Jantar Standard Canopy
Old June 25th 09, 04:11 PM posted to rec.aviation.soaring
jmarc
Default Jantar Standard Canopy
Is that possible to buy somewhere only the plastic
part of the Jantar canopy? I should probably take a look at
the "ceebaileys" like the previous post said for the Blanik.
But I think it will not be available that way. So I post here to know
if anybody have very good condition Jantar canopy used, to sell..?
jmarc...
Old June 25th 09, 06:08 PM posted to rec.aviation.soaring
Henryk Birecki
I do not have information, but you may want to specify which Jantar
Std. 3 has different type of canopy than 2 and I am not sure if one
from 1 fits 2.
Henryk Birecki
jmarc...
Old June 25th 09, 09:04 PM posted to rec.aviation.soaring
jmarc
Good point! It is a Jantar Std 2 ...
jmarc..
"Henryk Birecki" wrote in message
from 1 fits 2.
Henryk Birecki
jmarc...
Old June 25th 09, 09:19 PM posted to rec.aviation.soaring
sisu1a
But I think it will not be available that way. *So I post here to
know
Since it's a Std 2, now you should specify whether you need the front,
rear, or both sections since it's a 2 piece'r... There is a canopy
part that may be able to be fit for the rear section on wings & wheels
if you scroll down the page some...
http://www.wingsandwheels.com/Used%20Parts.htm
I know where a good canopy mounted to a frame for a Std 3 is should
you want to upgrade to a single piece canopy (there's already a few
2's out there with this conversion), although that's a 337 surgery as
opposed to mere maintenance... it sure is a nice view though!
-Paul
Old June 26th 09, 10:10 PM posted to rec.aviation.soaring
jmarc
You are right again. We need only the rear part.
I took a look at the wings & wheels site. But not sure
if I saw the one you talked about! Is seems to be
a one piece full canopy without the little door.. So
I will get more informations from the dealer..
But the best way is to find out
So, lurking on the newgroup, I learn about the MecaPlex
company. They seems to be the best place to get a
replacement canopy. Maybe they built original parts for
glider constructors, too! But it might be a bit pricy.
The best might be
So if nobody here on the net have good condition used
canopy, I probably contact them to know how much it
will cost for the plastic part (hoping the door will be
"sisu1a" wrote in message
know
-Paul
Old June 26th 09, 10:14 PM posted to rec.aviation.soaring
jmarc
You are right again. We need only the rear part!
Our Jantar is a SZD48-1 Standard 2
Once again, the best way is to find out there a used canopy
in pretty good condition..
jmarc..
know
-Paul
Old July 1st 09, 06:21 AM posted to rec.aviation.soaring
Adam
On Jun 26, 3:14*pm, "jmarc" wrote:
You are right again. *We need only the rear part!
I took a look at the wings & wheels site. *But not sure
if I saw the one you talked about! *Is seems to be
a one piece full canopy without the little door.. *So
company. *They seems to be the best place to get a
replacement canopy. *Maybe they built original parts for
glider constructors, too! *But it might be a bit pricy.
jmarc..
know
rear, or both sections since it's a 2 piece'r... *There is a canopy
opposed to mere maintenance... *it sure is a nice view though!
-Paul
Perhaps try joining and posting to the Jantar group on Yahoo.
http://groups.yahoo.com/group/jantar-sailplanes/
/Adam
Old July 1st 09, 06:23 AM posted to rec.aviation.soaring
Adam
jmarc..
know
-Paul
FWIW, the seller of that canopy recently owned a Jantar Std 2.
//Adam
Old August 2nd 09, 09:02 PM posted to rec.aviation.soaring
sisu1a
part of the Jantar canopy? *I should probably take a look at
But I think it will not be available that way. *So I post here to know
jmarc...
if your still looking...
http://adverts.gliderpilot.net/?op=s3&id=338
-Paul
Old August 22nd 17, 05:13 AM posted to rec.aviation.soaring
Are you always looking for a canopy for your jantar ?
I have one for sale for 1000CAD
Link of the advice: http://wingsandwheels.com/class/classified.php?id=2398
Pleasure
LAK-12 or a Jantar, and which model Jantar? rich Soaring 11 July 18th 05 11:54 PM
Jantar Std. 3 [email protected] Soaring 2 March 31st 05 11:50 PM
Airworthiness Directives for Jantar Standard 3 Miguel Lavalle Soaring 5 January 24th 04 11:55 AM
Cockpit sizes of standard Jantar goneill Soaring 2 December 28th 03 12:29 PM
Jantar Standard 3 Miguel Lavalle Soaring 9 November 19th 03 01:01 AM
