History Channel
Old May 30th 08, 01:20 AM posted to alt.binaries.pictures.aviation
Robert Sveinson
Default History Channel
m...
ŽiŠardo wrote:
No, that's not totally incorrect. When the weather was good B-17s
delivered their bombs very accurately for that period.
But when it came to the crunch?
Don't forget that the initial Dresden raid was supposed to have been
flown by the Americans but they cried off because of bad weather, so
the RAF stepped into the gap and played the lead role. American
"precision" bombing in that same campaign also saw the Americans bomb
Prague by mistake, although I don't know how accurately they did
that. It certainly upset the Russians, who were in residence by that
time!
Essentially the Norden bomb sight worked only in clear skies - not an
everyday thing in continental Europe, unlike California where it was
developed.
That's what I said.
But did you also say that there were MORE days of bad weather,
overcast in the European theatre than there were days
of good/clear weather? No I don't see thgat anywhere.
How about the bombing of Prague when the USAAF was AIMING at
Dresden.
How about the bombing of several Swiss cities
when AIMING at targets (supposedly) in Germany?
Also, to quote:
"The trouble was, precision was another Norden myth. From 20,000 feet,
2/3 of American bombs fell 1/5 of a mile or more from their targets --
even with the best of bombsights.
Which was very good compared to RAF night bombing accuracy.
  #32
Old May 30th 08, 01:24 AM posted to alt.binaries.pictures.aviation
Robert Sveinson
m...
time!
developed.
That's what I said.
Also, to quote:
RAF accuracy was as good if not better than that of
the USAAF if the target was vivible.
Did the USAAF precisely hit any target such as
the TIRPITZ, the Dortmund Ems canal,
the Saumur Tunnel, various Gestapo buildings,
the Antheor Viaduct, Amiens Prison?
No! I have never heard of any!
  #33
Old May 30th 08, 01:45 AM posted to alt.binaries.pictures.aviation
Robert Sveinson
m...
ŽiŠardo wrote:
Not at all. If their bomb sights were useless because of local weather
conditions their accuracy was as good/bad as that of the RAF, as the
USAAF's H2X radar was somewhat imprecise.
Right. When the weather was poor USAAF bombing accuracy was similar to
the RAF, when the weather was good it was significantly better than the
RAF.
You really haven't read the information below have you?
The United States Strategic Bombing Survey
http://www.anesi.com/ussbs02.htm#eaocar
The U. S. Army Air Forces entered the European war with the firm view that
specific industries and services were the most promising targets in the
enemy economy, and they believed that if these targets were to be hit
accurately, the attacks had to be made in daylight. A word needs to be said
on the problem of accuracy in attack. Before the war, the U. S. Army Air
Forces had advanced bombing techniques to their highest level of development
and had trained a limited number of crews to a high degree of precision in
bombing under target range conditions, thus leading to the expressions "pin
point" and "pickle barrel" bombing. However, it was not possible to approach
such standards of accuracy under battle conditions imposed over Europe. Many
limiting factors intervened; target obscuration by clouds, fog, smoke
screens and industrial haze; enemy fighter opposition which necessitated
defensive bombing formations, thus restricting freedom of maneuver;
antiaircraft artillery defenses, demanding minimum time exposure of the
attacking force in order to keep losses down; and finally, time limitations
imposed on combat crew training after the war began.
It was considered that enemy opposition made formation flying and formation
attack a necessary tactical and technical procedure. **Bombing patterns
resulted -- only a portion of which could fall on small precision targets.**
The rest spilled over
on adjacent plants, or built-up areas, or in open fields. Accuracy ranged
from poor to excellent.** When visual conditions were favorable and flak
defenses were not intense, bombing results were at their best.
Unfortunately, the major portion of bombing operations over Germany had to
be conducted under weather and battle conditions that restricted bombing
technique, and accuracy suffered accordingly. Conventionally the air forces
designated as "the target area" a circle having a radius of 1000 feet around
the aiming point of attack. While accuracy improved during the war, Survey
studies show that, in the over-all, only about 20% of the bombs aimed at
precision targets fell within this target area. A peak accuracy of 70% was
reached for the month of February 1945. These are important facts for the
reader to keep in mind, especially when considering the tonnages of bombs
delivered by the air forces. Of necessity a far larger tonnage was carried
than hit German installations.
  #34
Old May 30th 08, 01:56 AM posted to alt.binaries.pictures.aviation
Robert Sveinson
m...
RAF.
From the USAAF Air War Plans Division A-WPD/1
The A-WPD/1 Committee calculated the possibilities
of hitting the plants, in daylight, using the Norden bombsight,
balancing a number of factors to produce an 'accuracy probability". Their
first calculations indicated that to hit a target 100 ft. sq. from 20,000
ft.
would take a mission by 220 bombers, and when all the other elements were
factored in-flak,fighters, weather, whatever-the resources required to
achieve
a 95% chance of destroying such a precision target amounted to either
30 bomb-group missions or a single mission by 1,100 aircraft-which hardly
sounds like precision bombing at all.
  #35
Old May 30th 08, 02:09 AM posted to alt.binaries.pictures.aviation
Steven P. McNicoll[_2_]
Dresden.
You've confused target identification/navigation with bombing accuracy.
  #36
Old May 30th 08, 02:12 AM posted to alt.binaries.pictures.aviation
Yes.
That you haven't heard of any does not mean it didn't occur, it means you're
ignorant.
  #37
Old May 30th 08, 02:13 AM posted to alt.binaries.pictures.aviation
Yes, I have. Do you know who was on the survey?
that specific industries and services were the most promising targets
in the enemy economy, and they believed that if these targets were to
be hit accurately, the attacks had to be made in daylight. A word
needs to be said on the problem of accuracy in attack. Before the
war, the U. S. Army Air Forces had advanced bombing techniques to
their highest level of development and had trained a limited number
of crews to a high degree of precision in bombing under target range
conditions, thus leading to the expressions "pin point" and "pickle
barrel" bombing. However, it was not possible to approach such
Many limiting factors intervened; target obscuration by clouds, fog,
smoke screens and industrial haze; enemy fighter opposition which
necessitated defensive bombing formations, thus restricting freedom
of maneuver; antiaircraft artillery defenses, demanding minimum time
exposure of the attacking force in order to keep losses down; and
finally, time limitations imposed on combat crew training after the
war began.
formation attack a necessary tactical and technical procedure.
**Bombing patterns resulted -- only a portion of which could fall on
small precision targets.** The rest spilled over
ranged from poor to excellent.** When visual conditions were
favorable and flak defenses were not intense, bombing results were at
their best. Unfortunately, the major portion of bombing operations
over Germany had to be conducted under weather and battle conditions
that restricted bombing technique, and accuracy suffered accordingly.
Conventionally the air forces designated as "the target area" a
circle having a radius of 1000 feet around the aiming point of
attack. While accuracy improved during the war, Survey studies show
that, in the over-all, only about 20% of the bombs aimed at precision
the reader to keep in mind, especially when considering the tonnages
of bombs delivered by the air forces. Of necessity a far larger
tonnage was carried than hit German installations.
  #38
Old May 30th 08, 02:48 AM posted to alt.binaries.pictures.aviation
arjay
m...
Yes.
you're ignorant.
Then -- with respect -- it seems your place to provide enlightenment.
If Robert Sveinson is ignorant because he has not heard of "any" USAAF
achievements of precision strikes, one bomb per aircraft, in the ETO then
this implies that there were several such strikes. And your calling him
"ignorant" suggests you know of at least two of them.
Where, and when did they occur?
  #39
Old May 30th 08, 03:10 AM posted to alt.binaries.pictures.aviation
Robert Sveinson
"Mitchell Holman" wrote in message
"Robert Sveinson" wrote in news:7Gm%j.31$%g5.8
@newsfe13.lga:
"GC" wrote in message
My question on the B17's probably related to the fact the program
totally
ignored the Dams,the Tirpitz,etc all involving a touch of precision
Yes the so called pundits with the most resources to get A message
out to the public are the ones ignoring the facts, but it is also
the consumers of these so called facts who want their
fables fed to them by spoon rather than consulting
reputable historians who are at fault as well.
There was that fairey tale about U-571 which claimed
that the US Navy intercepted secret signals from a U-Boat,
decyphered the signals and using these spectacular results
sent a force and captured said U-Boat. A true work of fiction,
however people who saw this fairey tale asked me
in all seriousness whether I had heard about this
heroic episode of the anti submarine war.
For military movie fiction you can't "The Sound Barrier"
showing the British being the first to achieve supersonic
flight.
http://www.imdb.com/title/tt0044446/
I am surprised that you could find that one
what with the extensive air brushing out of any
British accomplishments.
I assume that you are stating that the British
did nothing in the attempts to fly faster
than the speed of sound. No surprise there.
Air brush away!
  #40
Old May 30th 08, 05:14 AM posted to alt.binaries.pictures.aviation
Mitchell Holman Mitchell Holman is offline
Banned
First recorded activity by AviationBanter: Nov 2006
"Robert Sveinson" wrote in news:euI%j.98$t07.25
@newsfe22.lga:
@newsfe13.lga:
totally
flight.
Air brush away!
No, just that British complaints about the inaccuracy
of "U-571" need to take into account their country's own
loose treatment of history.
And then there is British director David Leans' "Bridge
Over The River Kwai", which credited the British for an
action that in fact Americans accomplished.........
Battle 360 on HIstory Channel miket6065 Aviation Photos 0 February 17th 08 07:15 PM
Battle 360 on History Channel miket6065 Naval Aviation 0 February 17th 08 07:14 PM
Spitfire Ace on History channel keepitrunning Home Built 0 January 1st 06 05:57 PM
Ed Rasimus-Saw You On The History Channel [email protected] Military Aviation 1 June 15th 04 06:50 PM
History Channel Rosspilot Piloting 6 July 26th 03 04:02 AM
Copyright Š2004-2026 AviationBanter.
