Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
spins from coordinated flight
Old December 27th 07, 06:35 PM posted to rec.aviation.piloting,rec.aviation.aerobatics
Jose
Default spins from coordinated flight
A "normal" turn is accomplished by splitting the lift vector, NOT by holding in yaw. Yaw should only be present in the turn dynamic during the entry into the turn and exit from the turn.
Ok, then what exactly is "yaw"? My understanding is that it is a change of direction of the longitudinal axis of the aircraft in the plane that is roughly coplanar with the wings.
Splitting the lift vector serves to change the direction of flight, but not to change the heading. To do that you need what I was calling yaw, and if you want to stay in a coordinated turn, you need to continually change the heading as you continually change the direction of flight. You would have a steady change in heading (which will include a steady yaw) with no acceleration in the yaw direction.
You seem to be defining yaw as a rotational =acceleration= of the longitudinal axis of the aircraft in the plane that is roughly coplanar with the wings.
Do I have that right?
Jose
You can choose whom to befriend, but you cannot choose whom to love.
spins from coordinated flight Todd W. Deckard Piloting 61 December 29th 07 02:28 AM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 11:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 07:40 PM
Snap / Flick and spins in flight simulators [email protected] Simulators 1 September 2nd 06 08:10 AM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 09:46 PM
