what engines are making successful aero engine conversions?
Old May 21st 09, 01:59 AM posted to rec.aviation.homebuilt
Default what engines are making successful aero engine conversions?
On May 20, 2:15 pm, bildan wrote:
I wouldn't think so. The crank is light enough to use as a dumbbell
and that's heavier than the cylinder blocks. Just guessing of course,
but I'd say 180 lbs for 100HP which is better than an O-200.
The TCDS says the O-200-A is 190 lb. My experience with the engine
makes me wonder about the 100-hp claim. The C-90 I flew had more pull.
Dan
Old May 21st 09, 03:53 PM posted to rec.aviation.homebuilt
On May 21, 5:21 am, Stealth Pilot
my docs say "rated horsepower" which makes me think that there is a
calculation used to derive the figure not an actual 2750rpm
measurement. the 74hp at 2500 rpm seems to be measured.
They normally take a brake horsepower reading, with the engine at
redline RPM and full throttle. Torque times RPM times 6.28 divided by
33,000 gives HP.
BUT:
The O-200 makes its 100 hp at 2750. The C-90 its 90 hp at 2475.
Everyone knows that drag increases by the square of the increase in
speed, so the O-200's prop theoretically has 19% more drag than the
C-90's. The C-150's prop is narrower and I think a bit shorter than
the prop on the Aircoupe I flew with its C-90, so its drag might be a
bit less to start with, but overall the losses will still be higher at
2750.
So adding RPM to gain hp is a poor way to go. That's why PSRUs
are better than direct-driving a tiny prop at 4000 RPM. And it's also
why a 110-hp Corvair, if it's running at 3300 or some such RPM, isn't
going to outdo an O-200.
Dan
FS: Zero time Aero Vee / Monnett engine [email protected] Aviation Marketplace 0 November 30th 05 06:02 AM
