On Fri, 16 May 2008 20:26:57 -0700 (PDT), " wrote in : On May 16, 10:15*pm, Larry Dighera wrote: It's incredibly small, very few moving parts. * The ability to create High Definition video at this time places you in the role of pioneer, as most things have not yet been captured in that medium. * Very nice! I wonder about the file size on HD videos? How big are they? 1 minute video on my camera = 10 meg. http://37prime.com/blog/2008/04/14/p...-video-sample/ Video info: http://37prime.com/prepare_for_landi..._sd9_1080p.mov * Format: H.264, 1920×1080 * File Size: 16.66 MB * Frame Rate: 23.98 FPS * Data rate: 8.73 mbits/s * Length: 16.01 seconds http://www2.panasonic.com/consumer-e...odel.HDC-SD9.S Recording Time SDHC: 16GB: HA (2 hrs)/HG (2hrs 40mins)/HX (4hrs)/HE (6hrs) 8GB: HA (1hr)/HG (1hr 20mins)/HX (2hrs)/HE (3hrs) 4GB: HA (30mins)/HG (40mins)/HX (1hr)/HE (1hr 30mins) Full Specs: MEDIA . Records Onto SD/SDHC Memory Card Recording Format AVCHD (Motion Image) LENS Image Sensor (Total) 1/6" CCD (560K x 3 pixels) Image Sensor (Effective) 16:9 -- 520K x 3 (Moving Picture/Still Picture) F Value F1.8 (Wide) / F2.8 (Tele) Optical Zoom 10x Variable Speed Zoom Focal Length 3.0 - 30 mm Filter Diameter 37mm 35mm Film Camera Equivalent 42.9 - 429 mm (16:9) (Moving Picture/Still Picture) Lens Type Leica Dicomar CAMERA 3CCD Camera System Yes Image Stabilizer Yes (Advanced O.I.S.) Still Picture Recording yes (2.1 Megapixel 16:9) Minimum Illumination 5 Lux (1/30 Low Light Mode), 1 Lux (Magic Pix® Mode) Focus AF/Manual White Balance Auto/Indoor/Outdoor/White Set High Speed Shutter 60i: Auto Slow Shutter ON: 1/30-1/8000, OFF: 1/60-1/8000 (Motion Image)(Still Picture, Progressive: 1/30-) 24p: Auto Slow Shutter ON: 1/24-1/8000, OFF: 1/48-1/8000 (Motion Image)(Still Picture, Progressive: 1/24-) Iris Auto/Manual Backlight Compensation Yes Electronic Viewfinder (EVF) No LCD Monitor 2.7" Wide (300,000 Dots) Power LCD Yes(Extra) Wide Viewing Angle LCD 170° (Vertically & Horizontally) Pure Color Engine HD Advanced Soft-Skin Mode Yes Easy-to-Use Mode Dial Yes MagicPix Images Yes Simultaneous Motion Video & Still Picture Recording Yes Microphone Dolby Digital/5.1 ch, Zoom Microphone Date Recording Auto Date (in Date Code) Fade in/out Yes On-Screen Display Language English / Canadian French / Spanish Digital Zoom 1 25x-700x Flash 1m - 2.5m (approx.) Quick Start 0.6 seconds RECORDING & PLAYBACK Applicable Disc No Cue and Review No Skip No Video Recording Format AVCHD (Motion Image) Recording Mode HD: HA (17 Mbps/VBR), HG (13 Mbps/VBR), HX (9 Mbps/VBR), HE (6 Mbps/VBR) Playback Mode HD: HA (17 Mbps/VBR), HG (13 Mbps/VBR), HX (9 Mbps/VBR), HE (6 Mbps/VBR) Audio Recording Format Dolby Digital (Dolby AC3) / 5.1-channel Recording Time SDHC: 16GB: HA (2 hrs)/HG (2hrs 40mins)/HX (4hrs)/HE (6hrs) 8GB: HA (1hr)/HG (1hr 20mins)/HX (2hrs)/HE (3hrs) 4GB: HA (30mins)/HG (40mins)/HX (1hr)/HE (1hr 30mins) Still Picture JPEG Picture Size: 2.1 MEGA: 1920 x 1080 (16:9) Still Picture Recording Number SDHC: 16GB: (13470, 21170), 8GB: (6690, 10520), 4GB: (3290, 5160) Counter Yes Remaining Indication Yes Pre-Rec Function Yes Intelligent Contrast Control Yes One-Touch Navigation Yes Help Mode Yes Tele Macro Yes (50cm) AGS (Auto Ground-Directional Standby) Yes Disc Copy Function Yes (when using a DVD Burner (VW-BN1), data from SD Memory Card can be copied to a 12-cm DVD Disc) USB Host Function Yes SD CARD FEATURES . Built-in SD Slot Yes (SD/SDHC) DPOF Max. 999 stills PictBridge Compatible Yes JACKS . Video Component Yes HDMI Yes (mini) Audio Output Yes USB Hi-Speed USB (USB 2.0)(mini AB) Analog In/Out Out only Accessory Shoe No AV Out INCLUDED ACCESSORIES . AC Adaptor Yes Battery Pack Lithium-Ion Video Component Cable Yes AV Cable Yes USB Cable Yes IR Remote Yes Lens Cap No Software HD Writer 2.5E Other Cables AC/DC Cables Free DVD Burner No GENERAL . Power Supply DC 7.2/9.3 V Power Consumption 5.8W Footnotes 1 As digital magnification increases, resolution significantly decreases. Have you tried your camera inside a plane? Not yet. What I have been doing on my last two videos is putting my pocket size Kodak Easy Share on the glareshield propped up with my portfolio that doesn't slide around. Does the Kodak have active image stabilization? Works very well in smooth and light turbulence thus far. Obviously anything more then that, camera wouldn't be even turned on. Wondering if the above would work with yours or would you need a tripod (or sticky pod) to mount the camera? I would expect your arrangement to work as well with the Panasonic as the Kodak. I am all for pioneering new things :-) It's an opportunity, the window of which is closing... What video editing software do you use? The Panasonic software is only basic. Nero or Pinnacle seem to do a good job (better under XP32 than Vista64) with AVCHD format. I picked up a 3GHz Intel(R) Core(TM)2 Extreme CPU X9650 with 4GB of DDR3 RAM running at 1,333 MHz and two 10,000 rpm CDC Vipers in a RAID 0 configuration from Robert at XI Computer: http://www.xicomputer.com/ . That helps minimize waiting for video processing. |
| Thread Tools | |
| Display Modes | |
| Garmin 430 rquestion- does the approach always have to be activated via "activate approach"? | Terence Wilson | Instrument Flight Rules | 46 | February 18th 08 06:46 PM |
| Where was that video: Jumbo jet on very low approach over a beach | Al Dykes | General Aviation | 2 | November 7th 07 04:36 PM |
| Video clip of an "interesting" final approach & landing | Elmo von Thud | Aviation Photos | 3 | October 7th 07 01:54 AM |
| Video of VOR A approach into MBO in actual | A Lieberman | Instrument Flight Rules | 1 | May 2nd 05 04:35 PM |
| Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 06:20 AM |
