Things to remember in very hot weather
  #11
Old June 30th 08, 06:16 AM posted to rec.aviation.student,rec.aviation.piloting
Default Things to remember in very hot weather
On Jun 29, 7:23 pm, Steve Hix
In article PTV9k.157$K%2.34@trnddc02, "Mike"
"Mxsmanic" wrote in message
Mike writes:
The "real thing" doesn't necessarily require a compressor.
So how does it work?
Some older planes had a non-compressor based system that required water. I
assume it was some sort of evaporative cooling setup. I lived in El Paso,
Texas where the temps routinely got above 43° C and I had an evaporative
cooler in my home that worked just fine.
You can also buy aftermarket systems that use ice.
There are also state-change systems that just need a heat source to
drive them, like Dometic kerosene refrigerators. Not very useful for
aircraft use, granted.
Turbine engined airplanes don't have AC compressors. They bleed
some compressed air from the compressor stage of the engine, run that
through an exchanger to cool it, then drop its pressure, which lowers
its temperature a whole bunch. Mixing this really cold air with hot
bleed air provides whatever temperature the pilot wants.
A piston engine with a larger turbocharger could use some of
the same effect but it would be less effective since the pressures are
lower.
Dan
Deadlines to remember Gilan Home Built 5 July 5th 06 10:28 PM
Remember to tip your ... pilot? Brien K. Meehan Piloting 10 February 4th 06 04:25 PM
Remember when? Billposter Naval Aviation 21 August 22nd 05 10:22 PM
Tasha. Anyone remember her? Mike Anselmo Naval Aviation 2 February 15th 04 04:28 PM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 05:03 PM
