Tie Wrap on Ventus Fin???
Old March 29th 08, 12:40 AM posted to rec.aviation.soaring
Gary Emerson
Default Tie Wrap on Ventus Fin???
Andy Smielkiewicz wrote:
It holds a "spare" tube- it is not connected to anything, just tied.
That is if your probe is a twin probe.
Andy
On Mar 28, 5:19?am, Gary Emerson wrote:
I've got a Ventus b. ?On the top of the fin (under the horizontal
stabilizer) is a single tie wrap that appears to hold something to the
underside. ?Just curious, anyone know what that item might be? ?Seems to
high to be a support for the TE probe tubing. ?There is no tail tank
installed. ?Antenna perhaps???
It could easly be to support the TE tubing. Normally the tubing is
routed up from the mount and then back down through the fin. This
upward route is to prevent water from getting into the tube. If the
water has to go up as soon as it gets into the mount then it is not
likely to accumulate in the tubing.
Robert Mudd
Moriarty, New Mexico
ah, that makes sense - probably holds two in my case as I have two
"open" tubes going into the tail...
It's time to wrap up & keep warm ~ G-TBIO Andrew B Aviation Photos 6 December 23rd 06 02:45 AM
It's time to wrap up & keep warm ~ G-OGES Andrew B Aviation Photos 0 December 22nd 06 06:19 PM
It's time to wrap up & keep warm ~ G-ARVU Andrew B Aviation Photos 0 December 22nd 06 06:18 PM
It's time to wrap up & keep warm ~ G-BTRS Andrew B Aviation Photos 0 December 22nd 06 06:18 PM
It's time to wrap up & keep warm ~ G-???? Andrew B Aviation Photos 0 December 22nd 06 06:18 PM
