what engines are making successful aero engine conversions?
Old May 14th 09, 10:08 PM posted to rec.aviation.homebuilt
Anthony W
Default what engines are making successful aero engine conversions?
Honda makes a nice little 4 cylinder engine that is used in their
personal watercraft that I've always thought would be a good small plane
power plant but I've not been able to try it.
Tony
Dear Stealth (and the Group)
We may be looking it this the wrong 'way 'round.
There are plenty of engines which offer excellent power-to-weight
ratios. Unfortunately, they do so at rpm's which make them
impractical for slinging a prop UNLESS a PSRU is used.
A good case-in-point is the Rotax. The Rotax engine is only 1300cc
but it is designed to operate near 6000 rpm. What makes the engine
successful is the PSRU between the engine and the prop.
There are two obvious conclusions we can draw from this. The first is
that the engines themselves, despite any practical combination of cam
& cooling, are simply too small to be used with the propeller mounted
directed to the crankshaft. (This leads to another series of
questions worthy of discussion but which I will leave untouched at
this time.)
The second point is that the PSRU, which does NOT enjoy the same TBO
as the engine itself, has been designed specifically for this
application, taking advantage of the engine's torque & power curves,
and including mechanical features that make it suitable for the
mounting of a propeller; mounting the engine to an airframe and so
forth.
It may then be argued that we are wasting our time by focusing on the
ENGINE; that we should be devoting our energies to a suitable PSRU
that may be attached to a WIDE VARIETY of engines.
Having devoted most of my attention to the VW engine, I have little to
offer the Group should the discussion turn to PSRU's but it would seem
that the hand-maiden of these light-weight, powerful engines MUST be
an automotive TRANSMISSION having similar features of light-weight and
power-handling capacity. Here again, I lack the background and
experience to do more than mutter; there are aspects of PSRU's,
transmissions and torque converters about which I know nothing at
all... other than the fact they must exist (since the engines exist).
At the very least, I know the GEARS must exist.
Were I in Western Australia, rather than curse the darkness (and wish
for a Corvair to suddenly appear on my doorstep) I think I would light
a single candle by diving into whatever came my way in the form of
light-weight engines and trannies.
I suppose there has to be a clutch in there somewhere, so that means
I'm probably looking at a flywheel as well... fate stacking the weight
against my urge to fly. But perhaps some of those powerful, light-
weight engines ARE large enough to be able to drive a prop directly,
even if I had to find someone to grind me a new cam.
Liquid cooling need not be a road-block IF we begin by throwing out
the stock radiator. With ram-air of 90mph or so available for
everything other-than take-offs, a pair of heater cores may provide
enough area to keep things in the green. Plus, there is a couple of
quarts of oil that may also be pressed into service as an auxiliary
coolant.
The point of all this is that the lack of Volkswagens or other air-
cooled engines should not be taken as an automatic out. If push comes
to shove I could always convert a stray Holden, offering it up to
something like a Pietenpohl.
-R.S.Hoover
FS: Zero time Aero Vee / Monnett engine [email protected] Aviation Marketplace 0 November 30th 05 06:02 AM
