On 27 juil, 11:24, Geoff Vincent
wrote: Hi Bruno, I had an identical problem with our club EW (D) logger only last week. Fixed it immediately by changing the battery. *They thrive on a fresh alkaline 9 volt cell, but seem to be very unforgiving of low cell voltage - ours was a regular "heavy-duty" cell at 8.4 volts (no load). Regards, OK. But how to replace the battery? Do I need to send the Unit back to the producer in UK? Bruno Geoff Vincent Grampians Soaring Club Australia On Sun, 27 Jul 2008 01:36:16 -0700 (PDT), nimbus wrote: The red LED is always "ON" whatever I am doing with the ON/OFF switch. Impossible to know if the unit is switched ON or OFF. With or without antenna gives the same result. Does anybody have an idea of the problem? Bruno |
| Thread Tools | |
| Display Modes | |
| Digital airspace data question -- any FAA data gurus out there? | Tuno | Piloting | 2 | December 27th 07 06:06 PM |
| Flight Data recorders on a 757 - What data? | Al Dykes | General Aviation | 0 | January 1st 07 06:09 PM |
| Ted, your LX logger......... | [email protected] | Soaring | 6 | June 26th 06 05:21 PM |
| Cambridge 302 -or- Borgelt B50 plus data logger | Romeo Delta | Soaring | 25 | May 30th 04 10:50 AM |
| Colibri Data Logger reviewed | TOM RENT | Soaring | 18 | April 16th 04 11:47 PM |
