Bad fuel gauges?
Old February 24th 08, 02:05 AM posted to rec.aviation.piloting
Default Bad fuel gauges?
On Feb 23, 7:03*pm, "Bob Gardner" wrote:
Look at the Pilot's Handbook of Aeronautical Knowledge, too.
Wow, that's depressing. Whoever wrote the handbook apparently couldn't
be bothered to read the regulations before writing about them.
CJ, have you tried to get the FAA to correct their handbook? It's hard
to overcome this nonsense while the FAA is actively recycling it.
FUEL GAUGES
The fuel quantity gauges indicate the amount of fuel measured by a sensing
unit in each fuel tank and is displayed in gallons or pounds. Aircraft
certification rules only require accuracy in fuel gauges when they read
"empty." Any reading other than "empty" should be verified. Do not depend
solely on the accuracy of the fuel quantity gauges. Always visually check
the fuel level in each tank during the preflight inspection, and then
compare it with the corresponding fuel quantity indication.
Bob Gardner
There's an urban legend that the fuel gauge is only required to be
correct for an empty tank. The legend apparently arises from a
bizarre
misreading of 23.1337b1. What 23.1337b1 actually says is just
clarifying that the 'empty' reading must correspond to zero USABLE
fuel, as opposed to zero TOTAL fuel. There is nothing whatsoever to
suggest that non-empty readings needn't be correct--that would be
absurd. (If it were true, a gauge that ALWAYS says 'empty' would be
legal! You could just write 'empty' on a piece of paper and call that
your fuel gauge!)
The requirement for indications of a tank's fuel level (not just on
empty) is stated in 91.205b9, 23.1305a1, and 23.1337b.
Thank you!
What you say makes perfect sense. I'll go look at the regs too.- Hide quoted text -
- Show quoted text -
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 08:04 PM
Russian Airplane Instrument Gauges Steve Restoration 1 October 2nd 06 11:50 PM
Fuel Level Sight Gauges DonMorrisey Home Built 5 August 10th 06 06:00 AM
Need the temp and oil pressure gauges for a J3, where do I get them? Eduardo B. Restoration 0 December 5th 03 01:59 PM
FA: Vintage aircraft gauges Randal Peterson Aviation Marketplace 0 November 13th 03 03:05 AM
