Photos of a sectioned Pobjoy Niagra
Old June 8th 09, 10:02 PM posted to rec.aviation.homebuilt
Veeduber[_2_]
Default Photos of a sectioned Pobjoy Niagra
On Jun 8, 8:00*am, Stealth Pilot
veedubber I've emailed a copy of the scans for your blog.
Dear Stealth,
Thank you very much. I will keep an eye on the mail box. It is
nearly 300 feet from the house and has a history of losing things.
Should you be interested, the Weak Force Press ( http://www.weakforcepress.com
) in Huntsville, Alabama has a copy of the Operation, Installation,
and Maintenance manual of the Pobjoy "R" Type Aero-Engine on a CD.
They will be happy to send you a copy for about $16 USD (more in Oz
dollarettes, of course :-)
As a point of interest to all, under the Maintenance Schedule are
listed:
Check tappet clearances and (apply)graphite grease (to ) pushrod
ends
Every 50 hours:
Clean & adjust Sparking Plugs.
Clean & adjust Magneto Contact Breaker Points
Clean & adjust Carburetter Jets & Float Chamber by removing
Jets and flushing with petrol
Remove the Rocker caps and using the Grease Gun provided:
Fill the Rockers with High Melting Point Grease
Every 100 to 150 hours:
Top Overhaul the Engine. (!!)
After 300 to 450 hours:
Remove the engine from the airframe and have it completely
overhauled
There are some other equally interesting items that make the manual
something of a trip into the past. From the cam timing it's obvious
the engine was never designed to drive a prop directly, but was
intended to be used with a two-bladed metal prop turning 1400 rpm at
an engine speed of 3000 rpm.
-R.S.Hoover
HMS Warrior - 1950s Flightdeck Photos [7 photos, 'bout 350kb) Andrew[_5_] Aviation Photos 13 August 13th 08 05:36 PM
My Osh Photos Don Parsons Home Built 2 August 4th 06 08:53 AM
~ PHOTOS FROM THE FALLUJAH MASSACRE [won't find *these* photos on TekTeam26 Military Aviation 0 April 12th 04 02:49 AM
Niagra Falls and Quebec Steve House Piloting 4 August 21st 03 03:11 AM
Q: Niagra Falls and Quebec Peter R. Piloting 2 August 19th 03 05:23 AM
