question about EZRocket
Old October 1st 03, 06:38 AM
David O
(Dan DeLong) wrote:
Even so, the statement is not entirely accurate.
David O --
http://www.AirplaneZone.com
As Dave Barry would say, "an alert reader....".... You are correct in
your observation. The more complex and more correct statement is that
the single engine ground roll and takeoff are similar to an O-320 with
constant speed prop at a low MSL airport. After takeoff, the piston
engine/prop thrust drops with indicated speed whereas the rocket
engines have constant thrust. Also, the piston engine power drops with
altitude.
And the reason for the short airshow routine was because the events
coordinator asked us to keep it short. Otherwise, Dick would have done
a second go-around (which he practiced at Mojave the week before). We
landed with about half of the propellants remaining, which was why we
did the LOX vent after landing and before rolling into the crowd. Too
bad; that second go-around is more impressive at lighter weight.
Glide and landing are similar to a standard Long, except that the
rocket has less drag (the added fuel tank has less drag than the prop
and cooling drag did), and the belly board is less effective ahead of
the fuel tank.
Dan DeLong
XCOR Aerospace
Yes, Dan, I ran the numbers for a flat 400 pound thrust using the drag
curve of my Long EZ at 1200 lb. Best rate of climb was 2,770 fpm at
130 kt. That's why I concluded, "not entirely accurate". I then ran
the numbers for both engines firing and got a best rate of climb of
8,100 fpm at 185 kt with an aircraft weight of 1200 lb.
As for the LOX vent at Oshkosh 2002, that was something to see. I
think it was you I questioned afterward and you said it really was not
dangerous without some sort of fuel to burn. You (or whomever) said
you had once purposely put a lit cigarette into the O2 cloud -- the
cigarette burned quite rapidly and that was the extent of the effect.
Thanks putting the videos on your XCOR web site. Riding along with
Dick was a trip. I could hear the concern in his voice on that early
run when the engine didn't shut off as commanded, "We've got a major
problem here."
David O -- http://www.AirplaneZone.com
Tailwheel question Steve B Aerobatics 4 January 30th 04 04:35 AM
Air compressor question Frederick Wilson Home Built 40 October 6th 03 03:50 AM
Question on Pulsejets/Ramjets??? DarylG1532 Home Built 3 August 16th 03 04:20 AM
AVID FLYER question OB1 Kanobe Home Built 0 August 14th 03 03:46 PM
question on intercoms for my new homebuilt w b evans Home Built 1 July 23rd 03 01:57 AM
