Cobra Trailer Spare Tire mount failure
Old September 21st 09, 12:44 AM posted to rec.aviation.soaring
JJ Sinclair
Default Cobra Trailer Spare Tire mount failure
On Sep 20, 12:37*pm, JJ Sinclair wrote:
On Sep 20, 11:43*am, Mike the Strike wrote:
Mine failed in the same way. *It seems to be a design feature of the
Cobra, like the hydraulic ramp jack.
Mike
I never did like suspending all that weight with no part of the tire
resting on the floor, ala Komet.
JJ
My fix was to mount the spare flat on the floor under the fuselage
nose. This means I would have to remove the fuselage to get the spare
out, but I have only had to change one tire in 35 years. Now, watch me
blow a tire next week on my way to Williams!
JJ
Old July 17th 15, 09:43 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Anyone have any experience with the option offered by Cobra of mounting the spare under the trailer behind the axial?
JJ
Old July 17th 15, 10:29 PM posted to rec.aviation.soaring
I don't have experience of that Cobra option and don't know how it is designed. I have, however, been under a trailer that needed to be jacked up by the roadside to unbolt an under-mounted spare and it was a very worrying experience as passing vehicles blew the trailer about. I would only have an under trailer spare if the the design is such that the spare is in a cradle so that, no matter how flat the tyre, the wheel could be slid out from the side without any need to go or reach underneath.
John Galloway
Old July 18th 15, 01:57 AM posted to rec.aviation.soaring
I have that option, I put a plate on the inside of the trailer to help carry the load. The real problem with the initial installment is the bolts are too short and it is a real tussle to get the wheel off the bolts because as soon as one or two are loose the tire shifts against the remaining bolt and this can cause the threads to be damaged. Additionally, it is almost impossible to get the flat tire back on the bolts because of weight and short bolts. BUT, better than having the tire break off the original mount and fall on the nose of the glider.
Boise, ID
Old July 22nd 15, 03:57 AM posted to rec.aviation.soaring
Papa3[_2_]
I did the under-side mod this weekend as well. Made up a backing plate to help spread the load on the inside of the trailer. I mounted mine just behind the axle to avoid interfering with the surge brake mechanism. 4 grade 8 bolts poking down through the floor locked in place with jam nuts and fender washers on the bottom. Rim goes through the lug holes and held in place with 4 more nylock nuts with washers. Bought an aftermarket spare tire cover to keep everything from getting too messy - we'll see how/if that hold up. While I don't love the idea of crawling under the trailer, I figure that the flat tire can temporarily sit in the front of the trailer until we get to a convenient location to repair and put everything back where it belongs. In 25 years of trailering gliders I've only had 2 flats while on the road (maybe I've been lucky?), so hopefully it's a rare event.
Old July 23rd 15, 12:48 AM posted to rec.aviation.soaring
Just to close the [recent] loop, I mounted my spare flat on the floor under the nose of the glider. BTW, I was able to "reuse" the hole in the trailer floor where a bolt securing a bracket under the floor was already secured. The bracket is a simple strut that supports the brake rod about half way back from the coupler to the axle and keeps it from flapping around. I noticed that the bracket had been bent back by a previous collision with something under the trailer, not seriously but enough that it would have given me pause to locate the spare tire there. There's not much load on the bracket or the spare tire.
I have 13" wheels but went up one size in tire the last time I bought them to get more ground clearance (don't recall the size). As a result, the tire is JUST small enough to lie flat between the wings and not interfere with the spar dollies rolling in and out. Conceptually, the factory mounting the tire above the nose cone gives a lot more flexibility because there's more width there (due to the wing root shape) and the dollies are irrelevant. But obviously the load on the mount is a lot higher.
Chip Bearden
ASW 24 "JB"
U.S.A.
Old July 23rd 15, 12:49 AM posted to rec.aviation.soaring
And, yes, getting at the spare will require pulling out the fuselage on the side of the road. But that's a reasonable price to pay for me even though I've had more than a few trailer flats over the years.
Chip Bearden
ASW 24 "JB"
U.S.A.
Old July 18th 15, 03:43 AM posted to rec.aviation.soaring
Andrzej Kobus
The tire is in front of the axle not behind in that option.
cobra trailer brake lever gas strut failure? Frank[_1_] Soaring 11 March 31st 09 09:59 PM
Trailer tire rims Gary Carter Soaring 7 January 21st 05 04:15 PM
Trailer spare - who woulda thunk? Bill Daniels Soaring 7 May 20th 04 05:47 PM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 04:50 PM
Tire Stiffness & trailer swaying chris Soaring 42 October 22nd 03 04:51 AM
