Just two days left to try to stop an expensive and worthless FAA mandate on ADS-B
Old March 4th 08, 05:11 PM posted to rec.aviation.piloting
Andrew Gideon
Default Just two days left to try to stop an expensive and worthlessFAA mandate on ADS-B
On Tue, 04 Mar 2008 04:22:52 +0000, Ron Lee wrote:
Separate from this, the GA owner can choose whether or not to spend the
extra dollars to gain direct benefit from this network.
Do look into it and determine if the high cost is worth it to you. It
is not to me
We did a survey in our club a while back regarding how the members (each
of whom is an owner, BTW) would like to see money spent on upgrades.
That is, is WX more or less important than traffic, etc.
WX was first (which shouldn't be a surprise). Traffic was #2. This was
a surprise to me given the raw numbers (ie. found in the Nall report).
But we do fly in a congested area, and one of our home airports has a
nontrivial history of nearby MACs.
We didn't weight the survey questions by price; that's probably our next
step. Tossing the price of ADS-B-IN into the mix may very well change
the ordering. But, just from idle chatter, I see that traffic really is
a big concern for us.
On the other hand, I believe that Zaon (?) has said that they'd be
releasing a portable ADS-B-IN based unit at some point. So the cost may
be far lower than what we're seeing today.
- Andrew
Old March 4th 08, 06:39 PM posted to rec.aviation.piloting
Larry Dighera
Default Just two days left to try to stop an expensive and worthless FAA mandate on ADS-B
On Tue, 4 Mar 2008 16:11:30 +0000 (UTC), Andrew Gideon
wrote in :
Would that portable ADS-B equipment meet the NPRM requirements?
Old March 4th 08, 09:34 PM posted to rec.aviation.piloting
K l e i n
Default Just two days left to try to stop an expensive and worthless FAAmandate on ADS-B
On Mar 3, 9:22*pm, (Ron Lee) wrote:
Did you write "out" where you'd meant to write "in"? *Otherwise, I'm
afraid that I'm not understanding your question.
GA pilots aren't funding equipment in other aircraft. *They are, however,
funding the creation of a network in the air whereby all aircraft
(excluding military? *Nasty, that!) are announcing their positions. *It's
not all that different from transponders, in the sense that putting a
transponder in an aircraft benefits all aircraft, and not just the
aircraft footing the bill.
Incorrect. *Without ADS-B In capability...or talking to ATC,
broadcasting ADS-B Out does nothing for you. *Mode-C does just as
good.
Seems to me that having ADS-B Out only does at least as much for me as
a Mode-C transponder, only better. A TCAS I or II equipped airplane
can see my mode-C and maybe able to avoid me without my even knowing
he's there. Sounds like a benefit to me. If I have ADS-B Out, the
ADS-B In equipped airplane will likewise be able to see me and avoid
hitting me - still a benefit, I think. He'll do a better job of
avoiding me in the ADS-B case because he won't be relying on
directional antenna technology to obtain my azimuth, but rather will
calculate the azimuth to me based on differencing the GPS positions -
a much more accurate calculation. Even if the other guy doesn't have
ADS-B In, but is IFR and talking to center, center will be able to
give much more accurate traffic information than they can with Mode-
C. Yet another benefit for me, even if I'm VFR and not talking to
ATC.
extra dollars to gain direct benefit from this network. *
Do look into it and determine if the high cost is worth it to you. *It
is not to me
I think the cost estimates are totally bogus for the GA market. After
all, it's only a GPS and a transmitter.
I'd be surprised if a complete GA market ADS-B Out/In system couldn't
be done for a couple thou.
K l e i n
Old March 4th 08, 10:36 PM posted to rec.aviation.piloting
Gig 601XL Builder[_2_]
K l e i n
You must be kidding yourself. What's the lowest priced IFR certified
GPS? Add to that the lowest price transmitter which all so must be
certified. Add to that what ever needs to be certified to receive the IN
side and display it. Finally add in the cost to certify the whole
thing together. Then pay to install it all.
If any one comes out with a certified ADS-B Out/In for $40K I'll be
surprised. Half that for out only if we are lucky.
Old March 4th 08, 11:10 PM posted to rec.aviation.piloting
K l e i n
On Mar 4, 2:36*pm, Gig 601XL Builder
K l e i n
* side and display it. Finally add in the cost to certify the whole
I'm talking mainly about the cost of ADS-B Out. That unit pretty much
has no user interface at all. Could be a lump that installs
anywhere. Who says it has to be a full blown WAAS IFR GPS? I just
bought a gadget called a SPoT that has a GPS receiver and a Globalstar
compatible transmitter. Cost $135. It has essentially all the
functionality needed for a ADS-B Out. It only needs to transmit on a
slightly different frequency at a somewhat higher power. Are saying
it has to be built with 1980's technology??
Do you think this has to cost 10 X as much as a Garmin 496? I don't.
I bet Garmin doesn't think so either. Maybe less than 1X496. An Out
only box could cost far less.
K l e i n
Old March 4th 08, 11:37 PM posted to rec.aviation.piloting
Ron Lee[_2_]
wrote in :
I doubt it since the NPRM only discusses ADS-B Out. To that end, you
apparently need a TSOd GPS/WAAS receiver which will not be portable.
Andrew, if your club folks want weather, buy a 396/496 with XM
weather. Rent it out when people need it. Get a Zaon for traffic.
All that they want is available right now. ADS-B is not the answer.
Ron Lee
Old March 4th 08, 11:41 PM posted to rec.aviation.piloting
Ron Lee[_2_]
The specs mentioned in the NPRM can only be met with a GPS/WAAS unit
and I am assuming TSOd (in the panel unit).
Ok, lets say it is JUST $10,000 US for the GPS/WAAS receiver and ADS-B
Out unit installed (may be much higher). It is not worth it to me
when Mode-C provides adequate surveillance. PLus for YOU to benefit
you have to talk to ATC (if they have coverage). Most people I know
don't talk to ATC.
Ron Lee
Old March 4th 08, 11:42 PM posted to rec.aviation.piloting
Larry Dighera
On Tue, 4 Mar 2008 12:34:43 -0800 (PST), K l e i n
wrote in
Garmin sells hand-held GPSs for more than a couple of thousand
dollars, and they don't require any installation labor.
Old March 4th 08, 11:52 PM posted to rec.aviation.piloting
K l e i n wrote:
On Mar 4, 2:36 pm, Gig 601XL Builder
K l e i n
K l e i n
While that may be what you think you are talking about you specifically
wrote, "I'd be surprised if a complete GA market ADS-B Out/In system
couldn't be done for a couple thou." But that's OK.
Well what makes you think it isn't going to have to be certified to at
least the level of a TSOd GPS? And what do you think the 496 would cost
if it were certified?
Old March 5th 08, 12:25 AM posted to rec.aviation.piloting
wrote in :
Which is one of the main reasons the price tag is so high.
A more sensible approach would be to allow equipment classed like
handheld GPS for those that aren't going to be doing approaches into
Class B at minimums, but that isn't the proposal.
Jim Pennino
Remove .spam.sux to reply.
Non-Owners insurance- Worthless? Matt Herron Jr. Soaring 13 January 13th 07 10:50 PM
Used Cessna 150M Mixture Cable On Ebay 2 days Left NW_PILOT Products 0 April 3rd 06 09:13 AM
Used Cessna 150M Mixture Cable On Ebay 2 days Left NW_PILOT Aviation Marketplace 0 April 3rd 06 09:13 AM
Ethanol Mandate for Iowa? Jay Honeck Piloting 155 October 4th 05 04:17 PM
Bendix King's worthless GPS loader software Ryan Ferguson Owning 6 July 21st 03 06:27 PM
