1946 Piper PA-12 Super Cruiser Fuel Tank's
Old June 25th 08, 03:46 AM posted to rec.aviation.homebuilt
Phil
Default 1946 Piper PA-12 Super Cruiser Fuel Tank's
Hello
I am a welder by trade , used to work as a certified A/C welder for major
company , still do Alum . and 4130 A/C welding , a man brought a wing tank
to me from his Piper PA- 12 Super Cruiser today , he has a small leak around
one of the fittings , the tank has been soldered together , he says it's
Alum. but I am not convinced , the sheet metal is very thin and is non
magnetic , I scraped some of the solder material and it was soft like lead ,
the man called an older fellow A/C restorer and he thinks it's Alum , all
the fuel tanks that I have worked on were made from 5052 of whatever
Alum.and TIG welded , 1946 may pre date the Heli-Arc process , wonder if
someone can shed some light on this wing tank question.
Thanks
Phil
EAA 12873
Old June 25th 08, 03:56 AM posted to rec.aviation.homebuilt
R
Phil wrote:
Hello
Thanks
Phil
EAA 12873
Ask this question over at www.SuperCub.Org and you probably can get the
definitive answer. Lots of J-5, PA-12, and PA-14 mechanics there.
Old June 25th 08, 06:03 AM posted to rec.aviation.homebuilt
Rich S.[_1_]
"Phil" wrote in message
Hello
major company , still do Alum . and 4130 A/C welding , a man brought a
wing tank to me from his Piper PA- 12 Super Cruiser today , he has a small
leak around one of the fittings , the tank has been soldered together , he
says it's Alum. but I am not convinced , the sheet metal is very thin and
is non magnetic , I scraped some of the solder material and it was soft
like lead , the man called an older fellow A/C restorer and he thinks it's
Alum , all the fuel tanks that I have worked on were made from 5052 of
whatever Alum.and TIG welded , 1946 may pre date the Heli-Arc process ,
wonder if someone can shed some light on this wing tank question.
Thanks
Phil
EAA 12873
Being no expert, I believe what you have is made from "Ternplate". That's as
far as my poor memory will take me. Perhaps a search for that name will
help, as there are many references available..
Rich S.
Old June 25th 08, 04:13 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Tue, 24 Jun 2008 21:03:42 -0700, "Rich S."
Hello
Thanks
Phil
EAA 12873
Rich S.
tern plate was a lead coated mild steel.
I have an auster made in 1951. the tank is soldered tern plate.
you should be able to guess the material from the weight.
the auster tank is quite heavy. soldered up solid rivets in the
construction should be a giveaway.
Stealth Pilot
Old June 25th 08, 04:54 PM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
"Phil" wrote:
Hello
Thanks
Phil
EAA 12873
In those days, they welded aluminum with acetylene/oxygen, using a
reducing flame and special blue goggles. In recent years there has been
a resurgence of this technique.
I am not specifically familiar with the tanks on the Super Cruiser,
however.
I did a Google search on "gas welding aluminum" and came up with a lot
of hits.
Remove _'s from email address to talk to me.
Old July 20th 08, 12:37 PM posted to rec.aviation.homebuilt
Bruce A. Frank
Try  http://www.tinmantech.com/
He has a kit for aluminum soldering and recommends it for attaching fittings and bosses to fuel tanks.
Bruce A. Frank
Phil wrote: Hello
Thanks
Phil
EAA 12873
Super cruiser Philippe Vessaire Home Built 6 March 10th 08 07:40 PM
PA-12 Super Cruiser Window Part Needed [email protected] Owning 3 October 4th 07 05:34 AM
Rusty meets the Super Cruiser Denny Piloting 4 March 15th 05 05:49 PM
W&B info for PA-12 Super Cruiser Robert M. Gary Piloting 6 December 7th 04 11:36 PM
PA-12 Super Cruiser - Speed on Final Thomas Ploch Owning 7 January 28th 04 05:01 AM
