!_K@B&MI)88),KF=YHYBTB5#@![]+V)V%]_6PQ!
MT$`#G83&MR'M=KK,^F[75/9C65,M/^RJ=#HBTRHK,;R"^RFW7_V`Q(9
MXM?5Y$U95-3PR23M*"(M;-UFN-[[#;RM^4.*X4N=""4AV1`-4D0`5KD@6`O
M:O7Z8,KJ;-8JO]KT=,\\2+:570B-1N;"W0V\SY8PTG#+//,**9J9P9$'NU
M1,&74)HQF&65P-6'$?=J/^H6*L6`/3J;]F%Q)F%36FIKG=9WI8RKR"ZD]`!
M;H!N?7V]8Q5ED_Y[)A4TZPLP&IE!:07N+%?UOB2RJ:=S*TH8FD$?@(QLB
MVL=O(G;1P)80!K".H)9VGCNMY'YI^NJA32T4F83:BH96FB+ $%=@+`CVM][
M[X)ES[+LPJ(FF6)J19%#!U;O(0`390HW!\0-L#+FM349+\A))$A,TC1RN#=$
M-B5`-K-VZ^^$4-%+HIR\DB1U:@(W=%F&S&US:B+[#K;#7,I%]I-OFD%KVL
MN8@F_P"R,S/,DAB%3%1Q24T;:4"7[P,P`W4^("US]OIB"S%:C*XC3&L*PO:
MYFIU4R@@)@#YG?;I[X5Q#13P5$U/5?,FGBIIKM(A\*@#;?J;[7!'GA%#PWE
MVY?+5O((.]=4C4,68+?&QVZ'V_P!\%U.^Z-F(QPDB_#[\4BLFU3RTT^7
MQ-2M6VC0C=7))+6WVMYV$19?EE+6C,LNI:M&Z%X$A+1R*01IL `=[@@Y^
M^%9[DG#4.814'[GIY(8WLC1'3=@-3-N`2=A]NN"CIFKJ:&FEKI$[S2L;%
MU.QV53Z#4+^Q]=L&QKAI('MSP0&I`;4S`6T@SZ^1]%'9M54L(AAIZ44\M*V
MI88RI75LOY6W^V(3-N(,YBR^"6&1A3`:7C,08LMCM?H+$@_ETQDN14=TS
;P"8$!W"^0Z[D':PM;!
M"B"\2+:K#B'=0`'"YUX;Q"LRMSW+\]-#5TAE`8COXJ922Q\A;:P%^I]QUQ*4
-QYD7OZXN+_A?*LGS"KCRFE6P*NM%&B[[&ZM
M[:A]/6^'XN7R9C6-FL7[EWF*5$1D)10;=+VOON1OCKB#38)MYSS^R//-,9G
M18?3AXRK3"."6G,\X65+O*8UV?Q[`#T*D&V$1UO?1K#04BQQ$-WL1BO#S
M)(OT'3J;=,7K+P74REZO]GP3QQ2LIB6P:RG=AO;K8`N&,YH\O&8OD5'((9%
MO2!%-3+I4H#;58^7GZ@X7/G])1Q&*B0!UG;NU-V!N#9SUN+]0/+UZ8EXJGA;
M+*7OSG-/,(W,;5'*%D%[ZF&]C;'S]L0E,W"2U,E-/GL,T452RMW,H'%@+
MJ+`[D;6]K8!KFAQ!04R]C?S70N8\0T;U[5;Y;`9XK8%N+A;[WZBY)^W7$
MAF_$%'!219K&\8F2EN3W9U@C8'T`)/K_`*8:K\^X3BJE_9_$%&6G!CDC-*+*
-@*2'-8&E
MUE.TF??M2D?.WDC1`@CG#6U2;$@7`OTM:_F!]XA,Z9J:JRVB#2F;4*@["*
MXW!O?W%AYCVPQQ!Q;PP0::BAFGC+WD*D(`+%2HV_#;\MOOB) BYEY1##+E%3
MPO5&)FM*8T8!B#LO3Q7\5_MO@69=1I;R\O9/=71UZ"-.?93&:YU+4U,%,*
M&11=M8B@8!CL=STM8;[#!\?\35$E3#!DL2-,ZG6Q9K1D6!6^Y-_IBWFYG9Q
MD-+2563MT%D)2)XB"G06W&_B`OU_#B6@XWYJ2TAFRKE?4(\HB $4L8:ZKN
M==B;"XZFWG]\+J5'-,!LCC;4IN$APO]]X0^?YYFHSV+Y9HX$J6U2;%HPRD$
MEA[W]?+#,D7$T6;R9O5U($,Q.B'39&4BP*CZW^E\1SYIVCZQ8X'X"IZ 9)/#W
M50AL8B18@[]0HWM[CKBXZO+NV8UD8J\C2GIDB354)'=EWLH!/0;_IB7M`.
MS9"*G9L[BH8Y?3U=33_LVCD%1#82]YD;7L%/].MOX(FR?-]5-1S,PEE8EI
M`3;N['3VY(]/;$E)R_X[9`]'+3IF+PVDE"WCLQ`4J?X6!.][?ZM/RUYS29H
M\A;Y2%:=9)-(4@E5`N1N;$[^5\&&N?/#O2"]I),D^'/LH/B'(:VJJ8FI8Y5
MK`X682(-5E&Q:]K@@$_?`\6U\V5FEILOC'=N7#M8L&`(OL"!UM?W]\7+4\/
MR(ZWYC,.((FBJM`U11Z2+(;JHOY#?VL?I@K+4.=U;&OAXQC EU1_CT,`UP&
M`V(\A[[X4UCV``CPO[JV3`EQTUX^$JQZ/),P::KS"@@@1$C4Z020#I:]_3
M;W_/!F9\+4\5+)'&XHTC[M9*C5IWMZ@_AVMU],33=GB?,9XJZ3CJKTT98#N
M6LIZJER;W`)OB-SSLMY?F5-596W'-88*P+&T*6NF]CI\6^V^_3!ECFF;::3S
M$LNTW,B=X.F[P5FYM%P#5Y]/,F?45$T$G[JI60:S?R][W`Q&YCEG#XF9J_
MB=.ZZS+)("25%CLAM;SOTQ(Y-\//EIE6=5KR\R*S,[G#10U$_A(\P3U\C
MO:^&V[)_`^8,(LRH7]XXIXXJG6TR6`&_K:Y^V]L`.19&GH=V[6DZ";=R
M!I(.7M/2U%-%Q!25$EBNFFC4WC%B#?QZ^O3WQ:7$?,/D=1&;+VJ4=-)[P30
MVOV.D]+D[_G][\X![/7!O"N8O29!DS24\=0Z33U$MW0B]A8GK?K[8NRB[/O
M+K,LNCJ9^&8'26I[V"IJ8[/K)N0RL+A?(#Z8`T"8#N=Z93=5;8.'.X+4GF%V
M(^SQSLH*?/LOAFHJN7\,\*:&U$@@WVVW_(XU\YB\&]N/LN\4OD/*:MJ\\R.&
MIM3B4,39;C0-MQ;WQT\XIX2R&6DJ,NR?+8%2C:/NG^6`H#L!N;[;^MAB*K^
$:CQYE
M^LK^)]SNY/Y6M3SSY19G3R00")9XU-I/!IU&UK^1PUP3\83ASCROI$CX(G
MGK9)]4D31!6)(W'Z?K[8W:YBY7P#QD:O)N*#\LS&AF#)-3O``P=@2+[7O?8
M&W0]/747G-\,KEY69XO'O*#/(BS&`=\T,5EB;4"!UZ^6)IMP=P]L6M&BIX
MANTF,S4:N83H0)GGBLW\.\:\UN.C%-D'#D-!4Z4,QDMI1NND6VN;V-AYWP\_
M+_M!C/WAS#,J58Y$9^Z+"]B!VZD7VQJ=1:]LOLM9P8L\RJ;.LI$U,-R
MU@+D[7'0XO\`X/\`B$\&\?U+/\`$-^65TRK%W=4X5RP)&GR%[^?OAAH,;=
MC0_7]4#,:RI`K$M=WV^4!9MSWE!SJSC)ZA,NXAHJ*!8R=7?:264:@"` #??
MZXC.&NS!SC#)G=;S-,=.\+J["$M89WZ6/Z`?3`7#G-VLS#,*6DDXD,M(&#1
MHH!,IW(6]QYXO3AWF/6YC4*DL\;O&"JT\@\1)OOUO;?^%--06`GP^:NNI4J
MM4G-:.)CGK`I^QSQ::N;.^*N:M3/%K++%""AMY@F^W7?%P4G96Y?99F`KWX
MAJVE95-]`UE=F4WO'VOB^\YS[NLM$CR?]*E(JQ&H5M3*"G4]+#8CJ0,:S
M=MWMT\*]FOE+FDQSNG?/JF%HLJHE8EH59?QG;\74=?,W&V"`K5"`-3SI^J54
M90HTRXB?OW+F9\7W/^`\R[4E9E'+^8R47IW-PY*AAL;7][G&J.)KF%QKFO,
M3C+,.,YF=YZZI:1M;ZB`3L+_3$+CLL'1-##-8=51DFYWKV/8]CV+*QQO(
MWGIQMR%XTIN,^"Z\Q3P."5OLW^^^+*Q["ZM*G6IECQ(*@B5VW[%_Q9^67R
M++N'N8%5!DN0J(:BHGJ%6.1AT=KVM7%_6W2Y(VVH8W`K0 T.7\Q,LG:7
M72K#7QGQ&YM=6W!O_0X^9:FK*NBD$U)4O$PZ-&Q!_3%U.[.;?#0"Y%S"S6
MF%[_`+NJ/]U6Z.]N:3X'`J_0VC5HMAUU].%;F.92F,4-L(4*3(DBC4+;V
M%_IZX?HZYYA&TE5J"ZSW9?4)"2#_D-C],?-=3]L#M00RHT7/3B-3&H5+9BW
MA%NF#*/MI=JW+N[^1Y]\216-O!7D;GOU.*9Z/8H1%0ZOMVW1:8ZOY=WOH
M^EFCJWCF3N9&D*B6:$@E`!ON_3],$99#E@DC2BS:!DM"'[U1K+;;V-CM?
M]?.#+VUNU8C_\`QZXB&Y-UK;$$]@PQ0]LWM44-"]+2\](4C'B"BLZ'U%
@VW)\A8#R_3$O
MDZ93F%(UVIZF:GSI2U`?2G0MUWN?,G3]L+M14-.T='SVXDC60'O%3,6`
M:_6_KA2]L?M29-`ZY7SUXB@#V#=W7D7L;C&#H]B!_6/=#_&J9,93'BOI]IZ
M2EECART422B*.UXCI6X.H#?VV^V"!/D&6*B5M&(G/@%0TFA$)Z7)/H2"3CYD
M:;MY=L=(EC':,XHTK^$',";;W]/7",R[;_:WS*-H:[M`22HQ!97KMB1Y],2
MS856SB//[W;9HDSE/LOI['$V1TE&YRS.(9):,JL]I[=+D&X/E_+"X\SS/
M-Z"7):A)8`#WC20N"#?4;GVQ\NZ=M3M7+#+3+S[XC$=1(&G3YXVB]B=M
M\+C[;_:YHU[NC[0G$\*EB2L68E03]OI@?\/U0T@.%^"FGMNB!VV$QX2OJ`S
MG/FRV!(ZRM42=T$+_J+H'6P!ZW-\5RCBS7+HJ:OSGN62$*Z)-W;!0-PHV
M'47MTQ\LV:=K'M*YM5+-F?.[B.=EN1WN9.1^V`\G[2W/S(RQRCFSG5/JOJ[
MNL(O?#6]'Z@9&8A2QMQNG*;]X^R^J2HKJ9I:^JECE4%4BD%2KZ1T!ZW!O
MYO]L2E/7U72P1"HIC))'X(JE[KX2`"-_2U[X^51.UGVE-!C/.K/RM[Z36D
MB^)*D[9?:GCG6H3GMQ$'465_GC#$G8#S:1[HOXW3)NT^R^J#,:G/HX8\]K"
MDD"2ZDCI9AQVTD$]";W];X$K\UCJ(/F6A1`UGM-,%5%"D6.]K"Y/4?SQ\N%
&VYPE
M_1ZJ\#M"WBF,VY28YQ##?O"^I4\1JUC@K!*O=^"!JD:[:=3`7-[`CH0-NF!
M*%:;-,T^2?,N]DG362&!9@"+J6)VVTV]K8^66E[7?:=R^H-30\\^)(9.[TZX
M\R&WIMA;=L?M4,H!Y^3_BO?]J/XZ;WQ#.CE.DO!'FHJ;8]L!I%^Y?5!
M%74BZ^_KHT;OBBQ*RF98[7Z7]E%^F^'\MSG*\II(ZEIGJ*=PLD!2L2\H).X6
MYU``VM[==L?*16]K#M*YA*L]=SOXDE=+Z&DS-R5^F^V#*CM?=I^IRV&@GYZ
M2/#`!W4;9DUD\]L0[HS5M%0B(](&%UV'U7U&LS&N*9F:F.%91W42M*LDU
MMS8%AT`\O+#E37)1_P#*UM72&=X`T+-4HH$A:PV).]CU]3ZX^3^?M?\`:BGF
MBDFY\\3N8A/5FLATGVWVP15=LOM55-.*:?G[Q.R*ME4YF]@.O\`/`'HQB-,
M[?0SZIKD5%K8%,^J^JB?.J*IS!IJBHMK55579@JC8%22=K];]-M_3$'S'XJ
MI.!.#JSB"/,Z23Y:\S(M0I*CIY;L+_3RQ\K3=I7GZ:@U)YNY]WCL6=_GVN3Z
MG%*[M,=H+,8V@KN?$,J,"K(V9R6(]+7Q/\`A6KF:34!CN*7_B$=66AD3WKK
=W
M(Q!`.WI^F.6]5S.YB5DHFJN-LSD8#\3UCD_SPQ-QYQK44WR4_%-T5[]V:EM
M-_I?'4,P;J8:&0`!HN0KX9^(+B]USOWA?0+\.+F#5YWD91\05-'\K,JLM1)
M6`(NJ]SNPN+#&WW`O`_!W!%/49YEV9PLU85JZJ=)@$=;$`*U[^5[#8VV./E/
MR+G/S8X=I11Y'S"S:EB'2.*L8#\KXN.B[6_::HX1!2\\N)$CTA="YF^G3OM;
MTW.V-3M'9.-Q;B!4`9PNMYLO%X39]-HJTLSAO7U;-YG'7Y?%GV9S0PT;(#`
M9YT0Z6V%E))W.P^QP525F2RU=3F!JJ.MF64J=-2EX[@;-8[&WEM;'RA57:\[
M3U1(TDW/3B4DL+D9FXZ=.F&8NU=VDH9&FAYV1*[DEV7,GN3C6#HQ7%\X]"M
ML.D-,.G(?5?5_4\29+PE'49@\M,H7PT^NK70#MN#?WZ#R.&4XQX=I,[CRO/N
M,,NBK^X,TT$N8QG8`'7IU7478#UW/ICY1)U=VE)SWW._B1E]#FC_ZX"KNT
M?SZS',?VK7\W,^FJ=.GOY,QM;TO?!LZ+U@9-0A2ZG2$O=(9=?6MEY!5Y
=\M:W-SDT/%V2/44TJ*M/!F,?"3
MH"0&(W\6V/DKF[3W:&J&YR\0^%-*VS-Q9?3K@;+^T'SPH*IJNCYJ9Y'*V[2
M+F#ZB?K?#/\`#5?+:H!Y)9VZ`[,&-_!?6[)F'#N=97-EE-Q=01U5'5JU0:V
ML2ZML%N3XM@0/47Q$9/Q7PWQ4ZRTF=Y8'@6*N[VLC%M.[%@6V4#SZ'X^4
MFN[5W:4KQ:MYX2R]/QYI(FP\\`2=HOGO*6:3FWGQ+F[$YD^_ZX$=&:^;-U
[JVHWV'Y8N#-BI
=8UD`
M_G@B;M:]IJ1"C\])R`P('[6D\MAY^F)/1NN"(J#T6#;;+2P^J^LW,,_HSF%
&%I(Z@RUE1+3(L%..^ BJ0%@"&+6N
M"MA?^]L?);6=IGM"5K'YOG-Q')N#X\UD.XZ'KCTO:[0\[%IN=/$K%ETL3FT
MNX].N!/1C$'^MNO`IM/I"&3##!COK2R*MX7RM(\SHQI#3).+S5&81DJK`F
MWXOQ`?TPC.,5])3BHK^.,H:`5H2MJ,UC4(6Z^P%AU]?)5_\1?/=4$8
MYM9]I%O"QC^!ZKGOSEK8WBJ^9FR*[7=6KFW/KUP;NC(+I%0A2V;#3
\74*Y
M-Q!E$\R3=W&MC;4I8`$[FY4G^[8^1JDY\\Z,O(%#S0SN(*;J$S!P!^N%P]H
M'G?33?,4_-7/8WO?4F8N#?['&?X;K3.Z)NWP3+FZ^MZCSVD-764V8299
M`D+WJ'FKH_`X`-F.H$;6_/"X\VX9D.89U)Q'EKK"A)$==&A((!`&^Y#$;^
M/DD/:0Y^,K:N;_$)U$:KYG(;_7??#\O:C[1M*M%+SJXC22(SFDEK_`)XD
M]&ZQ`[8]U`V_!/8LOK(XAS#AJGRD9Q+Q5EK2JNIXJC,8U_=]2Q\6PL0;D;?E
M@#)97!YGRU-LB(JZA6I(X,P1N\4W\`&KQW&^V/D]JT;SZJUT57-[B&06
MM9LTD.WYX33]H;GG2.LE-S8SY&7\)7,G!'TWVQ/^',01!J#T*`[:1!IKZX,
MWXCX$X'HH*W-.(\J2GJ)#'#-+F:%+&S-?7UN;$8/R+F3RXXPII$/\MFE
MII[DG&81-9@M]*F^][CAQ\B57VB^?%?$T%;S=X@E1OQ+)FA!_7`]%SXY
MT9=J^0YHYY#K_%W8R"_Y'`NZ-57&[QZ%8=NF(:R/-?7;E7-/@3BBFS(Y=QO
?%&Q1:J0@
M+^$=6VWMZ?ICY`4[0/.^*1IH^:VJ[_C9RD!;Z[[X?F[2O:!FH!EC\Y(_E
MPUQ",VE"W^@.,_PS5)L\A6-VZ[-)9SW+ZV,QYB/4E-59J*,N6"C:U1:MB
MTW:UQ-N;6N!OOUP)EG,3EOQ%#/F^4:Y15=[':.,9FC.J,;7`)\M^HN/UQ\
MDR\^B4[TB\S\\$;G4Z?M*2Q/KUPF@YX\X\M;O:#F=GD+$;F/,9!_7!'HY5
M(C./=2W;H$@,L=?TY*^M&'CSE_E&7IG+\Q\G[LL8N\@S&$L%%]SXM[$;[#;#
M/#_-3EKF&254/&6753R`+#/!61V*D]+W(.]A;RZX^3-^/.*HC,_,W.V5
MK@@YC)O?KYXI1\ZN;F7P&FH96=Q1DW*1YC(!?\`/#/\/509+Q/@@?MMQ:&!
MMOFOK_]4$XHX9ESZBII49I9VDS"-@H!%P+L+;GZ'?I@1N87"5QJ3S'RI
M=9.]CCDS.`%%ZD$!K$V(W]L?)E/SZYU3Q=U+S3SUE`L`RDZ?G@=O-@+I_
M]1LYM?I^T)/]3_A^I'YPH.V`0.POK%3M"LVS&3)$YP\-),\I$E$N1"1-[
M78:O"!U!/4;C;$Q3R.7,=3KS+B[)IZBQCHIHLUA=90"0Q4J^YWW]/7'R+5'
M,GF!-*)Y-,S9_\`.:Q[_P`\%)S?YJ+&D:\P\X"Q_@'[0D\-_3?#?X'4#8S#
MAHE':EH#8YYXKZUWYF'.Y;4YS4\PKH8BTW?9K$^H7/@ZCS7H;&QOO8
M50_^56:99/G?#W-'(JF&EG[@O2YW3L8T(O=@'(TD;6!V/GCY)ASAYJF%X#S
M$SG1*+2)^T)+-]=]\-T7-CF;ESN*#CW-H=8\7=USB_Y'&-V'5!DN'H=%C]J9
MW?E\?NOK3_^*'DUW]4L_.GA&C5"FLC-(?W8MJP5[^5K=NIQ*/]HCD=Q;
M`,RR'G'PQ7/!3CO!3YW`LDDV_C-CU)!LP)Z;X^1IN;?,YF#-Q[FI(/G6N?Z
MX13V.9M(/\`E/VC_]EX]??`G8-1P_..=?5*&T7AP(:++Z[$YGJ1GTRY
MUSPXII9VT0TS\00JKR`EM/XMAU%_?:^).AYCF()OE:7FQD7S2ADC_`&[3
ML5OZ$/CS'E^/D`JN;/,ZKF::IX^S:1SU9JYR?YX]_ZLSHWUIQ_FZMIM5
M\@/\\3_`J^6SQ/@@9CGM3&J^ORAYL\G,\KDRS(N:O#,U7$QCJC2\00NT"QF
\,PTJR`2--Q)`K,0/"6&OR_ORQ\@=-S
M2YDT=2U32=YM'(V[.EX)/OOAVKYOTZM?^9YA9P]A8:J]S_7&?P&H'`AX]
MUGX]_#[+ZTJWGOVX:BFRR#GIPL];NT*R00#:X_"2]@";"PWVOBX:SC_E54
M,4N=5O.KA"BI68?+N[IU6:32%L7UVMJ'4F/D#3F5S!B`":9D+K8_\X_3
M\\+J.:/,BG%'-QUFS1*/#$U?)I&_I?!_P`$J6AX]%'XTD?E`\)Y"^M6KYV]
MFW(JZGR*MY\\,L[3=\/E,[A$EMSJ5M(L]SY];CRP-Q5VM.S3PYEM:U?S;RN
M:HHHPU2@S)B#K`"H`UB3ML#Y$^6/DI_X]XVM;_BS,=C?\`-O\`ZXJ8''+
M!@W&&9'6+/M??\`7#/X)4)_/\U#,46D]D+Z\^'^T;V?N--=4;O",W?QLRQ
M+GL!8QZALX,A-M_?H,$T?-+D;D-9*9N8^0RS16CE-/G%/X1??2=#$?3'R`
M1\;\91"T7%.8+_[:MQ_7#Z\R.8)\)XWS:QZ@U\G^N!_@;\L9PC;C7-;!:%]@
M.;].1.55DN5Y-S7X/222C:6.H/$,#V925=/#)?H"U^HOTWQ;F6]K'D'`YAJ
M.?\`PG()*CNZM3Q'2KX=K7!E\)Z=HOMCY'7X]XW)!/%^97MU^=?_7#0XQXL
M5BZ\2UP).Y%4US^N&-V,X#\P4.QA=_2OKV/:N[,U'4IPCE_.SA26!8%"0IQ'
M3=]&X8G?QDM;8ZNG7!M-VD^0F8Y+3U%-SBX;DD@)4Q4^=TQ%M!L&*OL;[G8
M$??'Q^#C#BL2=\.)*[7_`)_FFO\`G?!5/S+YAT8*4O&V:1@G+7./ZX$[$='
MYA[HOQSBXES9GG@OKIBY_LJBAI\JEY@Y15_+U15)8\XB;4K&X)\? 7]MQ;?
M?!6?].6T;9;!Q[P_&(9&0][FD(U@MMW?B`N&'TMMCY%H./-6F@,=-S%SF
M-6ZA,QD%_+UPS)S2YD]Z93QYFY8[DG,).OYX(;(J9YS!+.*S6BPY]E]=65\\
M"ZVG#KQSD$],$8L\.1/H.PT;/UW-[^GWQ$1XN`*1'ISS$X4,3:*@?MJ(
MLS%@2`0_B(WO^'8"XV./DSH?-@%J+F-G,5[DZ,PD&_P"&YN;O-*61WDY
MA9PQ=KN3F$FY_/#&;-KL-G#T0'$`N)A?6U'SUY439JU#5Q.&_F'C$J:L[@.
MN_L&-K7'GY^#LOYVNEE3)3S,X3[W,:.1$A&:0J8BNP9R9+`];;CICY%%YJ
MNVLYHY-1U:4D_/+A&G+HTL[?MNF$8(8!O#)T\(VOU/OB.ROF-PKFN9+14W:
M@X-6%DUP`9[$Y)-P5(U[7%S8^N/DEYEPIC;C?-6_]U?(?ZX5!S,YB0FT7
M'&:K6.FOD%Q^,=LNH?Z@H-419HY^Z^OC*^+N!(LSJ[;M"\(Q_*0(U7IX@
M@9!L/$QUV/VWZ;X?S_C3EQG@BK,D[1/#E?JJH8JZ6CXGIK0J6_&?%O;W_P`M
MKX^0(T^90B:`9OH?\:?/R6;Z[[X3!S-YB4C,:7CG-H]0*MHKY!AWQ+=
MF/#804;L4\U[0!9?8759ARA$;I5=IG*ZFG@UR,Z\0TY*6ZM8/KIV\Q]/-
MBGE[,#Y;^UYNT!P[61-)=I).(J!;6#V\0W&I?'ZG-3F6I`7C[-Q;I;,)/]
M?FGS+DA^7?C[.#'^C]HR6_*^"_ACYU"+\5V,N7QYA?87E4]ES.OEK*#
MFQP]6T8?5\PG$#D*=F%PVUM_O@-.(^Q7(\E'EG,_A,O*9#'&O$-YF`V"W?
M8_KO],?(%2\U^9M%3&CH^8&11-NT8R!3]@-'F;S%/7CG-MNG_/R?ZXEV
MSJCMX]$L5K@D:=_Z+[!ZC.S12AN(DYB/4D,FKO9:K/X%0-WBN]AU@/0;
M8)R3F=V95DGJ.97`,;3DAI5XCI&DEC.ZZ;MU%K'RQ\+\T9 ,@TR?9PPVV
M.8R'^N&).8''4I)DXQS,D]2:Z3_7"_X29D.A-.+YP)%E]@D_:`[*W#&91)F
M'//ES00R3WJ8JGBR@C9"%)5@&DWWL+;9WOL7D_:/[+V,]30\Y^#9*9(2(9
MDXFHF$@V\5ED(!.]U.^X\L?':_&W&,AO)Q3F#$;5CG^9PJ'CSC:FO\`+\6Y
MBE^NFL?UQ#=D.;?,)XI3L0]Q((L5]CE5VD^SC2M)19;SQX6,RRQ1RHNTT@
MB778C4'L!8WO_+`\7:Y[,])4]W4]#('T][#)524J=X`Q&D7DOD'PBQ(:
M]MQCX[1S!XZ`('&&9V)N1\Z^_P"N&VXXXR=U=^*LP)0^`FLV^F^(&QC _L.
M(J$:?MZ+[(,Y[87(-R5\OY['R(4/S9;BF=;E1MI$GD0?SOMB"SWMR]FR"
M&ARJ7GUPHXFBW6FSJ$KI(MI)UG2@/3I?'Q^MQWQJY)?BS,3?KL??\`7"#Q
M1!GU-8*%%@1KZ@FX!N=_;$#)VLNSLUFR=N?_#?SA@DHCFSZ"RJH)"[/:YZ
MV\P?(53\Q/J06I-,TC'HE=(/ZXI)S#X\FD,LO&.9LYZL:U[_G?`'9=1SK
MN"(8@M;9M_$POK9K^?W(&?,34P\.%IWIH?F))CG-.%8R`[VU[V6P]0?7H2O
M_B8[/4U`S"JYO\`"[F68E)6S^FC36`+6\=U`V-_.WE?'R-'COC9@5;BW,B#
MU!K7_P!4?CCC.10C\5YB0.@-8^WZX@T?F'=;1&6\B,H%N.O;+ZR^+
MV#V:HZ+YVFYV\-%3([*M1GT*B)Q96(LWC%M[GWP#)VH0'%].DF7]H3A,4RH
M0R?MV!38K:[^U_?\_D]DXMXIF4)+Q%7,!T#53&WZX3'Q-Q'%?NL^K%OUTU+
M#^N!_@[YL]&S&O9_3/G^B^KJC[3/9YS',339AV@.%:IHY-,M(O$%)=#I!\%W
M)9;:=^@-Q?:V"*3MC=GC)UEJY['Q3_`"\JQ0OG](I4*]]AJ!+&^PV)\@?
M)\W%7$[/WC0UQ;_`#&J_\`/%))N(YW[V;/JQV_P`S5+$_SQ(V0\"`_P!E
M+L=G$.8(\?T7U39GVW.R]DO%L22\[^$DE,)FF,=Q2*Y(8%9-!(4V6]CXMQM
MN,+C^(1V:*N=LM'.;A6GAE\,$[9F'(:Q8'2+67H`+"VV/E4EXASZ_?YU5O?
MKJJ&/])&9T-AF]2/I.W^N`=L1SG3UGLA=C:C@1EBT#2WLOIMS_`.(9V=M
MH:@YKSSX;TK('3,8W9;`;`@WL;7^OGBS^*_B1=G_BJGB6@Y JY%&!&K+IKD
MC;\!(#7/2P_,X^;QJJJ8EFJ9"3U)XI\S4?_`-0__P"&0=A!SI=4/IH@=BZ
MG](CW7T#R=O7L[YYWV6R\'8HAXYIY:PHM@=E!8@=[WMTQ8?%GQ$^S30R-
M?G[PP42(JL]'F2/KN/"";FYV\OUQPR9F8W9B?J4P;=AT@ZWLH_$U,L+N)G
MOQ"^S3GV5+11]H'(N\DD622)[E"K+^JVFU[BU[W]L:WP..QKS2S27-SSI
MRJAK8J@&*6)[%M^NPL=@,S+GUQ[#*QV4_ROCR52NS\1^9;^TG;#XY&YX)
M.&E+G=##*`L*,2VC4#L?7WQE3A+XR7*".OD;/I:BG.G_J1Q%M72PN/[ZXY
M78]AAV52(NZZKTL*ZC^1Y`X;ET;Y[?&GH9XYX.4V3U,LT],89*BKF)4[65@I
M_"0!^N-$N;O.OCOG1Q#)Q!QIG,U2[.659)"UKGWQ:./8L8?`8?#F6B3WI[:
M1)F%['LQ[%U,7__V0``````````````````````````````````````````
M````````````````````````````````````````````````` ```````````
end
Old December 17th 07, 04:55 PM posted to alt.binaries.pictures.aviation
John Szalay
Default A340 Incident - File 1 of 2 - PMRUNUP.JPG (0/1)
"J.F." wrote in
. net:
cabled during runups?
Sorry will repost..
Tied down engine runup
John Szalay
Default A340 Incident - File 1 of 2 - PMRUNUP.JPG (1/1)
Click image for larger version
John Szalay
Default A340 Incident - File 2 of 2 - RUNUP.JPG (0/1)
"J.F." wrote in
. net:
Sorry will repost..
John Szalay
Default A340 Incident - File 2 of 2 - RUNUP.JPG (1/1)
Old December 17th 07, 05:33 PM posted to alt.binaries.pictures.aviation
J.F.
I sure remember this run up area. Thanks for the pics!
J.F.
"John Szalay" wrote in message
42...
Old December 17th 07, 07:07 PM posted to alt.binaries.pictures.aviation
Terry M[_3_]
KEWL shots...!!!! I got to see the SR-71 take off from Kadena Okinawa for
its first mission over SE Asia back in the 60s.
42...
"J.F." wrote in
. net:
Sorry will repost..
Old December 17th 07, 08:01 PM posted to alt.binaries.pictures.aviation
Eric
We always had a symmetrical run up procedure (especially on ice)...on 4
engine types if you needed to go to max power on #2 engine, you also went to
max power on #3 engine. Of course during engine trims you could go full
power on all 4 or 8 for short periods of time.
For awhile maintenance was deemed incompetent and we had to get a pilot to
do max power runs. That was always a fiasco. The pilot didn't want to be
there and very seldom cooperated with maintenance, they refused to
understand the need to motor a green engine or to check for leaks BEFORE
starting the engines. They would also get irritated whenever they had to do
multiple starts and shutdowns because of problems encountered during the
maintenance runs.
On rare occasions I personally ran up C-135 and B-52's with J-57's with
water injection on all engines, it was an extremely loud rough ride. I have
also run up C-135 and B-52's with TF-33's, 707, 727, 737, and 747's, all
were great, but none gave that bone jarring, teeth rattling ride as a BUFF
in water.
If memory serves me right, the J-57 produced; 11,000 lbs of thrust dry and
13,000 lbs wet at MRT. While the TF-33 (depending on series) produced
17,000 lbs of thrust at MRT.
vibrate though your chest, you should try a B-52G with all 8 burning water
awesome.
A quick check says the -52 engines are rated at almost 57k lbs of thrust
but you
can only get "hands on" with two at a time. Only? Yah, right!
The Rolls engines on the 747's and L1011's that I worked on were in the
40,000
lb. area, while the later planes, such as the 767, kicked it up quite a
bit.
Get into the 777 and you're up there with two of the 52's engines at full
power.
But any of 'em will vibrate your filllings pretty good. The "old timers"
say
the piston engines rattled you around more than the jets... personally,
I'll
admit going back as far as 707's but I've run a couple of fairly large
radials.
They shook more but to me, they didn't seem to make the air vibrate like
the big
jets do. For as smooth as they are, that much 'stuff' moving around at
those
kinds of RPM, well, even trimming a 'little' engine on a DC-9 or MD-80 can
rattle you around pretty good. For most guys, the first time they
experience it
is not something they'll ever forget!
Cheers,
jc
Old December 17th 07, 08:25 PM posted to alt.binaries.pictures.aviation
John Szalay
"J.F." wrote in news:Txx9j.70874$RX.8979
@newssvr11.news.prodigy.net:
J.F.
42...
Thanks
Wish I could claim to have taken them, HOWEVER
I obtained them from the SR-71 groundcrewman many years ago..
he worked at both Calif & in GB.
I was lucky to have been able to keep them from being lost..
they have been transfer from his original slides snd stored
on backup files.
A340 Engine Test Gone Wrong Phil Piloting 15 November 22nd 07 04:16 PM
China Airlines Airbus A340 Valentin Golec Aviation Photos 0 February 17th 07 10:29 PM
airbus A340/330 Christian HACQUARD Simulators 1 May 2nd 05 03:45 PM
cokpict Airbus A340-313X franck jeamourra Instrument Flight Rules 0 June 26th 04 08:31 AM
PSS A340 with FS2004 PumpkinPie Simulators 1 October 5th 03 01:19 AM
