On Sep 23, 5:53*pm, wrote:
On Sep 23, 6:26*pm, Martin Gregorie wrote: On Wed, 23 Sep 2009 15:00:04 +0000, Derek Copeland wrote: I think this rather depends on the degree of instability in the air. On relatively stable days the usual thermal sources often don't seem to work. You need a large area to remain undisturbed for some time until enough hot air is available to give a decent thermal when triggered. Often things like towns and motorways don't work because there is too much trigger activity going on and only tiny weak thermals will form that go to no great height. 'Flapping' (as its called in FF jargon) only works in calm conditions with weak lift. To be successful it requires an area of 'stuck-down' warm air that can be broken loose by some vigorous milling about. A few years ago at a WC we and the Russians, at adjacent poles, each had one man still to fly in the last 5 mins of a round. We could feel a thermal building and the thermal detectors showed the air temp was building but it wasn't likely to go before the end of the round, so we decided to try to break it loose and started flapping. The Russians saw what we were doing and joined in. The thermal got broken loose and both models climbed away in it just before the hooter at the end of the round. Flapping is common at major Euro and World level events where the fliers have retrieval teams available to flap, but that was the only time I've seen or helped to get a thermal going before the model was launched. Its more usual to flap under a model that's been launched before the bubble has broken away and is coming down. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Shat is a thermal detector? Bill Snead- Hide quoted text - - Show quoted text - Bill, In this case it's a long pole, mounted vertical, with temperature sensors at the top and somewhat lower to measure the temperature differential close to the ground. In addition there is usually a long, light-weight mylar streamer attached to the top that can show the inflow to the thermal as it begins to rise. here is a site that has pictures: http://www.gallery.f1a.info/imgpage....img/img026.jpg The long poles to the right and directly behind the guy with the model are the thermal detectors. Mike |
| Thread Tools | |
| Display Modes | |
| Which Way is That Thermal? | ContestID67 | Soaring | 26 | September 9th 06 09:30 PM |
| Thermal Divider | RST Engineering \(jw\) | Home Built | 18 | May 30th 06 06:03 PM |
| Thermal Data Files Thermal Mapping Project Australia | Mal | Soaring | 0 | December 3rd 05 12:14 AM |
| thermal lift | ekantian | Soaring | 0 | October 5th 04 03:55 PM |
| Thermal mapping | John | Soaring | 35 | April 27th 04 05:29 PM |
