Texas Parasol
Old August 5th 08, 05:05 AM posted to rec.aviation.homebuilt
clare at snyder dot ontario dot canada
Default Texas Parasol
On Mon, 04 Aug 2008 11:25:05 -0500, cavelamb himself
Stealth Pilot wrote:
On Sun, 03 Aug 2008 16:52:03 -0500, cavelamb himself
To All:
I have recovered some of the files containing the corrections to the
FUSELAGE errors in the Texas Parasol drawings, originally posted in
Feb 2003 but since erased. Also found were portions of the tutorial
on extruded angle and its use for this type of structure.
If you've any interest in this data please provide a publicly
accessible space where the material may be posted. Some of the
drawings are in .jpg format, others are in DeltaCAD. So far, I've not
found any of the text files.
-R.S.Hoover
Taking someone else's work, making changes, and calling it you own.
he called it the Texas Parasol and noted the information as
corrections to errors in the original plans.
he hasnt made any attribution of source.
I cant understand your attitude. Dont you realise that there were
changes needed?
Needed?
Or wanted?
That's my problem with this whole affair.
These "improvements" have never been built (so you don't really know if
it will go together that way or not),
nor tested.
YOU BOTH have made really disparaging statements about the airplane not
being safe because you don't approve od some of the details.
Like the cabane bolts being loaded in tension.
I questioned it too - until I realized how lightly loaded they are.
And how many there are.
You don't like the wing strut fitting attachment.
Granted.
But it has never failed. Not even once.
If one had ever failed, we would have changed the thing years ago.
Before you ever even heard of it.
Bottom line on modifications is this:
If you want to change it, build it that way yourself.
THEN, if it works out ok, THEN publish the mods.
My attitude is simply, If it works, it works.
ANd Richard's own personal plane was NOT built to his published specs.
By his own admission.
** Posted from http://www.teranews.com **
Old August 5th 08, 06:55 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Which one?
Richard
(remove the X to email)
Old August 5th 08, 09:01 AM posted to rec.aviation.homebuilt
Which one?
Or should I ask which oneS.
Because no two have been exactly alike.
Richard
Old August 5th 08, 02:32 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
To All:
-R.S.Hoover
changes needed?
Needed?
Or wanted?
nor tested.
not correct. in my case I had an aeroengineer friend of mine look at
the details. his comments were not polite.
as a result of the deficiencies in your design he has been tempted to
publish a similar design backed up by full stress calculations a built
and statically tested to destruction fuselage.
unfortunately he is a very busy boy. he has done the FEA but hasnt
finished building the fuselage.
you should follow Chuck Slusarcik's lead and have a proper stress
analysis done. your spar needs mods.
Stealth Pilot
Old August 5th 08, 02:46 PM posted to rec.aviation.homebuilt
Good Bye
Old August 5th 08, 09:17 PM posted to rec.aviation.homebuilt
On Mon, 04 Aug 2008 23:55:26 -0500, cavelamb himself
Which one?
I don't know - the last one? Or any? Bring us up to date.
Old August 10th 08, 06:12 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
changes needed?
Regardless, Mr Hoover advanced no claims to anyone
else's designs.
FF
Old August 11th 08, 08:42 AM posted to rec.aviation.homebuilt
else's designs.
Give it up, Fred.
He is making changes to primary structure and claiming they
correct "faults" in the original design.
His suggestions have not been built or tested.
In fact, he has never built and flown ANY airplane.
If he's not putting a claim on it, dunno what is.
Actually, he damned well better put his name on it.
Because it's sure not MY work.
I do NOT recommend these modifications to prospective builders.
All because we violated his cast-in-stone rules of thumb.
Richard
Old August 11th 08, 10:49 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
What was the resolution of the supposed dimensional discrepency
discussed he
http://www.airtalk.org/next-vt20548....r=asc&start=15
Or has that been addressed over on the Yahoo TP group?
FF
Old August 12th 08, 01:01 AM posted to rec.aviation.homebuilt
discussed he
FF
Fred,
Do YOU know what he's talking about?
Heath Parasol plans, 103 trimmable? Chris Wells Home Built 2 July 1st 07 01:36 AM
Texas Parasol and 1/2 VW Engine...... WC Home Built 11 June 4th 07 10:39 PM
Looking for a good set of parasol plans Mike Gaskins Home Built 11 January 24th 07 05:10 AM
Texas Parasol Plans... Richard Lamb Home Built 82 March 12th 06 08:19 AM
Richard Lamb and the Texas Parasol Plans ...and Sirius Aviation Richard Lamb Home Built 12 August 9th 05 09:00 PM
