Skrud wrote:
They are AGM batteries and will not leak if ruptured. Get youself that and a Battery Tender Plus and you're good to go. "Sliker" wrote in message ... I'm thinking of using their biggest one, rated at 925 amps to crank my IO-540 300hp engine. I'm wondering if they are the same type of construction as the old dry cell flashlight batteries? The type that had that black carbon inside, which are still sold as "heavy duty" D cells, ect. The only downside I remember about them is if a flashlight were left on by accident, and when they fully discharged, they would then leak a messy substance and almost ruin whatever they were in. And when they got too old they'd do the same thing. I just wonder if those Odyssey batteries would do that. It would really be a mess in the airplane if they did. I like the idea of their much longer shelf and service life. I checked Bob Nuckolls site, but there's nothing there about them. And my hard copy of his old Aeroelectric connection was just starting to mention the RG batteries when it went out of press and switched to a web based system. I think the aviation dry-cell's weren't around then. I'm wondering if they need that 13.8 charging volts like the gel cells need, or if they aren't so demanding. Rich They are nothing similar to the old dry cell batteries---their shape is due to the way they are constructed---two long plates with the active ingredients smeared on 'em then rolled up to give close spacing inside---they have a good High cranking amps vs weight ratio. you can go to their site & get a complete low down on 'em. jerry |
| Thread Tools | |
| Display Modes | |
| Odyssey Dry Cell Life/Failure Modes | Ron Wanttaja | Home Built | 4 | July 11th 07 09:31 PM |
| An Odyssey into Ownership (Part 2) | Grumman 46U | Owning | 10 | March 7th 07 02:23 AM |
| An Odyssey into Ownership (Part 1) | Grumman 46U | Owning | 8 | March 1st 07 04:45 PM |
| odyssey battery | Philippe Vessaire | Home Built | 5 | October 6th 05 03:19 AM |
| Odyssey Battery-Jerry Springer | Badwater Bill | Home Built | 35 | September 7th 03 06:17 AM |
