High Altitude Waypoints
Old May 1st 08, 04:31 AM posted to rec.aviation.ifr
Dennis Johnson
Default High Altitude Waypoints
Greetings,
If I file an IFR flight plan with the equipment suffix of /G, indicating
GPS, can I use a high altitude waypoint on the flight plan even if I'm
flying in the low altitude structure?
For example, flying northwest from Las Vegas, filing from BTY VOR (Beatty)
to DOBNE to BIH VOR (Bishop) takes me around the Saline MOA that is in the
way of a direct flight from Beatty to Bishop.
The issue is that DOBNE is a waypoint in the high altitude structure and I'm
filing for 16,000' or maybe 18,000', in the low altitude structure.
Thanks,
Dennis
Old May 1st 08, 05:27 AM posted to rec.aviation.ifr
Dennis Johnson
It should not be a problem.
I've used ROKNE, east of Wichita, in exactly that way, with no issues.
Thanks, John, for the speedy reply! I figured it was probably okay, but
wasn't sure the computer wouldn't reject it.
Thanks,
Dennis
Old May 1st 08, 01:32 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
"Dennis Johnson" wrote in message
Yes.
Old May 1st 08, 01:34 PM posted to rec.aviation.ifr
The computer will accept any fix-to-fix route as long as the fixes are in an
acceptable format. It doesn't care about altitude, it will accept altitudes
that are below the surface.
Old May 1st 08, 03:39 PM posted to rec.aviation.ifr
Sam Spade
Dennis Johnson wrote:
Greetings,
Thanks,
Dennis
18,000 is in the high altitude structure provided the area altimeters
are all 29.92 or higher.
What gets tough with a routing like that is determining a legal
off-route altitude.
Where do you plan to go after BIH VOR?
Old May 1st 08, 03:43 PM posted to rec.aviation.ifr
Dennis Johnson
Thanks for the replies!
Best,
Dennis
Old May 1st 08, 11:58 PM posted to rec.aviation.ifr
Sam Spade
John R. Copeland wrote:
"Sam Spade" wrote in message ...
Greetings,
off-route altitude.
I must have missed something, Sam.
What's tough about reading the grid MORAs from the charts?
You mean ORACAs as per the AIM?
OROCA is an off-route altitude which provides obstruction clearance with
a 1,000 foot buffer in nonmountainous terrain areas and a 2,000 foot
buffer in designated mountainous areas within the U.S. This altitude may
not provide signal coverage from ground-based navigational aids, air
traffic control radar, or communications coverage.
They are not all that easy to apply on a route of any length and they
are sometimes needlessly high because they cover a relatively large area.
Old May 2nd 08, 03:44 AM posted to rec.aviation.ifr
Sam Spade
OK, maybe I'm showing my age by still calling them grid MORAs. :-[
Thanks, and I'll try to remember their current name after this.
But I've used them by whatever name for more than 25 years,
and I've never thought they were either "tough" or "needlessly high".
But then, you'll not find me flying through canyons, either.
I doubt you have as much age to show as moi. ;-)
High Altitude Bombing? Larry Dighera Piloting 0 February 6th 07 04:47 PM
High Altitude Linnies TTaylor at cc.usu.edu Soaring 4 August 4th 06 11:47 PM
High altitude & RPM abripl Home Built 1 September 1st 05 01:12 AM
High-altitude autorotations? Bill McClain Military Aviation 17 March 15th 04 05:23 PM
Low and high altitude airways David Megginson Instrument Flight Rules 7 September 9th 03 02:18 AM
