Belly Landing
Old November 25th 03, 07:24 PM
Dudley Henriques
"Emilio" wrote in message
Take a look at this 737 belly landing video clips.
http://radioscanning.wox.org/Scanner...o/737gear.mpeg
On a first sequence it appears the pilot is trying to get the gear
unjammed
by bouncing the aircraft on the good landing gear. The second sequence
shows the actual landing. But I am little puzzled by the fact that when
he
touches down the aircraft attitude is quite flat like in the normal
touchdown. Isn't it better to touch down at minimum flying speed with
nose
up and about to stall?
Emilio.
No, especially in large aircraft like this one. It's far better to lay it
down with positive control at some median airspeed that produces this
control than trying to slow it down to an absolute minimum airspeed. The key
phrase in emergency landings is "positive control". In almost every case,
this area of positive control will occur at an airspeed that is producing an
angle of attack less than that encountered with the touchdown attitude
you're describing.
Each type of aircraft has a recommended procedure covering this situation.
Some are different than others, but the actual flight parameters are spelled
out for the type involved in either the POH, the dash 1, or the Natops, as
the situation dictates.
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/ CFI Retired
For personal email, please replace
the z's with e's.
dhenriquesATzarthlinkDOTnzt
"bush flying" in the suburbs? [email protected] Home Built 85 December 29th 04 12:04 AM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Home Built 0 February 19th 04 07:51 PM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Aviation Marketplace 0 February 19th 04 07:51 PM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 05:35 PM
