"SeeYou" does it for you and is easy to use.
At 00:49 22 September 2008, GM wrote: Hi all, does anybody have a usable, step-by-step decription of the LX-Polar program? The instructions that came with the manual of my LX-20-2000 are pretty useless. I have a polar curve for my glider and I am trying to calculate the factors a, b and c used to define the polar. Thanks, Uli Neumann |
On Sep 22, 3:07*am, Big Wings wrote:
"SeeYou" does it for you and is easy to use. At 00:49 22 September 2008, GM wrote: Hi all, does anybody have a usable, step-by-step decription of the LX-Polar program? The instructions that came with the manual of my LX-20-2000 are pretty useless. I have a polar curve for my glider and I am trying to calculate the factors a, b and c used to define the polar. Thanks, Uli Neumann- Hide quoted text - - Show quoted text - Uli, I am assuming you want to use the polar for use in a computer for final glide and other flight performance calculations. If so, here are some hopefully useful and not too pedantic thoughts. If you are working from a measured polar you need to pick three points off the curve. Choose well if you intend to get good advice from your computer. I recommend one point at best L/D, one at your typical cruise speed, and one at a fast final glide speed. I use 60, 85 and 114 knots on my ASW-27B - but I fly in the west. Since you are fitting a curve to three points the curve will vary a bit from the actual polar at points away from the ones you pick. You can use the LX program or solve the equations yourself (or both as a check). Basically, you are solving for the quadratic polar equation Y=aX^2+bX+c, where Y is sink rate in knots and X is airspeed in knots (you can use other units, depending on what your computer uses). With three points (call them: Xone,Yone; Xtwo,Ytwo; Xthree,Ythree) you have three equations in three unknowns and the solution is: a=((Ythree-Ytwo)/((Xthree-Xtwo)*(Xthree-Xone)))-((Yone-Ytwo)/((Xone- Xtwo)*(Xthree-Xone))) b=(Yone-Ytwo+a*(Xtwo^2-Xone^2))/(Xone-Xtwo) c=Yone-a*(Xone^2)-b*Xone This is the basic format for use in a spreadsheet, but you have to make the references point to actual cells. You should also know the wing loading of the polar you are using to get the points so you can adjust for the actual wing loading of your specific glider. If R is the ratio of the weight you want to the weight the polar was measured at (typically what you want is the flying weight dry for YOUR glider with you and everything you typically carry). The adjustment is simple to go from old (wing loading for the measured polar) to new (wing loading for your glider): a(new)=a(old)/R^0.5 b(new)=b(old) c(new)=c(old)*R^0.5 Of course in the real world gliders don't always perform to the measured or factory calculated polar for a whole bunch of reasons so use your computer's advice with care. Hope that's helpful. 9B |
| Thread Tools | |
| Display Modes | |
| Discus 2c polar | Brett | Soaring | 5 | October 9th 09 03:17 PM |
| ASW 20 BL polar file | Steve Leonard | Soaring | 4 | November 14th 07 06:34 PM |
| K8 Polar | Mike Schumann | Soaring | 2 | July 22nd 06 05:10 PM |
| Polar Glider Program | WDM | Soaring | 1 | January 18th 05 02:17 PM |
| Is anyone still interested in CuSoft "Polar Explorer" program for PC? | Branko Stojkovic | Soaring | 1 | July 26th 03 02:06 AM |
