Boeing Fuel Cell Plane Flies At Last!
Old April 11th 08, 08:42 AM posted to rec.aviation.soaring
noel.wade
Default Boeing Fuel Cell Plane Flies At Last!
On Apr 10, 10:52 pm, Bruce wrote:
Weight and size. (you did ask)
I did. :-)
Weight: Hopefully Cui's battery improvements (or some similar change)
will alleviate the need to carry many pounds of batteries.
Size: Have you seen how small a powerful brushless electric motor is
these days? The prop has a large dimension in one direction; but at
least it can lie parallel to the mast and not take up much total
volume. I'm surprised there hasn't been more work on a ducted fan
solution - maybe the blades would just have to be too short to be
efficient, and still fit inside the aft fuselage... *shrug*
Take care,
--Noel
Old April 11th 08, 09:16 AM posted to rec.aviation.soaring
Bruce
Hi Noel
This has exercised my little brain for some time.
The brushless DC motor is a perfect motive unit. Small, relatively light, simple
and reliable, and its performance is perfect for the job. It produces almost
flat torque, and will swing an efficient propeller with the same torque at the
high density altitudes I fly at.
The batteries are getting smaal enough that it could be done - Existing
improvements like the A123 Lithium batteries are not only safe but have much
better energy densities.
However - the batteries size comes with shape constraints as well, whereas you
can put that smelly dino stuff into just about any shape you want.
And the other part is also a problem, the propeller demands a large hole in the
structural strength determining skin of the boom. So you need to add lots of
heavy strengthening as well as doors etc.
If I ever work out how to do it and stay under the "non-lifting" limits my Std
Cirrus will be an experimental self launcher...
Bruce
I did. :-)
Take care,
--Noel
World's First Fuel Cell Powered Aircraft Flies Larry Dighera Piloting 0 April 7th 08 04:25 PM
Boeing Flies Blended Wing Body Research Aircraft Larry Dighera Piloting 28 August 3rd 07 07:51 PM
Boeing prepares fuel cell Motorglider [email protected] Soaring 4 March 29th 07 06:40 PM
uh oh, Plane flies over Bush motorcade Mutts Piloting 38 July 29th 03 04:20 AM
Boeing to fly fuel-cell GA plane... DeltaDeltaDelta Piloting 6 July 15th 03 07:25 PM
