#11
"Ace" wrote in message ... On Fri, 6 Mar 2009 13:11:32 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: "platypus" wrote in message om... The thing that everyone seems to forget when promoting automotive engines for aircraft is that most piston aero engines have a very hard life. Take-off and climb is full power or very nearly, then they throttle back to cruise at 75% or thereabouts. The only roadgoing vehicles that approach that sort of use are in motorsports, and how long do they last? Not true at all. I drove a 6500 series Chevy dump truck years ago, always pulling a Case 580C back hoe. It was 100% power almost all the time, and always at lease 75% on the highway. But that;s true of nearly all agricultural vehicles, which is why they tend to use understressed, low-revving, low-tech motors. And just because you can drive them on the road doesn't make the road-going vehicles. These were not ag vehicles. Passenger car engines were popular back then in all the class C motor homes, school buses, and light weight dump trucks. My Chevy was a 350-2v with probably nothing more than the heavy duty 4 bolt main block. It also had a 4 speed manual transmission, and 2 speed rear. I would commonly shift the low gears as high a 4000-5000 rpm. The gross weight on the entire package was around 30,000 lbs. |
| Thread Tools | |
| Display Modes | |
| There I was, flat on my back... | Kyle Boatright | Home Built | 5 | August 16th 07 06:34 AM |
| Flat tire | Viperdoc[_4_] | Piloting | 11 | June 4th 07 03:57 PM |
| Flat Tires? | Jay Honeck | Owning | 40 | August 31st 05 02:59 AM |
| Wrinkly flat panels | [email protected] | Home Built | 27 | March 6th 04 03:12 PM |
| Flat Spin | JJ Sinclair | Soaring | 34 | February 10th 04 06:57 PM |
