Things to remember in very hot weather
Old June 30th 08, 12:25 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Default Things to remember in very hot weather
Michael Ash writes:
You don't legally need oxygen for the passengers until 15,000ft ...
I know, but I prefer not to wait until the law requires it to take
precautions. Some people show signs of hypoxia at half that altitude. Why
take the risk?
  #62
Old June 30th 08, 12:35 AM posted to rec.aviation.student,rec.aviation.piloting
B A R R Y[_2_]
Bertie the Bunyip wrote:
B A R R Y wrote in newsLM9k.5801$LG4.5340
@nlpi065.nbdc.sbc.com:
muff528 wrote:
Yep, 43° C (109 f.) WOULD be extremely uncomfortable at 3000'. But it
probably not that hot at 3000 if it's 43C on the ground.
Do you fly?
109F on the ground would be at or near 100F at 3,000. That's still hot,
especially with the sun beating on you through the windows.
Actually, it would probably be lower, but it depends on the stability of
the air on the day...
Like what? Maybe 97 or 98? G
Wouldn't that be NEAR 100? G
  #63
Old June 30th 08, 01:17 AM posted to rec.aviation.student,rec.aviation.piloting
Steve Hix
Michael Ash wrote:
At the risk of turning this thread into something useful,
Heaven forfend!
does anyone have
any recommendations as to when it's a good idea to give oxygen to
passengers? I'm not talking about the legal requirements, but just when
it's the smart thing to do. For example, as the pilot I like to start my
oxygen at about 10,000ft even though it's not required until quite a bit
higher. But then again, it doesn't really matter too much if my passengers
have mildly impaired judgement during the flight, even though I'd really
want to avoid that myself.
This is really an academic question since I don't plan to take anybody
that high to begin with, but I'm curious.
Depends on the person, really.
I have a friend who begins to exhibit severe headaches and some cyanosis
(his lips and fingernails start to go purple) above about 8000'. He's
been warned to be very cautious about higher elevations, as he's
probably a prime candidate for mountain sickness. So much for his dreams
of trekking the Himalayas.
That's a bit extreme, but it's worth watching for if you have a
passenger who's never been at altitude before.
Heavy smokers, or anyone with compromised cardiopulmonary function
should be cautious, probably.
There are affordable blood oxygenation meters, typically used by
clipping on a finger, to determine blood O2 levels if you spend much
time at higher elevations without supplementary oxygen.
  #64
Old June 30th 08, 02:20 AM posted to rec.aviation.student,rec.aviation.piloting
Michael Ash
In rec.aviation.student Bob Noel wrote:
In article , Michael Ash
At the risk of turning this thread into something useful, does anyone have
Those oximeter things are pretty inexpensive now. You could use one of those
to monitor your own status as well as your pax's need for supplemental oxygen.
A good point. I was actually looking at the prices the other day. It's
right on my threshold for buying one. The only reason I wouldn't is just
because I so rarely have the opportunity to get up to the altitudes where
it would be useful to have one. Maybe come winter when high-altitude
flying is possible (I'm a glider guy) I'll get one.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
  #65
Michael Ash
In rec.aviation.student Mxsmanic wrote:
Michael Ash writes:
take the risk?
You know, I addressed this point, and you snipped it. Why did you do that?
Mike Ash
Radio Free Earth
  #66
Old June 30th 08, 02:22 AM posted to rec.aviation.student,rec.aviation.piloting
Michael Ash
In rec.aviation.student Steve Hix wrote:
Heaven forfend!
does anyone have
Good point!
Do I correctly understand that you would be happy with monitoring for
symptoms during the flight and making the decision then? I don't want to
do this as the pilot, but only because judgement is one of the first
things to go. For passengers this seems to be entirely reasonable.
Mentioned in another post as well. As I said in the reply, I might well
get one once high-altitude season rolls around again.
Mike Ash
Radio Free Earth
  #67
Old June 30th 08, 02:32 AM posted to rec.aviation.student,rec.aviation.piloting
Mike[_22_]
"Mxsmanic" wrote in message
Mike writes:
Even normally aspirated piston aircraft can generally get to 9000 MSL
even
on hot days.
True, but then you have to start thinking about oxygen.
I have a Skyox 4-place system, so that's not a problem, but you certainly
don't need O2 at 9000'.
And yes, even on a 43° C it's a helluva lot more fun flying a real
aircraft
than flying a computer in a climate controlled room.
That is a matter of opinion. Nothing is fun at 43° C.
Of course. Everyone is entitled to their opinion. Some are just more
relevant than others.
  #68
Old June 30th 08, 02:35 AM posted to rec.aviation.student,rec.aviation.piloting
Mike[_22_]
Mike writes:
The "real thing" doesn't necessarily require a compressor.
So how does it work?
Some older planes had a non-compressor based system that required water. I
assume it was some sort of evaporative cooling setup. I lived in El Paso,
Texas where the temps routinely got above 43° C and I had an evaporative
cooler in my home that worked just fine.
You can also buy aftermarket systems that use ice.
  #69
Old June 30th 08, 03:05 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Mike writes:
That would be a swamp cooler rather than true air conditioning. It would work
in an aircraft if the humidity were low enough, but the weight of the
necessary water sounds like a major drawback.
Still not true A/C, but better than nothing.
I suppose adding a compressor to an engine would raise all sorts of issues
with certification, testing, performance, etc.
  #70
Old June 30th 08, 03:06 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Mike writes:
It doesn't hurt, and it's a good idea at night.
Deadlines to remember Gilan Home Built 5 July 5th 06 10:28 PM
Remember to tip your ... pilot? Brien K. Meehan Piloting 10 February 4th 06 04:25 PM
Remember when? Billposter Naval Aviation 21 August 22nd 05 10:22 PM
Tasha. Anyone remember her? Mike Anselmo Naval Aviation 2 February 15th 04 04:28 PM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 05:03 PM
