Osprey tested in air, at sea, but not in vortex ring state.
Old December 9th 03, 03:32 AM
Henry J. Cobb
Default Osprey tested in air, at sea, but not in vortex ring state.
http://www.signonsandiego.com/news/m...cnsosprey.html
"They decided not to finish a second phase of vortex ring state testing."
-HJC
Old December 9th 03, 03:50 AM
Kevin Brooks
That (your subject line claim) is not what it says. You are mistaking the
questionable claim from a former OT&E guru as meaning that the aircraft was
not tested in vortex ring state conditions, which just ain't the case.
"...has proven its ability to function safely in potentially deadly rapid
descent conditions, the government's top test pilot said...Gross said they
have completed the tests necessary to document the tilt-rotor's response to
the dangerous vortex ring state condition that rotary wing aircraft
encounter when descending too quickly at low airspeed...Gross and other
members of the Osprey test team have said the tilt-rotor encounters vortex
ring state at much higher rates of descent than helicopters and recovers
better because it can move the rotors forward to quickly gain airspeed..."We
believe we have explored this enough," Gross said.
If you are going to try to summarize the gist of the article in your header,
at least get it right.
Brooks
"Henry J. Cobb" wrote in message
om...
-HJC
Old December 9th 03, 07:52 AM
Henry J. Cobb
"Kevin Brooks" wrote in message t...
I don't see any mention that they ever actually went into full vortex
ring state.
What they need to do is send an unmanned Osprey up to say 10k feet,
put it into VRS and have it automatically recover until the software
is solid.
Then you don't have to worry about the pilot reacting in time, the
aircraft will rotate the engines forward and scoot out of trouble on
it's own.
-HJC
Old December 9th 03, 02:33 PM
Kevin Brooks
om...
t...
was
ring state.
You should reread your article, then.
is solid.
it's own.
Why? Other (conventional) rotary aircraft currently within operating
inventopries are susceptable to VRS and manage to handle it by knowing the
limits--why do you think the V-22 should somehow be different? Illogical.
Brooks
-HJC
Old December 10th 03, 02:47 AM
Chad Irby
It's not illogical if the V-22 is so much more susceptible to this that
the frequency of occurence during routine use is far greater than normal
helos.
But that's the thing.
It's not. It's just that they were trying something *very* far off
normal flight regimes, and it bit them.
Most copters damn near have to have their rotors fall off to get that
sort of sink rate.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old December 10th 03, 05:28 AM
Kevin Brooks
"Hobo" wrote in message
Illogical.
Brooks
helos.
But apparently it is not "so much more susceptable" to it.
Brooks
Old December 10th 03, 03:16 PM
Chad Irby
Hobo wrote:
That Arndt guy won't even claim the Germans did it first.
Actually, he did that a couple of weeks ago.
cirby at cfl.rr.com
Old December 10th 03, 03:46 PM
Kevin Brooks
Brooks
What I have heard is that using smaller than normal rotors makes it more
susceptible than normal. Regardless, it has already killed over 20
people and no US service other than the Marines wants it
Not true. The USAF is still anxious to get the Osprey into its special
operations force, and we have had recent reports of interest from the
National Guard Bureau in obtaining Ospreys for the homeland defense role. A
very brief review of available web resources via Google will verify that
your statement is patently false.
and no foreign
country will take it even as a gift
None have been offered.
and there is zero commercial
interest in the technology.
Really? Last I heard the joint Agusta Bell AB 609 civil spinoff had gained
some seventy advance orders, and made its maiden flight this past March. So
far you are exhibiting a very low batting average in terms of accuracy of
your statements regarding this program.
http://www.bellhelicopter.textron.co...r_0307001.html
did it first.
Have you been sleeping of late? He recently actually did exactly that.
Another less than accurate statement you have left with us...
Brooks
Old December 11th 03, 02:29 AM
Henry J. Cobb
"Kevin Brooks" wrote in message et...
http://198.65.138.161/military/syste...t/v-22-vrs.htm
"This asymmetrical VRS phenomenon, which is unique to side-by-side
rotor configurations, will have the initial resultant effect of
inducing a large rolling moment in the yaw direction."
That's what's different about it.
-HJC
Osprey 2 modifications Terry Mortimore Home Built 5 October 24th 04 12:46 AM
Amphib: Coot vs Osprey II Greg Milligan Home Built 9 December 29th 03 02:48 AM
Will the V-22 Osprey be a harder RPG target? Henry J. Cobb Military Aviation 17 November 25th 03 06:15 PM
Squadron formed to test Osprey for combat readiness Otis Willie Military Aviation 0 August 30th 03 08:33 PM
Osprey vs. Harrier Stephen D. Poe Military Aviation 58 August 18th 03 04:17 PM
