On Feb 16, 12:38*pm, nimbusgb wrote:
On 16 Feb, 12:45, nimbusgb wrote: On 15 Feb, 21:08, Papa3 wrote: On Feb 15, 9:09 am, nimbusgb [Jim wrote: * and can provide just as secure a record for badge flights] [Ian wrote: * Not even nearly] Okay Ian - prove it. * Prove that a COTS unit governed under the manual OO procedures I've laid out in the referenced link doesn't provide an equivalent level of security. *Come on, I dare ya *:-) http://home.netcom.com/~pappa3/files...rity_draft.pdf A cots GPS is still not as secure as an IGC logger. Your presentation appears to have merit and I'd support using it for badges. Ian Ho boy! It is VERY simple to split the casing on COTS units and substitute some internal microprocessor controlled gubbins or even reprogram the software so that it appears to perform like the real thing but given a few 'special' keystrokes could do just about anything, including dumping some prerecorded track or trace. I have a Garmin 12 that I put a NiMh pack into with a charger circuit INSIDE the casing. Without the manufacurers PKI key it would be extremely difficult to acheive this sot of thing with an IGC logger and still avoid detection using the VALI programs. That's why a COTS unit is not as secure. There is no way for anyone to check the validity of what's being produced from the unit or whether the unit is still a 'standard' cots unit. Now if you want to talk about how #probable# it is that someone is going to spend time, money and effort in replacing the internals of a cots unit just toe get a diamond height, thats another argument. Its MUCH quicker and simpler to just go find some wave somewhere. This was all argued out more than 10 years ago! Ian- Hide quoted text - - Show quoted text - Unfortunately, it was argued out by people who didn't take the time to talk with the manufacturers of the COTS units themselves!! The statement that " it would be It is VERY simple to split the casing on COTS units and substitute some internal microprocessor controlled gubbins or even reprogram the software so that it appears to perform like the real thing but given a few 'special' keystrokes could do just about anything, including dumping some prerecorded track or trace" neglects the fact that a company like Garmin or Magellan is more than a little sensitive about people reverse-engineering their products. Show me somebody who's rebuilt their Garmin 76 as you describe, and I'll believe you. I have detailed correspondence with Garmin engineers willing to discuss the issue. Of course, there are more than a few people out there (myself included) who know how to open the case of a number of IGC Approved Secure loggers to defeat the tamper switch. Gasp! On one of the units I own, this was precipitated by having to replace the small backup battery which preserves memory. Once opened and accidentally disconnected from the power supply, the security seal is broken. What to do? Oh, need to send the unit back to the manufacturer to reset the code. But, as long as I have it open, let's see how this works. Ahah, here's the mechanical switch. Let's see now, where does this come in contact with the case? Let's just mark that point on the case for "future reference". Now, send it back to the manufacturer and the unit comes back as "secure." Of course, now that I know exactly where the switch is and how to defeat that... Where did I put that 1/8" drill bit... And off we go. Of course, why stop with cracking the case. I'm sure any firmware guru and EE who wants to go to the effort of hacking a COTS GPS can more easily create a low power GPS signal generator which can spoof GPS signals with off-the-shelf components. In fact, my firm works with a number of freight/transportation firms on RFID, GPS, and other tracking technologies. Guess what one of the very REAL threats they're facing is right now - GPS spoofing. See for example: http://www.eyefortransport.com/index...nli=freight&ch Anyone who believes that an IGC Approved Recorder is somehow "significantly more" secure from tampering by a sophisticated/ dedicated cheater is fooling him/herself. I strongly agree that the IGC Approved Recorder provides a valuable solution for non-supervised/ minimally supervised flights. The overhead associated with having to manually review every recorder at a large contest would be a nightmare. But, could a dedicated cheater defeat security on an IGC Approved Logger. Yup. So, before we go off into fantasy land, let's start talking about the REALISTIC threats and the differences between the two approaches. IGC Approved loggers clearly have the advantage in that they offer an easier administrative approach at contests and other gatherings where there isn't direct supervision of the FRs. COTS loggers will require additional manual intervention which make them less attractive for those situations, but they are equally desirable for a supervised Silver C. Off to go skiing. At least I'll be on the ridge... P3 |
| Thread Tools | |
| Display Modes | |
| Standalone Flight Recorders for Club Use | ContestID67 | Soaring | 8 | April 24th 07 02:27 AM |
| Amendment 9 to the Technical Specification for IGC Flight Recorders | Ian Strachan | Soaring | 0 | July 1st 06 07:50 PM |
| IGC-approval levels for some types of Flight Recorders | Ian Strachan | Soaring | 42 | March 19th 05 06:42 PM |
| Commercial - Mounts for GPS Flight Recorders | Paul Remde | Soaring | 0 | March 13th 04 03:03 PM |
| Approved IGC Flight recorders | mat Redsell | Soaring | 2 | March 5th 04 04:35 PM |
