D Ramapriya wrote:
On Jan 26, 5:31 am, Jim Logajan wrote: As I understand it, the force of the tail plane's elevators typically moves the center of lift forward and backward along the airplane's axis as the elevators are moved up and down (as well as changing the lift magnitude a little - though that is secondary). One presumably enters stable flight when the center of lift is moved to coincide with the center of gravity. Since the CL can be altered by the wing configuration - deployment/ retraction of flaps for a given pitch, e.g., I'm not sure that the CG and CL need to necessarily coincide for stable flight. Also, for a body such as an aircraft, I think the CG would theoretically be somewhere within it while the CL is a point on the fuselage, so their coincidence may even be an impossibility. If the total lift vector does not pass through the center of gravity, then the resulting moment will rotate the aircraft. That is not considered a stable situation. Here's what I hope is considered an authoritative web site that discusses this issue: http://www.grc.nasa.gov/WWW/K-12/airplane/acg.html See also any text on flight mechanics and aerodynamics that has sections on the subject of longitudinal static stability. |
| Thread Tools | |
| Display Modes | |
| a question for the aeronautical engineers among us | Tina | Piloting | 10 | November 4th 07 01:56 PM |
| Are flight engineers qualified to fly? | Mxsmanic | Piloting | 14 | January 23rd 07 08:39 PM |
| Aerodynamic Drag | Kyle Boatright | Home Built | 7 | September 26th 05 04:34 AM |
| Aerodynamic Simulation of Standard Cirrus Glider | Jim Hendrix | Soaring | 13 | November 10th 04 12:38 AM |
| Airfoil aerodynamic simulator... | Thomas J. Paladino Jr. | Piloting | 4 | May 17th 04 03:41 PM |
