How do I fly this approach?
Old March 16th 09, 06:57 PM posted to rec.aviation.ifr
Sam Spade
Default How do I fly this approach?
Mxsmanic wrote:
Sam Spade writes:
You did it wrong about every way possible.
Okay. Please describe the right way ... and provide references.
First, by what authority did you descend 700 feet flow the MEA for V-187
simply because you were within 25 miles of AST? The MEA is 5,000 all
the way to AST VOR. That is basic chart reading.
The plate gives the MSA within a 25-nm radius. Once I was within the 25-nm
radius, I could safely descend to the MSA, and I did so, because it
facilitated entering the approach.
You must think you are in Canada. MSAs are emergency altitudes only in
the U.S.
Then, when you turn around at about 12 miles and headed north you
departed protected airspace.
I'm not sure what you mean by protected airspace. Once I was clear of the
Seattle Class B, the rest of the flight was conducted entirely in Class E
airspace, right up to landing.
Airspace protected from obstacles.
The 19 DME arc is available only to non-radar arrivals on on V-27
(R-328) from the northwest or V-27 (R-166) from the south. For any
other arrival the approach begins at AST via the feeder route to KARPEN,
then the procedure turn.
Okay. How do you know this? Explain where and how it is documented on the
plate, or where it is documented elsewhere, so that I can look it up.
Chief counsel's November, 1994 legal ruling on use of IAP's in non-radar
conditions. It is available on Summit's Aviation Reference Library:
The letter states in part:
"You also ask whether a Distance Measuring Equipment (DME) arc
initial approach segment can be substituted for a published IAF along
any portion of the published arc. A DME arc cannot be substituted for a
published IAF along a portion of the published arc."
Old March 16th 09, 07:48 PM posted to rec.aviation.ifr
Mxsmanic
Sam Spade writes:
the U.S.
Even if I grant this (the FARs mention it but do not define it), how would I
then determine the minimum altitude when moving from the airway to the DME
arc? The airway MEA applies only on the airway, which I had left. The
sectional MEF for the quadrant in which I was operating was 1100 feet below
the MSA.
If I'm off-airway, and not within an area for which a MSA is published, how do
I determine my minimum instrument altitude? If the MEA on the airway had been
14,000 feet, how would I get from that altitude to the appropriate altitude to
capture the ILS glide slope in the distance available to me?
By remaining at or above the MSA, I was protected from obstacles. This is true
whether an emergency existed or not.
I have the letter in front of me, but I do not see the relevance of it.
Explain how it applies here.
I also don't see any indication of feeder routes on the IAP plate. Can you
point these indications out to me?
I'll ask again: Describe exactly how I should have flown this, and explain
why, step by step.
Old March 16th 09, 08:47 PM posted to rec.aviation.ifr
Sam Spade
Mxsmanic wrote:
Sam Spade writes:
the U.S.
the MSA.
why, step by step.
If you don't see the relevance of the letter and you don't understand
MSAs, then just go play with yourself. You are up to the same bull****
game.
Old March 16th 09, 09:03 PM posted to rec.aviation.ifr
Viperdoc[_3_]
Classic example of Anthony thinking that by reading something (although not
understanding) he somehow gains expertise, which is of course not the case.
His questions and responses clearly demonstrate his fundamental lack of
knowledge of how the system works, as well as how to fly instrument
procedures.
Perhaps he should go back to asking about the location of the ejection seat
handle in a Baron.
Old March 16th 09, 09:09 PM posted to rec.aviation.ifr
Sam Spade
procedures.
handle in a Baron.
It all goes beyond his inability and unwillingness to learn. He
displays a profound personality defect by the need to ask for technical
help then attacking those who try to help.
I don't know why the nut house permits him access to the Internet.
Old March 16th 09, 09:11 PM posted to rec.aviation.ifr
Viperdoc[_3_]
Given his history, it's no wonder why he can't find a job in either the US
or France, yet he only blames others and never takes responsbility himself.
Old March 16th 09, 10:46 PM posted to rec.aviation.ifr
Tom S.[_2_]
"Sam Spade" wrote in message
not understanding) he somehow gains expertise, which is of course not the
case.
procedures.
seat handle in a Baron.
It all goes beyond his inability and unwillingness to learn. He displays
a profound personality defect by the need to ask for technical help then
I don't know why you feed the troll then wonder why he keeping popping up.
Matt B.
Old March 16th 09, 11:36 PM posted to rec.aviation.ifr
Sam Spade
case.
procedures.
Matt B.
Because I mistakenly thought he was asking some quasi-legitimate
questions. Or, perhaps I just wanted to rub his face in his unending
ignorance, not stopping to realize it is impossible to have an
intelligent discussion with a troll. Shame on me.
Old March 19th 09, 02:42 PM posted to rec.aviation.ifr
a[_3_]
On Mar 15, 5:34*pm, Mxsmanic wrote:
Kindly take a look at the ILS runway 26 approach to Astoria (KAST). *I tried
to fly this in my sim and I'm not at all sure that I did it correctly.
In my case, this is what I did: *I was on V187 from Seattle at 6000. *Once I
was within 25 nm of AST, I descended to 4300. *About 12 nm away from AST, I
turned roughly north and flew back out to 19 DME from AST, then turned east to
follow the 19 DME arc until I was within a few degrees of the localizer
course. *At that point I started a turn towards the localizer and armed the
autopilot, which captured the localizer and glide slope immediately and took
over. *About a mile away from the airport I disengaged the AP and flew the
landing by hand.
Was this correct? *I'm confused by the references to the NDB and the pointers
towards the east and the procedure turn. *Do I have multiple options for this
approach? *Was the way I flew it one of them? *Or what?
I almost thought that maybe I was supposed to fly to the VOR then outbound to
the NDB then make a procedure turn and come back in. *But the DME arc had IAFs
at each end so I finally figured I could just come in towards the VOR then fly
back out to the arc and finally turn towards the airport, which is what I did.
There is absolutely nothing ambiguous about this approach. Any rated
pilot, from 50 miles out at 6000 feet on V187 would not be happy to
hear center say "Cleared ILS 26, report to the tower at the outer
marker inbound" but would know what to do. It would be the same thing
we would do had we lost radio communication and our last clearance was
to that airport. Have you any clue as to why we would not be happy to
get that clearance?
What would YOU do? And provide references.
Old March 19th 09, 05:08 PM posted to rec.aviation.ifr
landing by hand.
There is absolutely nothing ambiguous about this approach. *Any rated
get that clearance?
What would YOU do? And provide references.- Hide quoted text -
- Show quoted text -
Apparently I don't understand the question. This approach does not
seem to be unusual, and your scenario would not make me unhappy
(unless you just don't like doing full approaches).
Maurice Givens
CSEL, CSES, CMEL, CFI-A, CFI-I, AGI, IGI
CAP Check Pilot
ILS approach and VOR Alpha Approach video DOCTOR Mary Ellen Hall McIntire Yasay, Ph.D, (Div.) Piloting 3 May 22nd 08 01:52 PM
ILS approach and VOR Alpha Approach video [email protected] Instrument Flight Rules 10 May 22nd 08 02:15 AM
ILS approach and VOR Alpha Approach video [email protected] Piloting 4 May 17th 08 01:19 PM
Garmin 430 rquestion- does the approach always have to be activated via "activate approach"? Terence Wilson Instrument Flight Rules 46 February 18th 08 05:46 PM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
