#21
Hi,
In article , William wrote: That's how I'm being taught. And if you've left the fuel cap off in your pre flight, and your fuel has gradually been ****ing all over the wing, how will you know? Andy |
On Feb 23, 7:10*pm, "Bob Gardner" wrote:
The best fuel gauge is a watch. The best fuel gauge is a watch IN CONJUNCTION with an actual fuel gauge. Neither suffices by itself. |
On Feb 23, 7:03*pm, "Bob Gardner" wrote:
Look at the Pilot's Handbook of Aeronautical Knowledge, too. Wow, that's depressing. Whoever wrote the handbook apparently couldn't be bothered to read the regulations before writing about them. CJ, have you tried to get the FAA to correct their handbook? It's hard to overcome this nonsense while the FAA is actively recycling it. FUEL GAUGES The fuel quantity gauges indicate the amount of fuel measured by a sensing unit in each fuel tank and is displayed in gallons or pounds. Aircraft certification rules only require accuracy in fuel gauges when they read "empty." Any reading other than "empty" should be verified. Do not depend solely on the accuracy of the fuel quantity gauges. Always visually check the fuel level in each tank during the preflight inspection, and then compare it with the corresponding fuel quantity indication. Bob Gardner wrote in message ... There's an urban legend that the fuel gauge is only required to be correct for an empty tank. The legend apparently arises from a bizarre misreading of 23.1337b1. What 23.1337b1 actually says is just clarifying that the 'empty' reading must correspond to zero USABLE fuel, as opposed to zero TOTAL fuel. There is nothing whatsoever to suggest that non-empty readings needn't be correct--that would be absurd. (If it were true, a gauge that ALWAYS says 'empty' would be legal! You could just write 'empty' on a piece of paper and call that your fuel gauge!) The requirement for indications of a tank's fuel level (not just on empty) is stated in 91.205b9, 23.1305a1, and 23.1337b. Thank you! What you say makes perfect sense. I'll go look at the regs too.- Hide quoted text - - Show quoted text - |
On Feb 23, 7:49*pm, Andy Hawkins wrote:
Hi, In article , * * * * * *William wrote: That's how I'm being taught. And if you've left the fuel cap off in your pre flight, and your fuel has gradually been ****ing all over the wing, how will you know? Andy I was taught to use that method to cross check with the gauge. Wil |
On Feb 23, 8:23*pm, William Hung wrote:
On Feb 23, 7:49*pm, Andy Hawkins wrote: In article , * * * * * *William wrote: And if you've left the fuel cap off in your pre flight, and your fuel has gradually been ****ing all over the wing, how will you know? I was taught to use that method to cross check with the gauge. Wil Yup, that's absolutely the way to do it. |
The half that's wrong is that the admonition ignores a vital
possibility: the gauges may show way LESS fuel than you expect. (Say you're supposed to have 3/4 of a tank left, but the gauge shows 1/8.) In that case (if the gauges are working well enough to meet the airworthiness requirements) you know you've got a problem--perhaps a fuel leak, which your consumption calculations can't warn you about without the gauges. A leak may be a very infrequent event, but aviation safety is about being prepared for unlikely problems, rather than unnecessarily relying on the gamble that it will never happen to you. Very good point. A fuel guage rapidly dropping toward E would cause me to go for the closest airport (hopefully with gas -- but I wouldn't insist on that!). |
If an airplane does not have accurate fuel gauges then it is not airworthy. Knowingly climbing into an aircraft that you know has inaccurate fuel gauges is both dangerous and illegal. That is why you check them during preflight. From FAR 91.205: Horse****. (a) General. Except as provided in paragraphs (c)(3) and (e) of this section, no person may operate a powered civil aircraft with a standard category U.S. airworthiness certificate ... (9) Fuel gauge indicating the quantity of fuel in each tank. To what precision and accuracy and where defined? More than half but less than full? More than empty but less than a gallon? More than ten gallons and less than 11? Cite accuracy regs, please. Jim |
#28
Gee, the world famous aviator is now telling us that the FAA doesn't know
what it is talking about when it writes documents. Idiot. Get a little real world sense. Whoever wrote the handbook has dozens of years, thousands of hours, and an understanding of how the world works. Rod Machado has not made an error of fact or interpretation as long as I've known him, and that was probably while you were still in liquid form. Jim Look at the Pilot's Handbook of Aeronautical Knowledge, too. Wow, that's depressing. Whoever wrote the handbook apparently couldn't be bothered to read the regulations before writing about them. CJ, have you tried to get the FAA to correct their handbook? It's hard to overcome this nonsense while the FAA is actively recycling it. |
#29
There is this big blue cloud coming off your flaps and the gas gauge,
admittedly a piece of crap, will SUDDENLY go from full to empty. Jim And if you've left the fuel cap off in your pre flight, and your fuel has gradually been ****ing all over the wing, how will you know? Andy |
#30
On Feb 23, 9:47*pm, "RST Engineering" wrote:
Gee, the world famous aviator is now telling us that the FAA doesn't know what it is talking about when it writes documents. Idiot. *Get a little real world sense. *Whoever wrote the handbook has dozens of years, thousands of hours, and an understanding of how the world works. Rod Machado has not made an error of fact or interpretation as long as I've known him, and that was probably while you were still in liquid form. People who have truth on their side don't need to resort to insults, name-calling, bullying, and appeals to authority. They explain their reasoning instead. Until you came along, this was an interesting, civil discussion in which people who disagreed were genuinely trying to understand the reasons for the differences in their points of view. But you just want to have a brawl. Sorry, not interested. Jim Look at the Pilot's Handbook of Aeronautical Knowledge, too. Wow, that's depressing. Whoever wrote the handbook apparently couldn't be bothered to read the regulations before writing about them. CJ, have you tried to get the FAA to correct their handbook? It's hard to overcome this nonsense while the FAA is actively recycling it. |
| Thread Tools | |
| Display Modes | |
| Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 08:04 PM |
| Russian Airplane Instrument Gauges | Steve | Restoration | 1 | October 2nd 06 11:50 PM |
| Fuel Level Sight Gauges | DonMorrisey | Home Built | 5 | August 10th 06 06:00 AM |
| Need the temp and oil pressure gauges for a J3, where do I get them? | Eduardo B. | Restoration | 0 | December 5th 03 01:59 PM |
| FA: Vintage aircraft gauges | Randal Peterson | Aviation Marketplace | 0 | November 13th 03 03:05 AM |
