Senior Project, recording equipment, and economic stimulus.
Old May 24th 08, 05:06 PM posted to rec.aviation.soaring
Default Senior Project, recording equipment, and economic stimulus.
On May 24, 12:36 am, Marc Ramsey wrote:
Cambridge CAI302 provides output of
true speed, but no temperature data (?).
The 302 will output outside air temperature.
In a fashion. It outputs it as some raw number in LOG 12 mode, but
unless you know all the calibration data, this mode does not do much
good.
Well, darn it, I was hoping for some easy way to display it on my PDA. I
can look at it on the 302 itself, but it's 10 button presses and 5 knob
clicks to get to it. A real nuisance.
The other thing the 302 fails to output in normal operating mode is
indicated airspeed (it provides only true airspeed), which one would
definitely want for flight test evaluation purposes...
Marc
true, but if we have TAS, outside air temp, and altitude, its a pretty
easy conversion, right?
Old May 24th 08, 07:42 PM posted to rec.aviation.soaring
Marc Ramsey[_2_]
good.
Marc
Unfortunately, the 302 does not output outside air temperature in normal
operating (LOG 0) mode. Operating in LOG 12 mode will require a fairly
sizable post-processing effort to perform the necessary conversions from
raw sensor data to usable results. If you want to go this route,
contact me via email, I have some code that will help...
Marc
Old May 24th 08, 08:36 PM posted to rec.aviation.soaring
good.
Marc
Marc
ok marc, i understand now. I still ahvent decided on what the best
route is for the data gathering. How much do the 302's typically
run? I glanced over their website and it seemed to me that the bare
logger wasnt too spendy, but then if you wanted to add on a vario
display, etc etc. it could get pretty pricey. what all would I really
need? just the bare logger?
Old May 24th 08, 08:51 PM posted to rec.aviation.soaring
Darryl Ramm
good.
Marc
Marc
The bare logger (302A) is just a GPS logger with altitude transducer,
no airspeed info etc. You need a real 302. ~$2,400.
Darryl
Old May 24th 08, 08:52 PM posted to rec.aviation.soaring
Darryl
well that takes care of that idea then
Old May 24th 08, 09:25 PM posted to rec.aviation.soaring
You'll need a Cambridge 302 (not the 302A, which is a flight recorder
that doesn't measure airspeed or temperature). If you have a suitable
PDA and software, you don't need the 303. So, minimally, the new cost
is just under $2800. I've seen used ones in the $2000 range.
If you aren't so worried about the flight recorder, you might be able to
pick up a used Borgelt B50 in the $500 range. These output IAS, TAS,
vario, and outside air temperature to a PDA, plus they are really nice
varios...
Marc
marc,
im liking that idea. i want an audio vario bad and have been lusting
after the B40 or 50 for a while. It would potentially leave enough
cash in reserves to find a cheap logger too. will have to investigate
it further.
Kentucky's toothless, Giuliani's work for Oxy-Contin, Bloomberg'sconflict of interest , junk foods and medications from same sources,lasertheft ,Economic Stimulus Plan fusion Naval Aviation 0 January 13th 08 08:15 PM
Recording Hobbs BG Owning 8 December 7th 06 02:40 PM
Recording Hobbs BG Piloting 11 December 7th 06 01:04 PM
recording from intercom system Nobody Piloting 10 April 3rd 06 07:54 AM
recording communications Casey Webster Piloting 10 February 13th 04 06:39 PM
