E-2D and Maritime Security
Old May 29th 09, 02:18 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Default E-2D and Maritime Security
On Fri, 29 May 2009 23:01:24 +1000, "Geoffrey Sinclair"
snipped for brevity
Fascinating story; thanks!!!!! :-)
Old May 29th 09, 05:52 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Aurelius
Mike pisze:
http://lexingtoninstitute.org/docs/857.pdf
Well, this plane carries APY-9 brand-new phased-array radar which is
capable to guide new Standard SM-3 and SM-6 missiles. Therefore it can
revolutionarize maritime combat to some degree, in my view!
Old May 30th 09, 02:27 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
hcobb
On May 28, 10:18 pm, "Don Harstad" wrote:
Japan has used E-2s I believe.
The French fly them from a carrier. Taiwan flies them in a land-based mode.
Israel used to fly them.
Don H.
Japan has not used them from carriers and the next Frog carrier (to
match the E-2D timeframe) won't be able to.
Plans for a half dozen Nip carriers would bring Chinese pressure on
North Korea faster than you can say "Kim Impossible".
-HJC
Old May 30th 09, 02:29 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
hcobb
On May 29, 3:26 am, LIBERATOR wrote:
On May 28, 8:28 pm, Mike wrote:
E-2D and Maritime Securityhttp://lexingtoninstitute.org/docs/857.pdf
Amazing photo and profiling but isn't this all better done from a
satellite? The plane has a limited duration of being airborne.
If you have full carriers you can send Super Hornet tankers up to
refuel them.
-HJC
Old May 30th 09, 02:31 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Alistair Gunn
In sci.military.naval hcobb twisted the electrons to say:
Seeing as how the French haven't decided if they're going to get a second
carrier yet[1] how can you be so sure that said carrier when/if it turns
up will not be compatiable with the E-2?
[1] http://www.reuters.com/article/rbssIndustryMaterialsUtilitiesNews/idUSL0635303320080506 or http://tinyurl.com/ln9yyt
These opinions might not even be mine ...
Let alone connected with my employer ...
Old May 30th 09, 02:38 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
hcobb
Even better. Zero carriers equals zero capability.
-HJC
http://business.timesonline.co.uk/to...cle4183255.ece
President Sarkozy ditches Franco-British carrier project
Old May 30th 09, 03:24 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Alistair Gunn
Except that they already have a carrier with E-2 capability, thus
indicating greater than zero capability ...
That article predates mine, he may have ditched the idea of an
Anglo-French carrier project (wise idea for both sides IMHO) back in June
2008 but he has not, of May 2009, decided whether there will be a 2nd
carrier ... Do try and keep up!
Global Hawk RQ-4N UAV to Perform Maritime Surveillance for the U.S.Navy [email protected] Naval Aviation 5 May 6th 08 02:07 PM
Canadian Maritime Airports: Request for Info David Megginson Piloting 0 July 22nd 04 03:24 PM
Boeing 737 Maritime aircraft JD Naval Aviation 56 December 31st 03 12:19 AM
LIMA 03 - air and maritime show in Langkavi, Malaysia, Sept. 30 tbp Military Aviation 0 September 5th 03 12:12 AM
LIMA 03 - air and maritime show in Langkavi, Malaysia, Sept. 30 tbp Naval Aviation 0 September 5th 03 12:12 AM
