I've had a Trig TT21 in my LS8 for a few months now, replacing a Terra
TRT250D transponder and an Ameri-King AK-350 encoder that were originally installed in 2000. Because of the small size of the Trig it was very easy to install. Similarly to a previous poster, the Trig checked out perfectly in all modes, and the encoder matched the test set to within 20 feet from 0 to 20,000 feet. It clearly works fine in the air, too, as I saw a commuter plane divert a bit to clear me while I was thermalling. The best part is the low current drain. Here in the PHL-NYC area the transmit symbol is always on, but my 4 year old 6.5 AH battery (which also powers a Becker 4401, an SN10B, a Volkslogger, and an iPAQ 3750) has enough juice to last over 6 hours. I've got another 6.5 AH battery on board, but that will apparently be my cold weather backup! -John On Sep 12, 1:56 am, Eric Greenwell wrote: snip the Trig looks like a very good choice right now, perhaps the best choice for gliders. I look forward to more reports. |
| Thread Tools | |
| Display Modes | |
| Trig TT21 in Experimental Aircraft | Paul Remde | Soaring | 5 | July 5th 09 04:15 AM |
| Trig TT21 Transponder Thoughts? | jcarlyle | Soaring | 16 | June 23rd 09 05:38 PM |
| Quest Kodiak receives FAA certification | [email protected] | Piloting | 2 | July 25th 07 04:07 AM |
| forgotten trig for climb angle... | xerj | Piloting | 5 | January 29th 07 02:08 PM |
| US aviation hero receives RP recognition | [email protected] | General Aviation | 0 | November 30th 06 02:14 AM |
