On Jul 22, 8:24 am, RN wrote:
I've been looking into this subject as well. My trailer is a 1983, and uses 13 inch wheels. For it, the proper tire appears to be ST175/80R13. Six ply is preferred, and if you want bias ply substitute a D for the R. The most important letters are the ST, as this specifies Special Trailer. As to the make of tire, my research has shown that customers in the USA recommended the Duro, Maxxis, and Denman. Goodyear Marathons have variable reviews, and Carlisle (which also makes Titan) are NOT recommended. I also wanted to replace the wheels, as they are old and rusty. Unfortunately they have an offset, and the 13" wheels I've found have zero offset. Spindleberger says they use a number of different wheels with different specifications, and so far I don't have a definitive answer as to the wheel specs used on my trailer. I did find a local shop that will bead blast the wheels, check for cracks, and then powder coat them - that's probably what I'll do come the end of flying season. -John The tires on my Cobra trailer from the factory are marked 185R14C8PF (102/100N)LT They appear to be GT Radial Max Miler X Load Range D 1875 lb at 450KPA 65# cold They need to be replaced, and the local tire stores seem to be having an issue identifying the correct replacement. A brief web search has also been unsuccessful. Any advice on the correct replacement, or where to find the code for reading the markings would be appreciated. John |
| Thread Tools | |
| Display Modes | |
| glider trailer tires | Ken Ward | Soaring | 18 | October 3rd 06 05:15 AM |
| Glider trailer tires | Greg Arnold | Soaring | 7 | December 7th 04 07:42 AM |
| Replacing Cobra trailer 13 inch tires with larger? | Andy Blackburn | Soaring | 6 | August 19th 04 04:15 AM |
| Cobra Trailer | Soaring | 1 | September 28th 03 02:14 PM | |
| FS: Cobra Trailer | Ed Byars | Soaring | 0 | September 22nd 03 05:47 PM |
