WinPilot ADV & PRO 9.0b Flarm
Old February 5th 08, 09:49 PM posted to rec.aviation.soaring
Paul Remde
Default ADS-B in Gliders in the USA
Hi Marc,
The maps I've seen of the rollout of the ADS-B ground stations will be much
sooner than you imply.
And even without the ground stations a batch of gliders with ADS-B units
would see and avoid (hopefully) each other - similar to FLARM.
But I'm sure (sincerely) that you know more about this than I do. I hope
you'll join us for the meeting.
Paul Remde
"Marc Ramsey" wrote in message
Paul Remde wrote:
My dream is that is 1 to 2 years from now many glider pilots will be
voluntarily using low cost ADS-B transmitter/receiver units. They will
show nearby traffic where you are AND they will allow you to see nearby
traffic - not only traffic that has an ADS-B transmitter. If you are
near a radar controlled airport with ADS-B transmitting you would also
see all traffic that has a transponder because they broadcast that
information to ADS-B receivers - cool!
The situation is a bit more complicated than the dream, unfortunately. Two
aircraft equipped with ADS-B transceivers of the same type (UAT or 1090ES)
will detect each other when within proximity, right now, anywhere in the
US. The ability to obtain traffic advisories for aircraft equipped with
the other form of ADS-B, or using Mode C or S transponders, is dependent
on the existence of a network of ground stations. These ground stations
are already in place along the coast from New York down to Florida, in
Alaska, and a few other random places. The contracts to complete the
system were just awarded last fall, it will be 10+ years before all of the
ground stations are in place.
So, for the next few years, an ADS-B transceiver will be nothing more than
an expensive underutilized FLARM-like device in most areas of the US.
That said, if we don't start pushing for what we want, right now, we
probably won't be happy with what we can get when the network is complete
in 2020 or so...
Marc
Old February 5th 08, 10:56 PM posted to rec.aviation.soaring
Bill Daniels
2 years or 10 years means it's probably not a great idea to buy a Mode S
transponder. ADS-B is a great technology and the sooner it's available, the
better.
Bill D
"Paul Remde" wrote in message
news:bZ3qj.17165$9j6.13971@attbi_s22...
Hi Marc,
much sooner than you imply.
Paul Remde
Two aircraft equipped with ADS-B transceivers of the same type (UAT or
1090ES) will detect each other when within proximity, right now, anywhere
in the US. The ability to obtain traffic advisories for aircraft
equipped with the other form of ADS-B, or using Mode C or S transponders,
is dependent on the existence of a network of ground stations. These
ground stations are already in place along the coast from New York down
to Florida, in Alaska, and a few other random places. The contracts to
complete the system were just awarded last fall, it will be 10+ years
before all of the ground stations are in place.
than an expensive underutilized FLARM-like device in most areas of the
US. That said, if we don't start pushing for what we want, right now, we
in 2020 or so...
Marc
Old February 6th 08, 04:27 AM posted to rec.aviation.soaring
Gary Emerson
Default WinPilot ADV & PRO 9.0b Flarm
I didn't suggest that they couldn't use FLARM as a collision avoidance
aid, but if I had to take a guess, rules could come into play that might
prohibit the use of software that provides certain data that is derived
from FLARM or other products.
There is no doubt that FLARM is a great safety product, it's the extra
data that comes into play that is an issue with competitive advantage.
Specifically, precise location and climb rate.
One might even see pilots electing to NOT use FLARM simply because they
don't want other people leaching off them.
Paul Remde wrote:
Hi,
I think we will see a lot of software and hardware in the near future that
will allow us to see the climb rates of gliders in our area. The rules
committee will have to figure out how to deal with that. I don't see how
they can tell a pilot not to use their favorite soaring software or their
FLARM (or similar device).
Telling them not to use their FLARM would be like asking for a lawsuit
should they get into an accident. I don't think any contest manager would
ever do that.
Also, it could be argued that seeing climb rates of nearby gliders is a
safety enhancement because it can help you avoid a landout - given than
landout is less safe then landing at an airport.
It will be very interesting to see how this develops.
Check out the image on my SeeYou page of the new FLARM radar. I think it is
really cool! But I'm a techno-nerd...
http://www.cumulus-soaring.com/seeyou.htm
Certainly this is not much of an issue in the USA at this time because very
few gliders are using FLARM here. But in a year or 2 we may have low cost
ADS-B units that will offer the same functionality in SeeYou and other
software.
Like all new technologies I'm sure that some pilots will embrace it and
others will not want themselves or others to use it. But I'm pretty certain
that it is going to happen. I think it will increase the level of safety and
fun.
Good Soaring,
Paul Remde
"Gary Emerson" wrote in message
Richard wrote:
WinPilot 9.0b Flarm
FLARM: Added ability to track several other gliders in the vicinity
that also carry FLARM on board. WinPilot can now show wisually the
position of the other gliders, their bearing, and also indicate
weather or not they are climbing, and if so, what their current climb
rate is.
Richard
www.craggyaero.com
Don't the rules prohibit any thermal detection system that has a range
beyond the wingtip of the glider?? Seems like any system that provides
location and climb rate is violating the INTENT of the rule.
I completely agree that proximity detection is a benefit to safety, but
I'll bet that unless the software programmers elect to limit the data that
could be used to a competitive advantage on their own that we'll
ultimately see new rules come into play that will force that requirement.
Old February 6th 08, 10:01 AM posted to rec.aviation.soaring
Henryk Birecki
As far as I understand this some information can be turned off in
FLARM by appropriate privacy setting. In addidtion on can set FLARM so
that it randomly switches glider ID, so that "flight following" is not
that easy.
Some food for thought: GPS_LOG deals with leaching by recording in the
IGC file whether or not FLARM climb rate display is enabled. These
records are secured by file signature. Of course to use something like
that, IGC would have to give up on the loggers and go to PDA
implementation. No I do not want to start this discussion .
Cheers,
Henryk Birecki
Paul Remde wrote:
Hi,
ever do that.
software.
fun.
Good Soaring,
Paul Remde
Richard wrote:
WinPilot 9.0b Flarm
rate is.
Richard
www.craggyaero.com
Old February 6th 08, 12:09 PM posted to rec.aviation.soaring
John Galloway[_1_]
European pilots and Flarm are very aware of the issues
regarding use of Flarm data in contests. Version 4
mandatory update software will be released at the end
of February and I guess it will include updates to
the privacy functionality.
John Galloway
At 09:06 06 February 2008, Henryk Birecki wrote:
collision avoidance
it's the extra
advantage.
simply because they
turned off in
on can set FLARM so
that it randomly switches glider ID, so that 'flight
following' is not
that easy.
by recording in the
enabled. These
use something like
go to PDA
Cheers,
Henryk Birecki
Paul Remde wrote:
Hi,
our area. The rules
software or their
ever do that.
nearby gliders is a
in SeeYou and other
software.
will embrace it and
fun.
Good Soaring,
Paul Remde
'Gary Emerson' wrote in message
Richard wrote:
WinPilot 9.0b Flarm
in the vicinity
wisually the
also indicate
their current climb
rate is.
Richard
www.craggyaero.com
that has a range
the rule.
to safety, but
own that we'll
Old February 6th 08, 10:49 PM posted to rec.aviation.soaring
Frank[_1_]
Richard,
Nice to have the new functionality, but have any of the outstanding
bugs in 8 and earlier versions been fixed, like the ones we have been
discussing here for some time?
Frank(TA)
On Feb 4, 3:27*pm, Richard wrote:
WinPilot 9.0b *Flarm
rate is.
Richardwww.craggyaero.com
Winpilot FLARM wiring. [email protected] Soaring 2 April 25th 07 10:57 PM
FLARM Robert Hart Soaring 50 March 17th 06 12:20 AM
Flarm Mal Soaring 4 October 19th 05 09:44 AM
FLARM John Galloway Soaring 9 November 27th 04 08:16 AM
WinPilot Offers Free WinPilot XP for your Desktop Computer Richard Pfiffner Soaring 0 November 8th 03 05:44 PM
