I have a friend who has adapted a V8 engine into his Long Eze. It is direct drive with no PSRU. He has flown cross country from CA to Oshkosh several times. As far as I can tell he has not had any engine problems. Wow, I would like to see that set-up. Did he have to move the fire wall forward, for ballance? I would not use any auto engine, without at least an additional bearing for thrust added to the crank. I had a 350 chevy crank in a van that was 25 thousands over spec, in end slop. That was without any thrust on the engine. -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| There I was, flat on my back... | Kyle Boatright | Home Built | 5 | August 16th 07 06:34 AM |
| Flat tire | Viperdoc[_4_] | Piloting | 11 | June 4th 07 03:57 PM |
| Flat Tires? | Jay Honeck | Owning | 40 | August 31st 05 02:59 AM |
| Wrinkly flat panels | [email protected] | Home Built | 27 | March 6th 04 03:12 PM |
| Flat Spin | JJ Sinclair | Soaring | 34 | February 10th 04 06:57 PM |
