On Fri, 14 Mar 2008 21:09:36 -0700, SoaringXCellence wrote:
There are at least one of each of the following gliders for sale currently: Jantar 2 Nimbus 2 ASW-17 At about the same cost for each, after delivery. I'm interested in the comparison of these three ships (and only these three ships!) by individuals that have actually flown them or at least one of them, for handling, comfort, idiosyncrasies, and any other details you feel are pertainent. I owned a share in a Nimbus 2 and flew many hundreds of hours in it, including competitions, an FAI 750km triangle and a 1000km Diploma. As they say "TINFOS". I have flown with ASW17's and helped derig them. The Nimbus inner wing section is lighter than the heaviest wing section of the other two you list. This is particularly significant if you land out in a soft plowed field. You need four strong fit men to carry the Nimbus out of a field but it is doable and if you done it you wont be too scared to get into that situation again. This is important. There is no point in flying open class unless you intend to use the performance for what it is intended for! With the others you will need even more or stronger man power and once experienced it might put the brakes on future cross country aspirations. Performance wise, the Nimbus has a lower wing loading than the 17 when flying empty, which gave it an advantage in weak weather. It was particularly good at sneaking back home after everything else had landed. The 17's might have gone a bit better in strong weather - maybe because they managed to load them up heavier. (But it was quick to full the Nimbus tanks and I regularly carried water.) Whatever you chose, you have to be committed to fly open class. Everything takes more time and effort. Rigging, cleaning, pushing, polishing even towing. There is a learning curve required to, but when you get on top of it you will fly a lot further and a little faster than the 15m pilots. (Now days I fly an LS3a, it handles beautifully, it climbs, runs, can be landed in a tiny field and it is easy to de-rig and tow home afterwards. It is really nice on our ridges. All very different to an open class glider - but I do a lot less cross country millage now than I did in the Nimbus.) Have Fun Ian |
| Thread Tools | |
| Display Modes | |
| Open Cockpit Gliders? | DL152279546231 | Soaring | 17 | December 25th 08 09:14 AM |
| Open Class Nationals | [email protected] | Soaring | 6 | July 12th 05 06:05 PM |
| DAY 4 U.S. Open Class Nationals | [email protected] | Soaring | 3 | July 3rd 05 04:24 PM |
| US Open Class Back Seat available | Paul M. Cordell | Soaring | 1 | June 10th 05 04:53 AM |
| UK Open Class and Club Class Nationals - Lasham | Steve Dutton | Soaring | 0 | August 6th 03 11:07 PM |
