I have had pretty good luck with making my own simple camera mounts.
They are easy to build. First, 99.999% of cameras come with a screw tripod mount on the bottom which is a 1/4" bolt with 20 threads per inch (commonly called a "1/4-20", pronouced quarter-twenty). Get yourself a 1/8" thick piece of aluminum about 4" square. Drill and tap a 1/4-20 hole in the middle. Screw in a short (about 1/4" long) 1/4-20 bolt into the tapped hole. Alternately, you can use thinner aluminum, drill a through hole and put a nut on the bolt between the aluminum and the camera. Attach this to your glare shield with gaffer's tape (used by the movie industry). Its as strong as duct tape but doesn't leave sticky residue. Here is a source. http://www.goodbuyguys.com/catalog/p...products_id/51 You may have to play with bending the aluminum plate if your glare screen is not flat. I have a DG and it's instrument pod is perfectly flat on top. Screw on your camera. You may have to play with to get it both tight and oriented in the right direction, either forward or at the wing tip (or back at yourself!). Here is a video taken by myself with my digital camera following a friend in for a landing. http://www.youtube.com/watch?v=VCPMAAF7pMg |
| Thread Tools | |
| Display Modes | |
| Lost camera | Dick[_3_] | Soaring | 0 | April 8th 08 10:12 PM |
| Camera Litigation in UK | [email protected] | Soaring | 12 | January 28th 06 08:16 PM |
| SOARING article on camera mounts | Charles Petersen | Soaring | 4 | June 25th 05 08:02 AM |
| Camera Mounts & Gliding Photography | Charles Petersen | Soaring | 0 | June 18th 05 11:35 AM |
| A-4 gun camera question | Guy Alcala | Naval Aviation | 0 | April 10th 04 07:33 AM |
