#21
On Oct 29, 1:14*pm, gen wrote:
Very interesting discussion. I myself use SN10 + PDA(SeeYou). Besides what have been mentioned, SeeYou also leaves traces which are useful to come back at exactly the same place in wave, etc. I think the original question is easy to answer.. You can buy everything you need to make the cable at Radio Shack for less than $10, so just go for it and see if you like it. -Gen The original question was likely answered the other way. I read that Kirk specifically wanted wanted to see the benefit of ehnanced wind/ air data for SeeYou - then don't bother as there is no enhanced data communicated. You can just stay with a separate GPS source for the PDA. There may be other benefits of communicating Mc. etc settings however that was not the question. Darryl |
gen wrote:
Very interesting discussion. I myself use SN10 + PDA(SeeYou). Besides what have been mentioned, SeeYou also leaves traces which are useful to come back at exactly the same place in wave, etc. I think the original question is easy to answer.. You can buy everything you need to make the cable at Radio Shack for less than $10, so just go for it and see if you like it. -Gen I actually modified my SN10B, Volksloger, PDA cabling two years ago in order to get SN10 Data into my PDA - This turned ut to be a big waste of time! The problem was that SN10 also appended its own pressure altitude data to the NMEA data stream together with the pressure altitude data from the Volkslogger. These two pressure altitude data may typically differ by at least 100meter. While flying close to the upper airspace boundary, it was totally random if SeeYou used the Volkslogger or the SN10 altitude to calculate an airspace warning. This resulted in lots of false warnings when the SN10 produced a higher altitude reading than the Volkslogger, and a single time resulted in a airspace violation when the SN10 decided that I was lower than the Volkslogger logged. Most of the time it was only pure annoying - I decided to rip out the new cabling at the last annual. Ole John Aske, Ls8T |
Thanks for all the feedback. I'm happy with my current SN10/PDA
setup, just looking for small enhancements. I currently have both setup totally independent of each other, with separate GPS sources (and even separate batteries). I'm considering on adding a GPS splitter to allow either GPS to drive the PDA, for redundancy, so while at it was wondering if the SN10 vario/altitude inputs would enhance SeeYouMobile (don't really care about wind - they already match pretty closely, and the SN10 works just fine for that). Thinking mainly about the vario and final glide functions. JJ, yeah, I know this is probably overkill, but it's fun (and PDAs are cheap) and I've lost single systems on long flights before. Nice to have a backup... For Dave: How about updating how the SN10 handles USA start/finish rules? And since now an AST is essentially an AAT with 1 mile areas and no time limit, how about combining the two to get rid of the need to go to the SETUP menu to create or change an AAT task? And figure final glide to the finish circle (i.e. 500' at one mile), not the finish turnpoint/airport (I can use the alternate page for that)? And PLEASE, get rid of those annoying announcements ("You have entered the start/turn/finish circle, press HELP to continue") - I know that! If no action is necessary, then either let me choose to not see those "info" announcements, or make them go away on their own after a few seconds, without any button pushes. Last request: Display digital altitude to the nearest 10 feet. That is the convention used in all the current civil and military digital avionics displays, for a good reason - the rapidly changing single feet (or meter) digits are distracting and serve no useful purpose - and can even make the altitude trend hard to see. Input altitudes to the nearest feet is fine, just round off the final glide altitude needed and current altitude displays to the nearest 10 feet. Trust me, try it, you'll like it! Cheers! Kirk SN10 user for the past 8 years and loving it. |
Hi John,
you can solve this problem by deactivating the $PGCS1 NMEA sentence at the Volkslogger. Then Seeyou gets pressure height data only from SN10 an position data from Volkslogger. Falk Ole John Aske schrieb: gen wrote: Very interesting discussion. I myself use SN10 + PDA(SeeYou). Besides what have been mentioned, SeeYou also leaves traces which are useful to come back at exactly the same place in wave, etc. I think the original question is easy to answer.. You can buy everything you need to make the cable at Radio Shack for less than $10, so just go for it and see if you like it. -Gen I actually modified my SN10B, Volksloger, PDA cabling two years ago in order to get SN10 Data into my PDA - This turned ut to be a big waste of time! The problem was that SN10 also appended its own pressure altitude data to the NMEA data stream together with the pressure altitude data from the Volkslogger. These two pressure altitude data may typically differ by at least 100meter. While flying close to the upper airspace boundary, it was totally random if SeeYou used the Volkslogger or the SN10 altitude to calculate an airspace warning. This resulted in lots of false warnings when the SN10 produced a higher altitude reading than the Volkslogger, and a single time resulted in a airspace violation when the SN10 decided that I was lower than the Volkslogger logged. Most of the time it was only pure annoying - I decided to rip out the new cabling at the last annual. Ole John Aske, Ls8T -- Falk Rüth K6-Team http://www.k6-team.de |
I'm considering on adding a GPS splitter to allow either GPS to drive the PDA, for redundancy, Roger that, only I'm considering a switch that would allow me to select either one of my 2 GPS's to drive the SN10. The thing is worse than usless if the GPS signal is lost.............it keeps providing info back to where the GPS stopped giving inputs. Am I correct in assuming I can send the red and white wires from both Model 20 GPS's to the SN10 with the NMEA signal (red) going to a SPDT switch with one GPS (red) input on the top and the other GPS (red) on the bottom of this "selector" switch? Dave, Roger on Kirk's requests for SN10 updates......... "your inside the start cylinder" and "you have a good start" can drive me nuts as I loiter near the edge of the gate. Maybe have these alerts go away in a few seconds. JJ |
On Oct 28, 2:44*pm, JJ Sinclair wrote:
I use the 'options' page on my SN10, keep it set on the nearest landable field (and next nearest landable). What it tells me is exactly what I need to know, distance and altitude needed to get there. No need to be looking at a sectional. When I ask the local PDA drivers, simple questions like; how long you been on course or what's your speed so far.................their stumpen dor an answer! Guess what I should be asking is; What are you looking for in a PDA that isn't already on your SN10? JJ JJ, You must asked have asked local uninformed PDA drivers. With mearly one click of the wand. SeeYou Mobile has a very informative page that shows the following: The statistics page gives you detailed information on Thermals and the flight. To change the content of the statistics pane, tap on it to switch between .. Flight statistics .. Task statistics .. last 60 minutes statistics Thermals panel graphically displays the last four thermals where the left most is newest. At the top of each bar you can see the Thermal average. The height of each bar represents the entrance and departure from each thermal relative to the other four. The number on the right is average for the last four thermals. Use it for your MacCready setting if you wish. Flight statistics gives averages for the Lift, Average speed, Distance flown, circling percentage and duration of flight. Distance is the same as Optimized distance in the "Opt" navbox. Task statistics gives averages achieved since the start of the Declared task. Last 60 minutes statistics gives averages achieved on the Declared task or the Optimized task in the last hour. Richard, www.craggyaero.com |
On Oct 27, 1:35 pm, "kirk.stant" wrote:
Does anyone have any experience driving SeeYouMobile from an SN10B, using both the GPS data and the vario/wind/air data that the SN10 can now transmit to a PDA? Wondering if it is worth the trouble to have a new SN10 wiring harness made to work with my PDA. TIA, Kirk 66 Kirk, I use seeyoumobile with an sn-10b. I also have the cable that supports the supplemental info from the sn-10 into seeyoumobile. Since I went with the new cable the seeyou wind calc seems to be in better agreement than in the past when using the gps data alone. However, I always rely on the final glide calc from the sn-10 so the possible increase in accuracy in seeyoumobile is of limited value to me. I would only go with the new cabling if you were already planning to make a change behind the panel. Regards, XJ |
#28
On Oct 31, 7:29*am, wrote:
On Oct 27, 1:35 pm, "kirk.stant" wrote: Does anyone have any experience driving SeeYouMobile from an SN10B, using both the GPS data and the vario/wind/air data that the SN10 can now transmit to a PDA? Wondering if it is worth the trouble to have a new SN10 wiring harness made to work with my PDA. TIA, Kirk 66 Kirk, I use seeyoumobile with an sn-10b. I also have the cable that supports the supplemental info from the sn-10 into seeyoumobile. Since I went with the new cable the seeyou wind calc seems to be in better agreement than in the past when using the gps data alone. However, I always rely on the final glide calc from the sn-10 so the possible increase in accuracy in seeyoumobile is of limited value to me. I would only go with the new cabling if you were already planning to make a change behind the panel. Regards, XJ Well that must be a special cable indeed (maybe made by Placebo, Inc.? I hear their stuff really works great). Have a re-read of this thread. Darryl |
#29
Kirk,
I use seeyoumobile with an sn-10b. I also have the cable that supports the supplemental info from the sn-10 into seeyoumobile. Since I went with the new cable the seeyou wind calc seems to be in better agreement than in the past when using the gps data alone. However, I always rely on the final glide calc from the sn-10 so the possible increase in accuracy in seeyoumobile is of limited value to me. I would only go with the new cabling if you were already planning to make a change behind the panel. Regards, XJ XJ, how about the thermal information? Thermal history, centering page, etc? Does that appear to be more useful than the GPS-derived information? Kirk |
#30
On Oct 31, 1:07 pm, "kirk.stant" wrote:
Kirk, I use seeyoumobile with an sn-10b. I also have the cable that supports the supplemental info from the sn-10 into seeyoumobile. Since I went with the new cable the seeyou wind calc seems to be in better agreement than in the past when using the gps data alone. However, I always rely on the final glide calc from the sn-10 so the possible increase in accuracy in seeyoumobile is of limited value to me. I would only go with the new cabling if you were already planning to make a change behind the panel. Regards, XJ XJ, how about the thermal information? Thermal history, centering page, etc? Does that appear to be more useful than the GPS-derived information? Kirk Kirk, Sorry, I haven't used the seeyou thermal features enough to comment on them. XJ |
| Thread Tools | |
| Display Modes | |
| SeeYou Mobile 3.0 now available | [email protected] | Soaring | 0 | February 4th 08 01:17 PM |
| Using mobile SeeYou | Robert Hart | Soaring | 3 | May 10th 06 10:42 PM |
| SeeYou MOBILE v2.0! | Roy McMaster | Soaring | 10 | July 12th 04 01:25 AM |
| Mobile SeeYou & Winpilot | Ian Molesworth | Soaring | 8 | March 25th 04 02:07 AM |
| SeeYou Mobile | Robert Fidler | Soaring | 0 | March 17th 04 05:18 PM |
